Need to replace 8 speed cassette
I need to replace my worn Sunrace 8 speed cassette but I can't find any anywhere. I am going to change it with a 9 speed Shimano cassette and get a new 9 speed chain.
I was wondering if my existing chain ring (FSA Tempo) will cope with this, seeing as the new chain will be a tad narrower than the 8 speed chain that's on it at the moment.
Also, will I need to do anything with the shifters to accommodate the new gear (after adjusting cable tension).
Cheers.
Cheers.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Cassette here:
https://www.biketiresdirect.com/prod...speed-cassette
You need to replace your 8 sp shifters with 9 sp shifters.
Maybe rethink this idea.
Likes For trailangel:
Quoted: 2952 Post(s)
Liked 3,106 Times
Every hub I know of that takes an 8 speed cassette will also take a 9 speed. The main thing is whether you have indexed 8-speed shifters--they only have 8 clicks. If it can be set to friction (some older mtb/hybrid thumb shifters and bar end shifters will let you switch between indexed and friction) then it shouldn't be a problem. If not, you'll have all sorts of problems shifting.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Are you also changing shifters? Unless you are using a friction setup, 8 speed shifters will not properly index a 9 speed cassette.
Edit: I see everyone answered at the same time.
Likes For rccardr:
Likes For alcjphil:
Quoted: 1438 Post(s)
Liked 1,092 Times
Likes For dsbrantjr:
Liked 3,106 Times
Likes For JRSheps:
Quoted: 2026 Post(s)
Liked 1,095 Times
Jenson USA has both Shimano and SRAM 8-speed cassettes available and they both work on the same hub and with the same shifters as your Sunrace. Look here: https://www.jensonusa.com/search?q=8-speed+cassettes
Maybe you should bite the bullet and change to 9/10/11? 8 speed is the red-headed stepchild of the bike industry as you are finding out. I guess though you'll always find someone here on the forum pointing you to an obscure manufacturer of one-off parts. I just prefer to stay with Campy and Shimano, especially for drive train parts.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12740 Post(s)
Liked 7,652 Times
Make sure you select the 11-28, 12-23, or 12-26. Some road derailleurs can't handle the other combos shown.
https://www.amazon.co.uk/Sram-Casset...65&sr=8-8&th=1
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I find tons of 8-speed cassettes. They have standard mounting and you can swap sizes and manufacturers. There may be some retuning required when the cassette is not exactly the same as previous, but, if the changes are not extreme, it tends to be slight.
