Anyone using 700cX40 tires?
I recently bought a new Wheeler hybrid that came with 700cX40 Kenda tires. This is my first bike with 700c wheels and the 40s seem really big at first glance (maybe that's only because I was riding a commuter bike with 26"X 1.25 smooth tires).
Does anyone here use such wide tires? Do you notice a slowness in handling or increased rolling resistance? I'm wondering if it's just a case of getting used to the new bike and larger rims.
Bikes: 2012 Giant Roam 1
my bike actually came with 700x40. i swapped mines out after a few rides. went with a 700x32 specialized infinity armadillo.
Bikes: Cannondale Supersix Hi-Mod / Scott Spark 930 / Scott Sportster 20 / Jamis Allegro 2.0
I doubt you'd notice a huge difference swapping them for 32s...
Mine has 35s and I swapped them for 28s at one stage...the only difference I experienced was feeling a little less comfortable on some little off-road trails I like riding on. I put the 35s back on.
Really Old Senior Member
When I got my hybrid, they had Specialized Armadillo Flak jackets in 35MM.
What SLUGS they were! They made the 26x1.50" on my "grocery getter" seen like race tires.
I couldn't believe how a "street" tread could be such a pig. Heavy to accelerate and I had to work my butt off to maintain speed.
You should be able to go as small as 25-26MM without issue.
The difference will amaze you. Even a 28MM (1.125") will be "fab"!
My bike came with 700x42 tires but I have nothing to compare to. I did try a bike with 700x32 which was more zippy but I did not ride it extensively.
Bikes: 2011 Trek 8.4 DS hybrid; 2012 Felt F-75 road bike; 1990 Specialized Stumpjumper MTB; 1992 Guerciotti road bike (inactive)
Are the Kenda's smooth too?
I've been using 700 x 40 semi-slicks (Michelin Citys) on my hybrid for about a year now and they are plenty fast for me. I pump them up hard. The rolling resitance of them is no problem at all, and I do mostly brisk road rinding. I do not feel as though they are too slow on the road (for a hybrid). However, this is compared to 26 x 1.85 semi-slicks (same type of Michelins) I used to ride on my MTB on the road. Seems like there might be slightly more rolling resistance since your 700 x 40s are wider than what you're used to. I'd give it a month or two of riding to draw your conclusion. The 40s may be doable.
Bikes: Giant Defy 2
Bikes: Giant Defy 2
Ha ha ha ha ha
Bikes: 2004 ORBEA Mitis2 Plus Carbon, 2007 Cannondale Bad Boy Si Disc, 2012 Trek Gary Fisher Collection Marlin WSD 29er Aldi Big Box (Polygon) 650b
Quoted: 8 Post(s)
Liked 11 Times
Pictures please 700x 40 sounds freekin hot.
I just went from 60 psi 32c tires to 105 psi 28c tires. The 32c tires may as well have been glued to the forks in comparison. Greatest performance mod you can make IF you are strictly riding in the street. Tread pattern being the same, the laws of physics dictate that you WILL be a difference.
The difference in rolling resistance is negligible. The biggest difference you will notice will be due to rotational inertia which you can achieve by reducing the mass of the wheel and tire. This allows the wheel to accelerate at a higher rate. I do not know the weight of the tires you chose, but even as little as 50 or 100 grams makes a difference in how the bike feels. What is noticeable and what matters are not necessarily the same thing though.
I think 40c is really pushing it. I wouldn't use anything past 38c. On the other hand 32 and 28c seem to be the sweet spot for a hybrid.
The 700x38C Maxxis overdrive tires are much faster feeling than the old 1992 Specialized Nimbus tires they replaced, which were supposedly 42C tires. Those Nimbus tires from back then look almost exactly like today's Kenda Kourier K tires, too...
Edit: I messed up!!! It's not the Kourier K, but the Rain V-Cut that bears the resemblance to the old 1992 Specialized Nimbus tires, though the Kendas are smaller and thinner 38C skinwalls.
Kenda Kourier 700x40
https://ecx.images-amazon.com/images/...500_AA300_.jpg
Not as smooth as my previous bike, but not overly aggressive.
In the end though...it really comes down to personal preference. My 42mm tires are 500g, manufacturer claim, so they're not a whole lot heavier than some 32mm tires.
Bikes: Mongoose Switchback
My K2 came with Kenda Komfort 40c's. Switched them out to Maxxis Overdrive 38c's. Not a huge difference in ride or handling, but I like the Maxxis tires more than I did Kenda's.
Bikes: Giant Defy 2
Good for you...
Quoted: 184 Post(s)
Liked 353 Times
My Diamondback Edgewood came with 700cX40 Kenda Cross tires. I think they are great, compared to what I was riding on before. I had a Giant Sedona MTB. I had switched out the knobby tires that were on it when I bought it (used) with a brand I can no longer remember semi-slick tire. Seems like I can ride a little bit faster than before. My new bike doesn't feel quite as sluggish as my old ride did at times. Even if it's all just in my head, I like the way these tires I (and the whole bike in general) work.
Papaya King
Bikes: 2009 Felt X City D, 1985 (?) Trek 400, 1995 (?) Specialized Rockhopper, 1995 Trek 850
My Felt hybrid came with 700x38 Conti City Contacts. They roll great, and ride great. I think they're awesome.
Bikes: Classic lugged-steel road, touring, shopping, semi-recumbent, gravel
Quoted: 46 Post(s)
Liked 81 Times
Kenda Kwest here. 700x35 (ISO 37). Very low rolling resistance, excellent wear. I have thousands of miles on them and they are now on my shopping bike.
It is not. It is entirely possible to get big light weight tires and heavy small tires.
My 42mm tires weigh about 450g (manufacturer claimed) and there are 32mm tires out there that weigh 600-700g. In this type of scenario, it's entirely possible the 42mm tires can feel quicker because of less inertia.
Bikes: Giant Defy 2
I'm an honors graduate with a degree in industrial mechanics. I head special projects with our mechanical engineering department with 30 years experience. Explain to me what I don't understand sunshine? You just got all pissy for nothing.
Bike Sorceress
Bikes: Yes
Quoted: 59 Post(s)
Liked 102 Times
I have Innova 26x1.75 (559-47) tires on my Giant, and it feels plenty fast to me. Sure, 1.25" slicks might be a little faster, but it's a hybridized MTB, I'm not going to be racing it.
