Clip less pedals for total Newb
I have just recently started biking for exercise and commuting to work 15 miles RT. I am considering getting clip less pedals, I am looking at the Shimano Pd-m520 or the 540.
Is there any significant difference between the two, should I just get the 540 right out of the gate? Any advice to keep from falling, or is it a right of passage? I'm 6'6" and on top of a bike it's a long way down LOL.
Thanks
Thanks
Sorry, I thought that you were comparing SPD-M520s to SPD-SL R540s. Since they're priced in the same range. I realized after re-reading it that you were referring to the $100 SPD-M540s.
WALSTIB
Lord have mercy if you started with toe clips first. I had the hardest time converting my brain from pulling my foot back to twisting foot sideways. Luckily you will more than likely be going slow if any problemsBecomes second nature in no time.
Quoted: 5 Post(s)
Liked 11 Times
I switched to clipless from toe clips about 4 years ago. I love them for street use, didn't take long to get used to them. Can not get comfortable with them on my mountain bike. Might go back to flat pedals. Using Crank Bros Candy-Cs on both.
No, going from flat pedals to clip less.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
If you think that you are doomed to fall over if you use clipless pedals, that increases your risk. (Self-fulfilling prophecy.)
Think positive!
Think positive!
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
Why leave rlatform pedals unless you are taking up bicycle racing??
Not to smart............
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
Thanks
Thanks
As for falling, get multirelease cleats and set the tension on the pedals loose. Then go practice on somewhere away from traffic until you are comfortable with them. It shouldn't take very long. If you really want to learn fast put them on a mountain bike and go off-road. You'll quickly find that you are out of them before you even think about it because rocks hurt to fall on
But to be honest, it's not that hard to learn how to use them. Most people crash with them at slow speeds and when they fail to anticipate stops. Clip out before you get to the stop and you'll be fine. Learn how to do a track stand and you'll be even better.
Stuart Black
Stuart Black
Quoted: 67 Post(s)
Liked 83 Times
Mprelaw said they were $100. I didn't pay anywhere near that at an LBS. Don't listen to Nightshade. He's, um, uh, a little out of the mainstream on this. I would agree with most of what cyco said, except that I do think the multi release are a little unsafe if you ride singletrack or do any climbing, just cause they can release too easily.
Liked 4,217 Times
The easy release of the multirelease is the point for newbies. I usually use the single release type but for someone new to clipless, the multis are easier to use.
Stuart Black
Stuart Black
The multi release is what I was using when I tested the theory that you would automatically unclip after t-boning a car, and before flying over the hood. It worked. Is there a sadist in the crowd that I shold perform the same experiment on other types?
Some people are like a Slinky ... not really good for anything, but you still can't help but smile when you shove them down the stairs.
1st, my Doc says it will help with my knees.
2nd, I may be wrong here, but I thought it works a whole other muscle set by being ale to pull up on the pedal?
3rd, I want to see if I can be more efficient?
I don't do much climbing, I'm in central FL, so not many hills. Thanks for all the advice, I will post back with what I choose after I get back from vacation. Again, thanks for the advice!
I just got some new 540's with cleats for $45 on ebay. Saw them elsewhere online for about 50-60. 100 is a rip-off.
Quoted: 3375 Post(s)
Liked 5,513 Times
Bike ≠ Car ≠ Ped.
How about something with a fat platform? I started with Crank Brothers Mallets with the notion that if I wasn't clipped in right away, I could still pedal safely enough. Pretty important at all the stoplights in town.
https://www.nashbar.com/bikes/Product...12_-1___202530
https://www.nashbar.com/bikes/Product...62_-1___202530
https://www.nashbar.com/bikes/Product...97_-1___202530
My vote among those three would be the first, the Time pedals. There are some others besides those, too.
Ergon pedals are a contour shape, they work well to consistently locate
your foot centered on the pedal, without fixing mechanically.
Quoted: 10 Post(s)
Liked 6 Times
Fair enough. I never would have guessed that a doctor would suggest that clipless would be helpful.
