27-inch tires too narrow - switch to 700c?
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
My wife's Motobecane Grand Touring mixte has 27-inch wheels. At the moment, it has a mismatched pair of tires. The rear is an old IRC Touring tire which states 32-630 but only measures 27mm inflated. The front has a Panaracer Pasela which has both "27x1-1/4" and 28-630 markings (weird - prototype narrow/wide???). It only measures 26mm wide. I have a new set of Paselas marked 27-1/4. I imagine they will measure more true-to-size, as I have a set on my Motobecane Grand Jubilé. Even after sitting idle for a month or more, I just measured a 30mm width.
Still, I wonder if I should just dispense with this foolishness and source some decent 700c wheels (120mm OLD). That would likely allow me to to mount 35-38mm tires and I'd have many more choices. I think the brake calipers Weinmann Vainqueur) have enough adjustment left in them to allow the switch. Any reason not to switch (aside from added cost)?
My wife's Motobecane Grand Touring mixte has 27-inch wheels. At the moment, it has a mismatched pair of tires. The rear is an old IRC Touring tire which states 32-630 but only measures 27mm inflated. The front has a Panaracer Pasela which has both "27x1-1/4" and 28-630 markings (weird - prototype narrow/wide???). It only measures 26mm wide. I have a new set of Paselas marked 27-1/4. I imagine they will measure more true-to-size, as I have a set on my Motobecane Grand Record. Even after sitting idle for a month or more, I just measured a 30mm width.
Make sure there's the needed 4mm adjustment left in the brakes. Obviously. Tires at that time maxed out at 32mm, generally speaking. You might be able to go a little bigger. You'll find out. I'd probably go with Sun M13 rims and 32c myself. The Sun rims look just like Rigida if you take off the stickers.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...I have and ride several bicycles with Panaracer Pasela 27x1 1/4 tyres, and find them very enjoyable to ride. They are especially useful if you have something that requires a 27" rim because of cantilever brake boss placement. If I have any caveat, it is that they are not nearly as useful if your current wheel rims are old enough to have no bead hook or an inconsequential one. They're much more fun to ride at higher inflation pressures that you can use with a decent hook bead rim.
Bikes: many
Liked 1,392 Times
Not really. 27" was used for those because that was the standard size. 700c was still quite rare and exotic. The Rigida rims they came with were quite narrow. That's why your tires are less wide than the nominal width.
Ellen's bike has Weinmann Concave rims which might account for the mounted tires running narrower than nominal. They do seem to be a bit narrower than whatever is on my Grand Jubilé.
Quoted: 796 Post(s)
Liked 522 Times
Not sure of the year of your Moto GT on my 1978 I run Pasela 27 x 1 1/4 and that is about as wide as it will take due to rear stay clearance I really like the Swift Sand Canyons in 27 x 1 3/8 - also Panaracer and have them on a Nishiki but I don't think they would work on the MotoGT
I usually advocate sticking with 27" but in your instance if you really want more than a 27 x 1 1 /4 (roughly 32) then probably going 700c would help. The question is how much wider you could actually go and if its worth the hassle - wheels possibly brakes etc?
700c tires will also give you a little more room for fenders.
Quoted: 964 Post(s)
Liked 1,451 Times
More room for tires and fenders, more options for high quality tires, what's the downside? Cost and effort, of course.
I would do it, and I would also spread the frame to 135 and throw in a freehub so you don't ever have to worry about broken axles and removing freewheels again. Any bike I own, save the two museum pieces with Maxicar hubs, gets this treatment.
Quoted: 930 Post(s)
Liked 1,292 Times
There is the Swifttire Sand Canyon, which is labelled as 27 x 1-3/8. I just bought a set and put them on my new Raleigh but haven't measured them. They don't look any wider than the 700Cx32 Compass tires I have on my Cooper though.
