Squealing disc brakes
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
So my sram disc brakes on my gravel bike have started to make a lot of noise. So the other day, I cleaned the rotors and de-glazed the pads. I went out for a ride yesterday and they quickly started squealing again. The bike and pads are new as of last November. A rough estimate of maybe 1000 miles on them as I mainly ride once on the weekends and indoors during the week. I have no idea how long disc brake pads last. I ordered new ones so hopefully that will resolve the issue. Is there anything I’m missing or are the brake pads just finished? I didn’t measure the wear when I removed them.
Quoted: 667 Post(s)
Liked 529 Times
I've had to deglaze rotors as well. Take the rotors off the bike, clean them with a solvent, than take a sander with 220 grit garnet paper to both the rotors and the pads. Just a light deglazing.
makes everything like new.
Oh, you probably know this but never touch the rotors or pads with your fingers. Even skin oil can cause them to squeal. Chain lube = disc brake death. If the pads got oil on them time for new pads.
Quoted: 6882 Post(s)
Liked 10,873 Times
It's easy enough to figure out whether the noise is coming from the front or rear brake; it's probably the front. If cleaning hasn't worked, replace the pads and that will probably solve your problem.
Brake pad life depends on many factors, so there is no set lifespan.
Quoted: 151 Post(s)
Liked 42 Times
definitely the front brake. Ordered new pads
Quoted: 3352 Post(s)
Liked 1,054 Times
Make sure the caliper is holding the brake pads absolutely square and flat. Is there the same amount of spacers on both caliper mounts. What I am saying is this is akin to the fact that rim brake pads need some toe in to not squeal.
Quoted: 151 Post(s)
Liked 42 Times
biketampa Side note....are you Bike Tampa, as in History Bike Tampa?
haha no. I don’t know what history of bike Tampa is. I don’t even live in Tampa anymore. I created the username when I lived there
Quoted: 151 Post(s)
Liked 42 Times
I’m still baffled on these brakes. I replaced the front brake pads. Also cleaned and sanded the front rotor just to be sure. Went for a ride. Really bad squealing. I checked the bolts that hold the brake on the fork and they were tight. I’m going to check other bolts.
Quoted: 667 Post(s)
Liked 529 Times
What type of pads? Resin or semi-metallic?
Quoted: 151 Post(s)
Liked 42 Times
resin. I’m just surprised it was seemingly almost worse after. I maybe was expecting a little noise as I was braking them in but it was very loud. I’ve never had such issues with brakes. I did check the bolts holding the rotor and they were fine. The thru axle wasn’t loose at all. It seems too loud to be something like the brake lever.
Quoted: 667 Post(s)
Liked 529 Times
The resin ones are typically the quiet ones.
Don't know what to tell you. Usually the sander trick works wonders. I'm sure you realize any bit of oil on the rotors, even from your fingers, can cause squeal? Alcohol or brake cleaner and lots of clean rags when messing with rotors.
Quoted: 151 Post(s)
Liked 42 Times
Quoted: 151 Post(s)
Liked 42 Times
Timely subject. Just wait until the calipers won't release from the rotors. It is coming, I promise you. 4 fricking bikes this week with Sram hydro brakes with this problem. 4 of them! It is just nuts.
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
I had squealing like a turkey with my SRAM Force Hydros. I just recently got fed up with it and replaced the SRAM/Avid rotors with some Shimano RT-70 rotors and no more squealing.
Quoted: 427 Post(s)
Liked 339 Times
I find rotors with an aluminum spider tend to be stiffer and less prone to squealing; not sure what you have...
Semi metallic pads chirped when its wet out, (I don't go fast) the Organic compound Did not, once I bedded them in..
[Avid BB7 Mtn, Kool Stop Replacement pads]
Chirping brakes work better than ringing my bell on the MUP..
