Are all bumps to be avoided?
Quoted: 10236 Post(s)
Liked 5,183 Times
New to cycling, and after breaking two spokes back to back I have gotten really paranoid about bumps on the road. Along my normal route I cross bumps at a couple of intersections. The are for helping with run off and are about an 1.5 inches high, and it goes across the whole span of the street. Should I change my route to avoid it, or am I being extreme?
Thanks
Thanks
Expired Member
Quoted: 3658 Post(s)
Liked 5,403 Times
A bump like you describe should cause no problem but you can lift your butt off the saddle to un-weight the rear wheel. If you are breaking spokes there is an issue other than those bumps. Do you weigh too much for your bike?
Liked 5,183 Times
I am not to sure if I am too heavy. I am 511 185 pounds and it’s a 56 cm cannondale caad 4. It had the original mavic wheels that were put on it in 2001 and I have no way of knowing how many miles were on the wheels. I just replaced the rear wheel, I just don’t want start breaking spokes again.
Quoted: 4717 Post(s)
Liked 1,882 Times
It's not a bad idea to have the wheel checked by a skilled wheelbuilder, even for a new wheel.
Likes For noodle soup:
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
Your wheels have not been maintained and probably weren't built properly in the first pace. I've never broken a spoke in my life, and I've been riding for ~65 years. Any decent bike shop should be able to re-tension your wheels. You should be able to hit bumps hard enough to flat your tires and dent your rims without breaking a spoke. That said, it's possible that all your spokes have now been fatigued so badly that they are all getting ready to break. I'd just buy new wheels.
No, you are not too heavy. Our tandem weighs over 350 lbs. with us up in touring trim. We don't break spokes even on cobblestones.
Results matter
Results matter
Liked 5,183 Times
Cool, I ordered through my lbs and they checked it out before I took it home. I appreciate the help.
Expired Member
Liked 5,403 Times
Nope, not too heavy. Your new wheel should resolve it.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
I've been called paranoid, but if I broke a spoke I'd get the wheel rebuilt with all-new spokes by a well-regarded builder. The impact that broke one spoke stressed the others, and those took further stress from the wheel being out of true. And if the wheel was built improperly and that contributed, the other spokes were already at risk as well. Fix (or replace) the whole thing. As you did.
Liked 5,183 Times
I’m extremely interested In learning how to work on all aspects of my bike. I fly airplanes for a living and with airplane ownership the insurance cost and mx cost, are usually what keep people away from owning one. In my short time in this sport I can see how the mx cost could easily become a scaled down version compared to airplane ownership.
I plan on buying a truing stand, and replacing the spokes on my old wheel myself. Not necessarily to use the wheel again, but it would like to know how to build a wheel, and tru one as well. I like my LBS, however I don’t want to have to go there every time I have a small issue.
Quoted: 365 Post(s)
Liked 419 Times
It sounds like you did the right thing. IME, you break one spoke, you replace it and ride the wheel. You break another in short order, you either (a) accept that you'll be periodically breaking spokes; (b) re-build the wheel or (c) get a new wheel. If the LBS is trustworthy, then I would take their advice, as you did.
I have an inexpensive truing stand, but I use it to make small changes to my wheels, I don't use it to build wheels. A front wheel would probably not be a big deal, but with modern wheels the large amount of dish necessary to accommodate the larger gear clusters, and the resulting large difference in tension between the drive side and non-drive side spokes makes me leery of trying to build one. Plus, I wouldn't be building enough wheels to gain (and maintain) the experience necessary to build good wheels. I'm pretty sure I'd break more spokes on a wheel I'd built myself than I would on a factory manufactured wheel. But that is me, I'm OK with basic maintenance, but I'm not interested enough to learn everything and I take some work to the LBS.
If you're interested in building wheels, see if your LBS would be willing to show you. Some LBSs are happy to help do-it-yourselfers, others not so much. Maybe you could get practice by building and re-building the same wheel a few times? Also, I would think a tensionometer might be a good purchase. Some people can use the pluck and listen method to gauge tension, but personally I'm not that good at distinguishing pitch.
Liked 5,183 Times
Liked 1,938 Times
I've been building my own wheels for years. IMO a Park TM-1 tensiometer is a necessity for the beginning builder. Experienced folks who build a lot of wheels using the same spokes can do it by ear, but even they won't be as accurate as an amateur with a TM-1. However you don't need a truing stand or a dishing tool. Your bike works fine as a truing stand. After all, if you have to do touch-ups before or during a ride, you won't be pulling the wheel and putting it on your stand - you'll do it right on the bike. To get dish correct, simply flip the wheel in the frame. Wheel building is relatively easy, just time consuming until you get good at it. Figure 2-3 hours for your first wheel. There are online spoke calculators to get the spoke length right. My practice is to put a little anti-seize on the spoke threads.
