Why were bikes chrome plated?
Bikes: Stevenson Custom, Stevenson Custom Tandem, Nishiki Professional
Quoted: 367 Post(s)
Liked 196 Times
I have a 1972 Nishiki Professional whose frame and forks are chrome plated. This was the top of the line Nishiki made in 1972. Why was this frame chrome plated before being primer coated and then painted? I have seen Japanese "Silk" bikes that were also chrome plated, was this common, or, reserved only for top of the line models. I would think the latter as it would add another step and cost into the manufacturing of the bike.
I know that today finding someone who will chrome plate parts is a real search and then getting them to do a high quality chrome plating a similar task.
Thanks for your history, recollections of this question.
Quoted: 5781 Post(s)
Liked 2,576 Times
Chrome plating of fork ends front and back in the "Italian style", is a classic look, probably started to add some protection in the areas most likely to be scratched by things like wrenches when removing the wheels.
Plating of the head lugs was probably a cosmetic statement, whereby the details of good workmanship showed out better.
When plating, some makers masked off the rest, but others simply plated the whole part, and painted over. In most of the frames that were fully plated, they would only polish the areas they planned to leave. So, you don't have the option of removing the paint to find a shiny frame underneath.
FB
Chain-L site
FB
Chain-L site
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
I as understand it there are or were two schools of thought. One was just to help protect the frame and as stated they were left rough and painted over. There is also a school that says it did something to the metallurgy and made the frames stiffer.
Sugar "Kane" Kowalczyk
Quoted: 941 Post(s)
Liked 319 Times
How about for the same reasons they used to chrome plate car bumpers, bling and protection from the elements.
The 1st fully chromed race bikes that I saw were track bikes whose finish gets banged up in normal handling to/from events, in the many gear changes for types of races and as part of the inevitable contact & crashes. Elegant is a fully chromed Paramount P-14.
-Bandera
-Bandera
Quoted: 3464 Post(s)
Liked 2,829 Times
Chrome plating under the velodrome lights just looks so Styling.
Gotta love chrome plated spokes too and mega polished Scheeren rims.
Chrome bars and stems...
Morelon, Nicholson, Trentin...
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Not necessarily top of the line, although those are the ones you commonly see. The 1972 entry level Bottecchia Special were plated then painted over, and with the paint quality back in 1972, it showed quickly. Mine started the flaking within a few weeks of being purchased new.
As @FBinNY stated above, the chrome in those frames painted over were frequently left with a rough, unpolished surface since it wasn't visible. Not easily polished out, or even possible in some cases.
Bill
Bill
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4679 Post(s)
Liked 5,797 Times
Chrome is *****in' and sexy. And that protection thing.
*ASFE = American Society of Fraudulent Engineers. Crap steel and modern super steels are just about exactly the same stiffness if made in the same gauge. Stronger steels allow for thinner walls.
Liked 2,576 Times
Yes, the ASFE* has made this claim often.
FB
Chain-L site
FB
Chain-L site
Semper Fi
Liked 358 Times
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
Because there is a basic human need for shiny:
...it's in Maslow's self actualization hierarchy.
Likes For 3alarmer:
Quoted: 2588 Post(s)
Liked 4,824 Times
Durability of finish first, bling later.
DD
DD
Quoted: 18374 Post(s)
Liked 4,509 Times
I think there were some Italian brands that painted a translucent paint over chrome (I think). Anyway, it created a shiny deep rich paint.
Maybe Pinerello or Torelli.
Likes For CliffordK:
Likes For qcpmsame:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
FWIW, when I find neglected bikes with rust, the chrome areas always have more rust issues than painted areas. For some reason, chrome seems to be more susceptible to rust. And once it gets pitting, it will never look good.
On the other hand, I love chrome bikes.
Definitely NOT limited to top of the line. Some lower end bikes were chromed, while some top of the line had no chrome. My chrome Katakura Silk was really a mid-level bike which came with nothing special Suntour LePree components. Since mine was parted out by the prior owner, and acquired as a bare frame, it now sports Suntour Superbe Pro components.
+10 Translucent paint over chrome looks fantastic.
Quoted: 367 Post(s)
Liked 196 Times
Thanks all, excellent to get a perspective on this subject. The reason for the question is the picture below:
Sadly someone road a badly miss-aligned rear wheel to the point that it rubbed through the silver paint, white primer, chrome plating down to the steel tubing, which shows its surface rust surrounded by the remaining chrome plating. In other spots on the down tube and fork, paint has been chipped off and the chrome plating shines through. Though as you say it is rough on the fork and down tube, sigh, sadly quite polished and shiny on the left inside chain stay tube pictured above.