Bikes: many
Liked 1,392 Times
Thanks, yes I saw them mentioned in another thread where it was indicated that they weren't really any wider than 1-1/4.
Quoted: 796 Post(s)
Liked 522 Times
Quoted: 3464 Post(s)
Liked 2,829 Times
If you can drop the brake pads 4mm, why not?
More options, plus fenders as noted, but on a Mixtie, there is always rear brake to be double checked.
Likes For 63rickert:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
The 27"x1-1/4" Panaracer Paselas on my wife's Schwinn measure a full 32-33mm without the need for blocky or knobby tread.
My hot take: if you have "1-1/4" tires that measure 26mm or whatever, they're probably either old or crappy, and should be thrown out!
Liked 2,829 Times
We break up, she fits the bike with Weinmann levers and "Comfort" levers too...
Later sells it at a large profit.
20 years pass, our paths cross, "Never should have ended our relationship, and should have kept the Masi".
too bad, so sad, about the bike especially.
Whether those tires will fit on that 1970s frame remains to be seen. Whether your brakes can be adjusted to fit, also remains to be seen.
When I was building up my 1963 Jack Taylor Sports I used Mafac Racers which had enough reach to work. I would have used them regardless, because I wanted to use the TA front handlebar bag rack that was made to fit those brakes.
I also happened to have a perfectly usable set of 700C wheels left over from upgrading my 700C randonneur, thanks to the VW Dieselgate settlement, and either the original owner had at some point in the 50-odd years he'd had the bike spread the rear triangle or the bike originally was made that way, because the last configuration the original owner had the bike in featured an indexed Campagnolo 10 Ergo drivetrain, and I had no difficulty getting a 130mm wheel to fit.
Period-correctness was never going to be an issue with this bike. I set up as though it were a brand new frame rather than one that had been made over 55 years before, with components I liked, that I had on hand, and that reflected my preferences in setting up a bike. In this case, that meant an XTR M900 drivetrain, indexed 8 speed, with bar end shifters and modern generator hub lighting.
I'm using Grand Bois Cypres 700x32C tires on this bike, and even though they're still a couple of steps down from the best 32mm tires (such as the Rene Herse Stampede Pass with the EL casing) the tires are still significantly better than any 27 x 1 1/4" tire that has ever been available.
Likes For palincss:
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
smontanaro see this post: https://www.bikeforums.net/20175974-post63.html
I wish I'd taken measurements on it, but those are 27", 1x1-3/8 and relatively low cost investment, see the Moto GT they're on in the pics for a reference on how bulbous they appear. I have a few pair in the shop I horded when the price dropped down again below $10/tire at Niagara but haven't installed yet on the bike they're intended (Claud Butler I just got). Could be suitable for your needs. I can slap them on the CB this weekend and take some measurements for you if you want. Would give me a good excuse to get into the shop and hide from the kids and my "better 3/4"
These are Compass/Rene Herse 700x38c tires on my Moto Grand Jubile. It's just about the limit in terms of clearance between the chainstays--- the wheel is pushed all the way back in the dropouts. But I really like the way they ride....
I did put a slightly longer-reach Weinmann brake on in the back, but those are pretty cheap/easy to find. Was thinking about 650b for this bike, but for the moment this is riding very nicely...... I guess if I want fenders I'll have to go to 32c or 35c....
Likes For no67el:
Quoted: 346 Post(s)
Liked 398 Times
Look at the MICHELIN Protek 32-630 , 27 x 1 1/4 tire.
It is one of the heavier tires based on it's weight in grams, so if you're opposed to weight, it might not be for you.
Great riding tire.......durable and protection against thorns and road debris......reflective outer ring on the sidewall which is very nice.
These are true to size and are among the widest 32-630 tire on the market......no cheating or fudging with the Michelin Protek tire.
You should also know that these appear to be taller than several other popular 32-630 , 27 x 1 1/4 tires on the market Based on my own
non scientific observations. This might be an issue on certain bicycles that have fenders as you'll likely find that you may have less fender
clearance than with the 32-630 tires that you may be currently using.