I've been using these instructions: https://www.bikewebsite.com/build.htm
and some of these tools: https://www.bikehubstore.com/category-s/570.htm
I use the Mulfinger tool, Unior wrench, and Sapim PolyAx brass nipples.
It's fun, and you can build your perfect custom wheels from parts you choose, which don't have to be expensive.
Results matter
Results matter
Quoted: 5224 Post(s)
Liked 3,581 Times
I never brake nor stop when there are bumps (unless it's unsafe to do so). If the bumps are small, I just unload the saddle and the bars until I have passed over them. If it's a big bump I bunnyhop over it. The worst bunnyhop landing will be better than a speed bump at high speed.
Likes For Amt0571:
Quoted: 8271 Post(s)
Liked 9,022 Times
Full disclosure, I break other stuff, too. 4 frames, broke shoes, had pedals snap off 3 times, saddles, seatposts, stems, motorcycle suspension parts, etc.
Quoted: 97 Post(s)
Liked 106 Times
You're just going to have to learn to 'post up' over the rough stuff! Build some 36 spoke wheels... they are tough! I've only broken one spoke in over 35 years of riding. The only reason I remember that is because the spoke jabbed my calf muscle! I had a seat break once and some derailleur cables broke but that's about it.
Liked 1,938 Times
I used to be 220# and now I'm around 200 and I have broken so much stuff I can't even remember it all. Lots of spokes and rims. Every rear wheel I use will fail eventually. The best wheels I have used are built by hand by pro wheel builders. Once spokes start breaking it's time to rebuild the wheel if it isn't cracked.
Build your own wheels using the TM-1. Cheaper and better. Use deep section rims, at least 26mm, 32 spokes, 14-15 DB.
Results matter
Results matter
Liked 9,022 Times
I've built all my own wheels for about the past 20 years. I'm not a pro by any means. I'm really slow, but I'm accurate and I know how to choose rims and spokes and pair them to the application. Our tandem has ordinary road wheels, just built and tensioned properly. When we camp-tour on it, we have two rear panniers, no front. The tandem does have the advantage of a rear 145mm O.L.D. so the drive side spokes aren't as highly stressed as on a 130mm road wheel. Still. BTW I now run the same CX-Ray spokes and rims on the tandem and my single, just more spokes on the tandem..
There is more to breaking wheels than weight. Lennard Zinn had an article about guys who break a lot of stuff. The theory was that some guys have a spike or surge in their power output which flexes and fatigues things. Another thing is riding style. From years of off-road motorcycling I tend to lift the front wheel and let the rear slam into bumps with my heels dug in. We have some terrible roads here.
I've used multiple wheel builders, some are waayy better than others, many different rim/hub/spoke combinations, and tried wheel sets like Ksyriums. On my 3rd set of wheels on my current road bike with 6 failures on the previous 2 sets and I just replaced the rear rim on my mtb due to multiple cracks.
Liked 5,183 Times
I used to ride bmx back in high school, and when I first started cycling I did notice I had a tendency to lift the front wheel over the bump, causing the rear wheel to take the most of it. I don’t do that anymore, I try to take the weight off the rear wheel.
How did you like the krysiums? That was one of the wheels I was looking at. I ended up with a factory made machine wheel for now, my LBS provided it, and it was all I could afford at the moment.
Liked 9,022 Times
Liked 5,183 Times
I liked the way they ride and they looked good on my bike but the spokes kept pulling through the rim. They're threaded into the rim and I just kept ripping them out. The first 2 times Mavic warranteed it for me but the 3rd time I had to pay for a new rim. That's when I stopped using them, they're sitting in my garage. I've been using 32 hole Open Pro rims on Record hubs with double-butted DT spokes for a couple years. No problem yet except truing. My weight is down to 200 and my mileage has been down, too.
Liked 1,938 Times
I have built wheels before, 36 hole Mavic MA2. Still broke a spoke while touring @Around 260# all up. I'm no good at wheel building, find it tedious.
I used MA2 rims also back in the dawn of time. Flimsy rims with decent brake tracks. Ksyriums are another wheel with a flimsy rim. You don't want that. Light rims were all the rage years ago. Look at Kinlin XC-279 or XR-300 rims for examples. If you don't want to build, have your shop build 32H wheels with a rim of similar depth. Wide helps, too. I think, 14-15 spokes, and 120 DS kgf, 100 on the front. Any decent sealed hub will work IME. Prowheelbuilder has quite a selection of rims and drillings.
Results matter
Results matter
