Dud Schwalbe
Quoted: 1188 Post(s)
Liked 1,154 Times
Dud Schwalbe
In a first for me, since I usually buy Schwalbe, I received a dud Schwalbe Moto-X tyre. Distorted casing and doesn't run straight. Bought online, so they said they'll send another one with my next order, but I can't justify the postage until I get a big enough order together so I'll have to wait to replace it. Buggerit.
Quoted: 4195 Post(s)
Liked 3,837 Times
Every company has their duds every so often. Usually an undamaged tire with a wobbled casing isn't un ridable, although if bad enough certainly distracting. Andy
AndrewRStewart
AndrewRStewart
Is it too bad or only deformated because of wrong packaging? If only deformed temporarly, you may want to try to instal it to any wheel (of corresponding size) and pump it. Leave it couple of days and deflate. Check if the shape went back to normal.
Liked 1,154 Times
Dagnabbit, they didn't put the replacement tire in with my next order. So annoying... especially since with Covid-19 the order took 6 weeks to arrive!
Quoted: 2479 Post(s)
Liked 2,948 Times
If nothing else, you can always use "Dud Schwalbe" as your cowboy alias.
Liked 1,154 Times
I suggest that you contact the company by replying to the e-mail where they promised to include the replacement tire with that last shipment and demand (politely) that they ship the tire separately.
Quoted: 836 Post(s)
Liked 1,059 Times
They, presumably, sent you a defective tire and are obligated to send you a replacement at no extra charge. If this is the case I wouldn't do business with that company again.
Quoted: 5888 Post(s)
Liked 3,471 Times
I have a schwalbe tire that simply blows off the rim once the tire is pressurized. It just has a bad kevlar bead. It happens.
