Flat bar to drop bar conversion: Bridger + hydraulic disc options
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
Flat bar to drop bar conversion: Brifter + hydraulic disc options
Hi!
I have a 2007 hard tail MTB turned into hybrid. It's wonderful, but it would be even nicer if it had drop bars and hydraulic disc brakes.
Thinking through the conversion, there's one thing I'm stuck on:
Is there a Brifter that supports 3 chainrings (alivio FD) and drives a hydraulic disc brake (Shimano preferred, but not necessary)? Brake mounts are IS.
If this exists, I could keep my existing 3x9 setup (or switch to 3x10, if needed) and just switch out the frontend.
Thanks!
Alias5000
Edit: I'm hoping for a fully hydraulic system, not based on cable-actuated hydraulics, such as the Hy/Rd
Thanks!
Alias5000
Quoted: 181 Post(s)
Liked 14 Times
The issues as I see them right now are:
Shimano Tiagra has a 3x lever, but not for hydraulics. 2x levers come with Hydraulics. I can probably live with that, if the pull ratio fits my existing FD - and the inner ring will just not be used.
All hydraulic road disc brakes seem to come as flat mounts now. I have IS mounts on my frame. Adapters appear crazy expensive (CAD$40 per item). Can I use MTB disc brakes with these levers? How do I find out?
I can live with upgrading parts of my drivetrain to 10 speed, as I have a 10-speed cassette flying around and 10-speed road pull ratio = 9-speed MTB pull ratio (don't need to change RD). I'm expecting that the crankset should be fine with 10-speed.
Shimano GRX is a similar story.
Have you considered bar end shifters? I've got a 1x so no need for a front shifter but for the rear I've got a microshift bar end. It works great. For braking I've got the TRP Hylex RS hydraulic brakes, which is fully hydraulic but is brakes only, no shifting.
Here's a page with info on IS to post adapters:
https://analogcycles.com/true-facts-...rake-adapters/
Quoted: 1438 Post(s)
Liked 1,092 Times
I've got just this setup on my daughter's bike. Her hand is simply too small and dainty to work the front 105 shifter so she's got the bar end to work the front derailleur.
Quoted: 181 Post(s)
Liked 14 Times
Disc brakes can be operated with rim brake levers, using either a mechanical caliper or one of several hydraulic calipers, that are cable operated. Juin-Tech makes 2 piston and 4 piston models. The 4 piston models cost a lot more, but they do work better and use a larger, more modern pad. I don't know is the come in an IS model, but they do make post and flat mount models. I have one 4 piston and one 2 piston set.
https://www.ebay.com/itm/Juin-Tech-M1-Mountain-E-bike-Bicycle-Bike-Hydraulic-Disc-Brake-Caliper-Set-Black-/202787747525?redirect=mobile
Quoted: 181 Post(s)
Liked 14 Times
https://www.ebay.com/itm/Juin-Tech-M...edirect=mobile
Edit: I am cycling year-round in Canada. Therefore, I need brakes that survive the salty and dirty environment (when cared for and sprayed down regularly). Hydraulics seem to offer this better than mechanical brakes as it seems and mineral oil seems temperature-stable enough for my use.
I ride year round in Colorado, but I never ride in the wet and never need to hose off my bikes. Compressionless cable housing like Jagwire pro is a must. Both cables are full length, so the only exposure is at the brake caliper. I get more powerful braking than a rim brake, but I don't need it, since I weigh in a 60-62Kg.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
Some combination of Gevenalle, maybe.
If you can't find them all together, which one would you compromise?
Genesis 49:16-17
Genesis 49:16-17
Quoted: 181 Post(s)
Liked 14 Times
Interesting, I've learnt so much from this thread and in this process. Thanks everyone!
Good question! I've spent the past few days on this. With a somewhat heavy heart, reason won and the compromise is: no drop bars. This thread was helpful in coming to an informed decision. I'll get everything else I'm still hoping for (hydraulic disc brakes, hub dynamo, better studded tires), but the drop bar conversion doesn't seem to make sense at this price point. One day in the far future, my all-season commuter will be a gravel bike with Tiagra-level components when it's a justifiable N+1 day :-)
