Minimum size tires for 29 inch x 41mm rim?
I have a 29 Plus bike (29x3 Chupacabra tires) , but sometimes I might like to ride on some pavement in addition to the dirt/gravel roads for which the bike seems to have been made. I upgraded the rims a while back to carbon Whisky, 41mm width. What is the most narrow tire that I should mount on these wheels? It would likely be a gravel tire of some kind, and hopefully tubeless, as are the Chupacabras. It's just that the Chupas are like glue on pavement.
Quoted: 4205 Post(s)
Liked 3,864 Times
I suspect that even a 38 wide tire will seat (likely with a tube). I wouldn't want to rid that set up though.
I don't like the straight/vertical side wall that seems to be the current fashion. But you will do what you want. Andy
AndrewRStewart
AndrewRStewart
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I don’t know what the minimum size is in terms of getting the tire to mount and stay on securely, but if you run tires with any sort of side knobs, if you go too narrow then the tire profile may be flattened out enough that you are always riding on the side knobs, rather than just when you lean the bike over.
Quoted: 152 Post(s)
Liked 173 Times
According to the DT Swiss chart I like to use for ref. 2.80" - 3.20" are recommended with 2.35" - 4.20" being possible combinations. Assuming the 41mm is the inside rim width.
DT Swiss Tire Pressure and Dimension Chart
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
I think, in general, it seems like a bad idea to have a tire narrower than your rim. I am guessing the 41mm is the outer width because when I googled 'whisky rim 41 mm' the words '35 mm inner width' popped up. So a 700x42 mm tire would be the narrowest I would use.
Liked 3,864 Times
"I didn't know whether the 41 was inside or outside width, but I didn't want to dismount the tire in order to find out"
Measure the outside of rim width. Is it 41mm? If so then the inside width isn't 41mm. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Tire speed is mostly a consequence of casing construction and tread pattern, and not width. There are a lot of fast tires in the 2.0-2.2" range, and I'd pick from one of them. https://www.renehersecycles.com/shop...elope-hill-tc/ would be my choice if cost were not an object. Schwalbe G One Speed in 2.35" would be a good, more mainstream option.
And thanks for pointing out the obvious. I have been known to overlook that while immersed in the underlying theory.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
So, not to be a jerk, but the web is your friend and the manufacturer usually posts useful information (not always though!).
The Whisky 41 rim has a 35mm inner diameter and the optimal recommended tire width is 2.4”-2.8".
https://whiskyparts.co/rims/no9_41w_Rim
2.4”-2.8" is 61-71mm. But to your question, they recommend 2.4 as the smallest "optimal" tire. That is probably "optimal" for the intended use of the rim which is mtb/off-road. You probably could go a little smaller, but you'd want to check the tire mfr specs and recommendations. Not sure how much extra benefit you'd get by riding, for example, 2-1/4" inch tires as compared to a 2.4" width tire.
Quoted: 6193 Post(s)
Liked 4,809 Times
29 plus are the same BSD as 29" tires..... generally. Which also share the same BSD as 700C tires, 622 mm. You should be able to run a 29" tire on those rims, this being one of them that to me looks better than a knobby for road, but there might be others too.
https://www.jensonusa.com/Maxxis-Hoo...Wire-Bead-Tire
Might be better to get a set of wheels with narrower rims. Then you can open up your tire options more. There will be plenty of road options as you get narrower. You'll also have a set of wheels you can swap easily for your riding conditions.
This is one case where disc brakes if you have them will be an advantage as you can swap wheels without having to adjust brakes for the narrower rims.
p.s. if those are Bontrager rims, then look carefully and you might see a sticker or printing for the internal width and BSD. Many rims of other Mfr's will have this too. My son's 29er from Trek has it on them. I have to use magnifying glass or snap a pic with my phone and enlarge it as it's too tiny for my eyes.
2.4 tires are the minimum recomended for 35mm inner rims. So +1 to schwalbe g one speed on 29x2.35 or surly ET on 29x2.5 if you want more durability.
And yes, I have disc brakes, and also other wheel sets with mtb tires mounted, 29 x 2.2 to 2.35, but those rims are aluminum. Therefore, I am weighing the option of simply swapping wheel sets versus swapping tires on the one set of carbon rims.
Ultimately I will try the Schwalbe G-One gravel tire, which I surmise is substantially different from the typical Maxxis mtb tire. Better on pavement, anyhow.
Bikes: Trek Marlin 6 29r - Scattanti road bike w carbon fork - Trek 6500 - Univega Alpina 503 - Specialized Sworks M4 made in USA
Quoted: 90 Post(s)
Liked 103 Times
My Trek Marlin 6 is-was a 29r. The knobbies that came on it wore down . As I am riding mostly all flat trails, I put on a set of Kenda Kross 700 X 42s .They seem to ride almost as smooth as the 29rs did.
Liked 341 Times
Liked 341 Times
But now, I have to go back to some very tedious data treatment. Sigh...
Yes, 29 x 3 inch. I actually love the Chupas in the environment for which they were intended, gravel and dirt. Pavement riding has me checking the knobby surface for glue.
Really Old Senior Member
IF it were me, looking for the narrowest "safe" tire for a 41mm outside width CARBON rim-
I would go as narrow as 50-51mm. (1.95-2.0)
That gives about 5mm on each side to make curb contact, helping protect the rim.
IF pavement only, you might want some lighter "street slicks".