Any suggestions on a good rust inhibitor to apply over the surface rust shown above? I am a little nervous about sanding given how thin tube walls can be.
Thanks again.
Thanks again.
Soak a towel in evaporust, wrap around the afflicted area, then wrap some plastic wrap around the towel (to keep the towel 'wet').
Clean with 90% IPA when done, run some clear nail polish over it, and love the battle scar.
Quoted: 1372 Post(s)
Liked 1,751 Times
Full chrome bikes are one of my favorites and the bike does not have to be high end...
Likes For randyjawa:
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
One of my high school pals rode a 1961 Schwinn Continental, complete with the original suicide front shift and an aftermarket Campag. GS rear derailleur and barcon. After he had crashed it (classic front-wheel pop-off), his father, the engineering manager at a heavy machinery plant, replaced the fork with an all-chrome one and had the frame chrome-dipped. Particularly when he waxed it, it certainly looked sharp.
As for cars, I recall chrome-plated door handles, which somehow look OK on a 1950s or 1960s Chevy, but which stood out dreadfully on some late model Acuras, including the TSX Sport Wagon I wish they had continued into the next generation.
Quoted: 378 Post(s)
Liked 1,409 Times
I've had several frames chromed under the paint, and all had polished/smooth areas only where the paint was left off.
This includes Italian:
Cinelli Super Corsa, over SLX
Mondonico Diamond, over SLX
D'Arienzo (Basso's frame builder) SLX
Cinelli (Chirico) Centurion Equipe, over SL (also over SP on larger frames)
Pinarello Montello, over SLX
and Japanese:
Lotus Classique, over Tange Champion #1 (Tsunoda frame builder)
Centurion Turbo, over Tange Champion #1
Centurion Semi Pro, over Tange Champion #1
Raleigh Competition, over 555
There is no doubt in my mind that the Lotus had the best quality plating and painting.
The Italians were no more consistent and thorough with their painting than they were with their plating. It's almost like they lost interest after they put their magic into the ride quality of the frame. The Japanese seemed the opposite in that their frame finish quality was much better, but the frames rode very well but not magically.
I've often wondered why the best steel frames I've ridden have been fully painted, both Italian and Japanese. I would think a full court press on finishing would follow the design, craftsmanship and attention to detail on the frame building. Imagine if Cinelli or Pinarello had sent their frames to the Panasonic National plant to be painted....combining the best both had to offer.
I may have missed some that I owned, but others here have the same experience, I think. My guess is that it was a relatively convenient corrosion protection, since parts of the frame were being chrome plated, anyway, like fork ends/crowns, lugs, etc.
I've stripped two of those down to the plating, and have yet to find one where the areas intended for paint were filed/polished fine enough to be left unpainted and looked at closely. Painters sure don't like to paint over chrome, but I imagine the rough chrome was much easier in that regard.
Chrome accents look great. All chrome is a totally different look, more dependent upon accents than a painted bike, and has a smaller group of fans, in my experience.
In the end, if I had to do it again, I'd follow Doc Cannondale, and find the frame I want, send it to Al Wanta or Joe Bell to be done the way it should have done to begin with.
and Japanese:
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
A shop owner at a shop I worked at years ago rode a Teledyne Titan , -- he swore the flex in the frame helped propel him up hills as it recoiled in a whipping motion to give some added boost
Me personally, I think if that flexy flyer was any better on hills, it was due to it weighing 17 or so pounds in an age when 21 pounds was considered light
Quoted: 1361 Post(s)
Liked 423 Times
Who was the premier Italian builder who said chrome was nonsense for a top tier race bike? Added weight and changed the tubes original characteristic -performance traits.
Pennylane Splitter
Bikes: Yes
Quoted: 1798 Post(s)
Liked 1,439 Times
Remember, there are different qualities of chrome plating, too. Cheap jobs done for purely asthetic purposes are no better that a paint job, but a good 'hard chrome' job that actually bonds the chrome-and-nickel-heavy layers to the base metal will resist corrosion and last a lot longer (and cost more, too). And its tough to paint over a good chrome job; the paint doesn't bond all that well and will eventually start to come off. Of course, why would you want to paint over a good layer of chrome plating?
-Bandera
Likes For Bandera:
