Winter project: upgrade cranks + chain line
just having fun
Hello! I've got some questions to ask now that I've done a bit of research.
I'd like to upgrade my cranks to something else. I'm currently running 1X set up, GXP (68mm) BB and SRAM S300 messenger cranks. On the rear is a Force1X derailleur.
Right now the chainline is set up so it's smooth as butter at 11T and stays that way until the higher gears where there it is more noticeably less so.
I know the easy option is to just get a set of SRAM Force/Apex/Red 1x cranks from their current line. Those are out of my price range, and I am totally fine using used parts of Craigslist. I like being able to piece something together with random quality parts to make it work.
Ideally, I'd consider an older SRAM Red crank from a few years ago. I'm open to Praxis, Rotor and almost any other brand aside from Shimano. Nothing against Shimano, but I dont want to mix SRAM with Shimano parts.
I'm confused as to which cranks would be suitable from older generation models and how to tell? Am I worrying too much about chainline because it's easy to adjust and I just don't know how to yet? Any suggestions for cranks? Is there a quick way to tell what the chainline will be with any particular set of cranks?
Thanks peeps.
Thanks for the help!
Thanks peeps.
Quoted: 1067 Post(s)
Liked 259 Times
Are you currently using a proper 1x narrow/wide chainring?
They are made with some offset to bring the chainline closer in and towards the centre of the cassette.
just having fun
I am, but it's one that came with the S350 messenger crank and so its not really intended to me removed. It has the same 1 logo on it as other 1x drivetrain pieces in the SRAM family, but I get the feeling that the chainline is not correct.
I did some research and found out what you said. So, I'm going to buy some old SRAM red carbon cranks, sand the logos off and repolish I'll post updated when I get them.
