Jerking Under Load
Quoted: 451 Post(s)
Liked 364 Times
Jerking Under Load
Currently running 105-5800 on a BMC SLR02 about 2 years old. No issues with bike so far. I am currently doing a lot of hill repeats on some pretty steep stuff here. The other day, halfway up a fairly steep section and while pushing pretty hard, I experienced a jerking sensation in the general area of the right crank--or so it seemed. There was a loud, metallic pinging sound, a deeper pitch, not high-pitched, but still, metallic sounding. Then, the drivetrain continued functioning just fine. Since then, it has happened a couple of more times, always when under quite a bit of load.
I had the chain length checked a few hundred miles ago and it was stillf fine. The cassette looks okay still. But I do ride about maybe 200 miles a week right now, so that could have changed.
Any thoughts for me?
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,587 Times
Frame flex? (I'm not a mechanic)
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Replace the chain.
If the problem persists, replace the cassette.
Also, if the front chainring(s) are worn, this could be an issue. When you replace the chain, if it gets worse, it is most likely the cassette and/or the front chainring(s).
Quoted: 451 Post(s)
Liked 364 Times
Well, good question. On the hill repeats I know the answer, because I am always in the little up front and teh 4th easiest in back. It has happened once or twice while on more flat terrain and I have no idea what I was in, other than that it was little in front.
Quoted: 451 Post(s)
Liked 364 Times
Thanks!!
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Sounds a lot more like the drive dogs in the freewheel not fully engaging the drive pawls. Or a loose bottom bracket/crank arm.
Likes For AdkMtnMonster:
Likes For dwsmartins:
Occam's Rotor
Liked 2,331 Times
Is that you, Ms Cleo?
I'm absolutely incapable of detecting wear visually.
I also should have said that it is unlikely both front chainrings and all of the rear cogs would be worn equally, so if you can get the problem to go away by shifting, that is usually a good indication.
Forum Moderator
Liked 6,587 Times
While it sounds like this isn't your issue, here is a description of frame flex.
Frame Flex | Kirk Frameworks
Bottom Bracket/Drivetrain
I believe that this is the most talked about and least understood of the three flexes. You often hear people say that the stiffer the better and that any bottom bracket flex results in a loss of energy. I firmly believe that to be untrue. Let’s look at what causes bottom bracket flex and what it leads to.
Likes For cb400bill:
bike whisperer
Quoted: 1526 Post(s)
Liked 718 Times
Crank starting to fail?
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Registered User
Quoted: 188 Post(s)
Liked 276 Times
I had it happen to me on a local climb. I thought it was the BB as it clicked intermittently but always while my right foot was at 11 o'clock. Really strange because I was expecting crank problems. I removed and re lubed everything. Finally I removed my rear wheel and checked the cassette.
I had repaired a flat 2 weeks earlier then the noise started that weekend on the climbs.
Turns out that my lock ring had somehow come loose but not loose enough to feel by hand. Used the proper tools to tighten and sure enough, a little loose.
Put the wheel back on, noise problem solved. That one really stumped me so whenever I remove the rear wheel, I always double check the lock ring.
Likes For TheDudeIsHere:
If it always happens under hard load, it's related to an interaction between frame flex and drivetrain almost for sure.
Maybe when pushing hard your chain rubs on the FD?
Likes For Amt0571:
Quoted: 1572 Post(s)
Liked 643 Times
Check this:
Set your bike up against something and turn the crank backwards while watching where the chain exits from the derailleur arm. If you see the arm move a little bit, you have a tight chain link. if that's the case, find and loosen up the tight link and you'll be good to go.
Likes For Retro Grouch:
Quoted: 1324 Post(s)
Liked 927 Times
Check your frame for cracks too.
Cheers
Cheers
Likes For Miele Man:
Quoted: 713 Post(s)
Liked 796 Times
Sounds like the small chainring is worn. I had to replace one on my gravel bike after I replaced the chain. It worked fine until it was under load from climbing. Under load, it had a bad vibration/grinding noise from the worn teeth hitting the roller instead of the space between the rollers on the chain.
Likes For dsaul:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I was thinking along the same lines as kimmo. Could the crank be failing in some way? Don't know if spline failure (its a 105 setup if I read the OP correctly) or perhaps the crankarm tightening bolts weren't tightened properly (too loose or too tight so that one broke)?
Likes For WizardOfBoz:
Quoted: 451 Post(s)
Liked 364 Times
Well, little update on this. I replaced the cassette and chain with brand-new ones. Just went with an Ultegra chain. It's fine. Everything was fine for a couple of weeks, but now, it is occurring again. Difference today is, it is not just when under a fair bit of load. Even when just applying fairly modest power, it just slipped, I guess, is a way of putting it, earlier this morning. Then, it returned immediately to normal.
I will go through every post one by one and do each intervention, one at a time. Then, if it's still there, I'll be back. Actually, I'll be back either way, just to report on what seems to have worked (and not worked).
Thanks to all for your help. I really appeciate it!!!!
Likes For alo:
Liked 927 Times
It's actually SLIPPING not just making a noise? Check the chairing teeth for excessive wear. Also check the freehub.
Cheers
Cheers
Liked 927 Times
Years ago I bought a used bike and took it for a short ride before completely checking everything over. Going up a moderate incline on a long hill I got this nasty crunching sound and sometimes some slippage. When i got home I opened up the bottom bracket which was a square-taper cup-and-cone unit with caged bearings. the bearing cage on the none drive-side was in pieces. I hope it's not your bottom bracket bearing s going.
Cheers
Cheers
Quoted: 451 Post(s)
Liked 364 Times
I have had a good look at the chainrings and I think they are still just fine. But will keep it in mind. Have not looked at the freehub. Will have to read a bit, as I am no hub expert.
Thanks very much for the guidance--I really appreciate it!
