Go Back  Bike Forums > Bike Forums > Beach Cruisers
Electra Cruiser 1 Brakes
Beach Cruisers Do you love balloon tires and fenders? Do you love riding the simplicity of a single gear and coaster brakes or a single gear cluster? Do you love the classic curves in the tubing of a cruiser that takes you back to the 1950's and 1960's, stylistically? Here's your home! Welcome to the Beach Cruisers and Cruisers forum!
Old 06-21-20, 12:53 AM
k9nny
k9nny's Avatar
Bikes: Electra Cruiser 1 (tall)
Electra Cruiser 1 Brakes (LEJOG)
Hello everyone, I have an Electra Cruiser 1 Tall, added a Minoura rack and a Drifter Plus saddle. She's looking good (tried to post an image) and all set to cycle LEJOG next month. I'd like to add some extra stopping power if things get dicey. Can anyone recommend a rear caliper brake suitable for use with a bike fitted with a coaster? Do I need to get the drill out, or is there a less invasive solution? Thank you, Kenny.
k9nny is offline
Old 06-30-20, 06:49 PM
OldCruiser
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times in 1,015 Posts
I’d just add a front brake . Front brakes are stronger than rear ones .
OldCruiser is offline
Old 07-01-20, 08:35 AM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
As Kirby999 said just add a front brake. The coaster should easily lock the rear wheel and at that point you are using the maximum braking possible. Roger.
rhenning is offline
Old 07-01-20, 02:23 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
& you can fit a drum brake hub front wheel too .. they're close to zero maintenance.. retrofit well..
fietsbob is offline
Old 07-09-20, 09:17 AM
The Old Peddler
The Old Peddler's Avatar
Bikes: Currently 4 Electra's : 3 Cruisers and a Townie. also 1 mutt bike
Quoted: 11 Post(s)
Liked 38 Times in 13 Posts
Yes, a front brake is the best solution for more stopping power. You may need a long reach caliper so check the specs before you buy. It should bolt right on, no drilling.
The Old Peddler is offline
Old 07-19-21, 07:02 AM
MrWasabi
MrWasabi's Avatar
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 124 Post(s)
Liked 51 Times in 36 Posts
I'm looking to add a front brake to my Electra Cruiser 1 as well. OP, which brake set did you go with? Any AIO kits out there with the lever and cable included or should I just go ala cart as I want a good lever for my cruiser bars?
https://www.amazon.com/Tektro-Calipe.../dp/B00BLM3TZO
Thanks.
MrWasabi is offline
Old 07-19-21, 08:04 AM
OldCruiser
Quoted: 267 Post(s)
Thanks.
That’s the brake I used on my Electra C1’s.
The levers in the kits aren’t as nice as ones you buy separately.
Likes For OldCruiser:
Old 07-19-21, 08:19 AM
MrWasabi
MrWasabi's Avatar
Quoted: 124 Post(s)
Thanks for the input,
What lever should I get for the Cruiser 1 bars? I'm eyeballing the Tektro short reach ones.
https://www.amazon.com/gp/product/B0...AVQ4OOHG&psc=1
MrWasabi is offline
Old 07-19-21, 01:01 PM
OldCruiser
Quoted: 267 Post(s)
that’s the one I used . I also used some koolstop salmon pads I had laying around that seemed to work better than the ones that came with the brake .
Old 07-19-21, 01:05 PM
MrWasabi
MrWasabi's Avatar
Quoted: 124 Post(s)
Thanks for the advice. Yeah I have the kool-stop pads on my other bikes. They are great and I'll probably get a set for the cruiser too..
MrWasabi is offline