I have these Protek 32-630 tires on my 1971 brown Schwinn Suburban Five Speed with the stock fenders removed.
The are great tires for the type of tire that these Michelins are, but if WEIGHT is an issue, you're gonna want to look for some other tire.
m
m
Quoted: 1303 Post(s)
Liked 1,911 Times
smonatanaro,
Your wife has a set of bomb-proof wheels and you want to switch them for something else to fit a wider tire???? Not a problem, ship them to me and I'll find you a couple of cheap drop bolts to make the brakes work correctly. Methinks there is a bit of overthinking going on here! There are plenty of good tires that fit the 27" rim and will work. The cost of a pair of tires is way cheaper than all of the changes you will go through to make the change to 700c wheels. Smiles, MH
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
If you want wider 27" rims get a set of Sun CR-18s. I got them for my '74 Raleigh rebuild and they're quite nice. I mounted 27 x 1 1/4 Panaracer Pasaleas on them. The whole combo is quite nice. I'm running Tektro R539 caliper brakes with them since the old Weinmans were sucky.
On my other vintage Raleigh I made the switch to 700c (running 700x32 Pasaleas there), and Tektro R559 long reach brakes.
Both are great combinations and have worked well. Both are commuter bikes.
Likes For the sci guy:
PM me your cotters
Liked 590 Times
Overall great tires, they've held up well, believe it or not these are at least 18 months old (she only rides casually). She says they ride well. Looks wild when light interacts with them at night, the reflective strip is bright! My only gripe is the squarish profile and lack of vintage vibe. But maybe varieties other than the Cross look different?
Bikes: many
Liked 1,392 Times
Thanks for the feedback folks. I'll respond to a number of comments in a single post. But first, a small confession. I originally stated that the Pasela on the front wheel was marked as both 27x1-1/4 and 28-630. The inch marking was actually 27x1-1/8. I blame poor lighting in my bat cave and my aging eyes.
Working backwards:
Working backwards:
- TriBiker19 Kenda, just say no. I don't really care how good their tires are now. Their tires and tubes have given me too much trouble in the past, so I refuse on principle to ever purchase their products.
- the sci guy Thanks for the CR-18 tip. The Weinmann Concaves don't have hook beaded rims or eyelets, so if I stick with 27-inch rims, I'll consider them. (We have three bikes in the stable with 27-inch rims, so even if this Moto stays as-is, one of the others might get new hoops.)
- Mad Honk Thanks. I don't think drop bolts will be required. I believe there is enough adjustment left in the brake calipers if I go to 700c. Also, I'm not convinced that an old set of Weinmann Concave rims laced to some mid-level Normandy hubs with old galvanized spokes qualifies today as "bombproof." The last thing I want to do is have Ellen ride a bike that leaves her stranded. (Upgrading to something else, even if it remains at 27-inch, would eventually be a good idea.) She doesn't ride during the winter, so I have time to execute some alternate plan.
- no67el Thanks for the pic of your Grand Jubilé. I have one as well. I don't think of it as a "keeper," but it's nice to know a 700c swap is a possibility.
- ThermionicScott I had a pair of 27x1-1/4 Paselas, so I installed them yesterday. After sitting overnight at about 60psi, they both measure between 29 and 29.5mm. My guess is the difference between your measurement and mine can be chalked up to differences in rim widths.
- 63rickert If I collect the parts, do you want to lace up the wheels?
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
@smontanaro, have you perused this sticky thread? https://www.bikeforums.net/classic-v...ce-thread.html
Many! great recommendations for 27" tires, including my favorite Continental Ultra Sport II, which for 27x11/4" size measures a true 32mm and is a supple side walled comfortable ride to boot! I have both 27" and 700C wheels and there is no intrinsic advantage to either one. Great tires are available for both!
