Dahon headset wobble solved...
Sprint the hills!
Bikes: Klein Q-Pro w/Campy, Dahon MU P8
Since I purchased my D7 (from private party) there has been a slight wobble seemingly coming from the headset. I searched the Dahon forums and tried the fix suggested but that didn't work so I gave in and took it to the LBS that is a Dahon dealer. In less than a couple of minutes he had the problem solved! It was a simple adjustment (tightening) of the clasp that secures the handlepost. My D7 now rides solid and smooth, no wobble!
Bikes: "Hildy", a Novara Randonee touring bike; a 16-speed Bike Friday Tikit; and a Specialized Stumpjumper frame-based built-up MTB, now serving as the kid-carrier, grocery-getter.
Quoted: 11 Post(s)
This is a common problem with Dahon handleposts. On the advice of someone from this forum, I carry a tool to tighten it up periodically.
Now if I could only figure out how to tighten the frame hinge joint without making it difficult to fold.
Tour Journals, Blog, ride pix
My bands:
My bands:
- Uke On! - ukulele duo - Videos
- Ukulele Abyss - ukulele cover videos - Videos
- Baroque and Hungry's (Celtic fusion) full-length studio album Mended.
- Artistic Differences - 8-track EP Dreams of Bile and Blood.
My 2007 MuSL has had chronic headset wobble from two sources. First, the white plastic clamp adjustment bolt loosens on its own, but locktite fixes that for a year or so. Second, I've had to replace the headseat bearings twice. The first time, I let it go too long and the bottom sealed bearing blew completely. It made for a very sloppy ride, downright dangerous. The second time a year later I caught it sooner. Both my local bike shops had the right bearings in stock, even the one that doesn't carry folders. Crane Creek 1 1/8" Z6 Z2 or something like that.
Watch those headsets! You can distinguish headset from handlebar lock by tightening down the handlbar clamp, popping the handlebars back up, tightening in the front brake and looking for wiggle in the headset area.
Good luck, all.
Good luck, all.
dahon headset
Did you looked at the Cross Creek 40-Series – ZS44/28.6/H8 | ZS44/30 – Short Cover – Complete – Black – BAA0075K ?
Jenson has them at around $45 (US dollars plus shipping). There are also the Litepro H73 headset offered by Thorsten USA and descriptions on how to perform this replacement.
55+ Club,...
Bikes: 9+,...
Quoted: 1111 Post(s)
Liked 843 Times
2008 Mu (used) wobbling big time.
2008 Mu (used) wobbling big time right now.
About a month ago, took it to LBS, they said the headset wasn't part of the old recall for failed hinges/headsets but I didn't ask them to tighten it up.
I'm so worried about frequent loosening and being unable to do it myself and having to schlep it 10 miles each way to the only Dahon dealer in my area.
Any 2022 recommendations for fixes?
Thanks.
amy
Thanks.
amy
Quoted: 461 Post(s)
Liked 566 Times
Thanks.
amy
Thanks.
amy
crane creek headset
Good to know about Jenson. I'll look for other sellers on amazon and ebay for the Crane Creek option. if my local bike shop does not carry the The Litepro H73.
And there are online instructions (not allowed to post URL) and of course there are video instructions online as well.
Quoted: 461 Post(s)
Liked 566 Times
Quoted: 461 Post(s)
Liked 566 Times
FYI & FWIW this, the Litepro H73, is what a standard folding bike headset looks like. Two hard washers or rings, two cups with removable bearing cartridges and a crown. Four bucks in my parish.
