Just bought a Trailer... need a hitch
I got a smoking deal on a floor model Baby Jogger switchback trailer/jogger. It was missing the manual, and when i got home and looked it up i realized its missing the hitch that attaches to the bike. there was no box, and it was the only one they had in stock..
babyjogger.com doesnt appear to have the hitch in their online store.
any suggestions?
Thanks
Bill
any suggestions?
Thanks
Bill
To know for sure, I'd need more details on the draw bar. However, generally speaking, the Burley round bar or square bar fits many child trailers and works flawlessly with the Burley forged hitch. I have a Bell child trailer and converted the clamp on hitch to the Burley round bar.
Bikes: Raleigh Glacier MTB/Commuter. Cannondale CAAD5, Windsor Timeline fixed gear
Definitely would help to post a pic of your attachment point. I bought a trailer that was missing a hitch for $25, and ordered the hitch off amazon for $9 BEFORE I even backed out of the ladys driveway after I bought the trailer.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
You will find a picture of the hitch in this online pdf manual for this trailer........
https://www.babyjogger.com/PDFs/Switc...structions.pdf
The hitch can be replaced with a call to their customer service @ 1-800-241-1848
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
I looked at the manual Nightshade provided a link for. I would think the Burley square bar and hitch would work. It's a proven design that's easy to replace if you need more than one hitch, it gets damaged, etc. Personally, I'd go with the Burley over the factory hitch. I've pulled well over 200 pounds with mine and it held up fine.
In the right lane
I did the same thing last year with my Instep trailer. I worried that the stupid chainstay clamp just wouldn't hold or would tip me and the trailer. I bought from the same outfit you did. My only problem was that the Instep had a square pipe and the flex connector is round. However, it has held up for over a year and twice weekly trips to the grocery store.
Mine originally had the chainstay clamp. It held fine, I just didn't like how it chewed up the paint on my chainstay. Also, when I tried to use it on my Raleigh 20, it didn't work too well because the small bike wheel puts the hitch arm too close to the ground (the clamp sits below the level of the rear axle), thereby tilting the trailer passenger/s forward. Using the Burley forged hitch, I can put the hitch upside down on my R20 and the hitch arm sits high enough (above the rear axle) so the trailer is level.
In the right lane
Sounds like you bought the round connector for a square pipe. I'd bet the square connector would have fit in your square pipe better, just a guess though.
And it still looks good.
Great system when you have to lay your bike down too.
Industrial Air tool quick disconnect couplings and a short section of rubber hose
is what Bike Friday uses for their suitcase trailer fitting.. works well.
I went the free route, and got a warranty replacement on the hitch.... the package showed up yesterday.... with a big hole in it... and no hitch.....
one phone call later, another is on the way.
nw commuter
Bikes: trek antelope, trek 3900
It's simple to get two hose clamps, a short length of pipe plus a male pneumatic quick release coupling to create a new hitch right on the chainstay, I prolly spent more money getting a piece of hose fitted to the female quick release than on the brass parts. If your hardware store doesn't have thick enough hose to press onto the female quick release, wrap some cut-down spokes in electrical tape and place them into the hitch hose to increase stiffness/reduce trailer oscillation.
Pneumatic hitch post
Pneumatic hose wear post
Pneumatic hitch fix post
i got my hitch. definitely thinking about building my own. this thing is gigantic. but it was free, and I wanted to at least try the trailer with it. now to just get my daughter to want to ride in it.
nw commuter
Matchpoints,
Sure, I'll try to get some pics posted soon. In general, I take a 4" segment of copper pipe that will fit a female threaded male pneumatic connector. I wrap the ends of pipe with a bit of inner tube and electrical tape to protect the enable on the frame, this includes putting a strip of inner tube beneath the hose clamps around the chain stay.
nw commuter
Matchpoints,
