Should I buy this Tern Link?
Old 04-14-20, 11:55 AM
frofro
Quoted: 7 Post(s)
First to say I live in a country with limited choice of bike brands, folding bikes especially.
My primary city bike converted to mid-drive is waiting for replacement parts and I'm eager to ride.
Some time ago used Tern Link d7 appeared in great condition convertes to electric with 500w rear hub drive. I'm sure ebike components are decent quality and are installed by local shop and still under warranty.
What I'm not sure about is, is this bike safe to ride having in mind my 90kg (198lbs) of body weight and Terns reliability record on this forum. What would you do?
ps: I can't post images
frofro is offline
Old 04-14-20, 06:18 PM
bargainguy
bargainguy's Avatar
Quoted: 516 Post(s)
Liked 310 Times in 191 Posts
Don't buy it. Reasoning: Never buy into problems.
Tern has a horrible record of frame failures on their regular folders. Seems they use the public as a beta tester instead of sound R&D. Not only that, but when the frame failures started becoming more frequent, the company tried to claim the bikes were being used past their design limits and therefore no longer under warranty. Double gotcha.
Now add an electric motor to a frame that has a history of failure. Bad idea. Increases the chance that your frame will split dramatically at any moment. Not the way I want to ride.
bargainguy is offline
Likes For bargainguy:
Old 04-14-20, 07:41 PM
linberl
linberl's Avatar
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times in 288 Posts
+1^^^. If it didn't have a motor, I'd say check the serial number and inspect the bike super carefully. But the added stress of a motor
means you only want a bike with a SOLID frame reputation.
linberl is offline
Likes For linberl:
Old 04-14-20, 08:26 PM
downtube
downtube's Avatar
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times in 17 Posts
Tern's behavior has been horrible. I don't think they can be trusted. Just get a Dahon.
Thanks,
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
downtube is offline
Likes For downtube:
Old 04-15-20, 07:48 AM
termv
Quoted: 20 Post(s)
Liked 3 Times in 3 Posts
I concur with the previously added statements.
+ you would buy AT BEST a bicycle WITHOUT warranty, at worst A SUICIDE BIKE (because I bet with you that you would engage the electric motor to its limit and exert forces on the bike for which it was never designed for)!
If you value your life, STAY AWAY FROM IT!!!!
termv is offline
Likes For termv:
