An issue with the Wahoo Bolt
When hiking even with auto pause off, the Bolt does not show meters climbed/descended. It shows accurately the 'current' elevation, but does not record the ascent/descent.
I know it's not designed for hiking, but the Garmin does this very well, and lots of cyclists also use their computer for hiking. I think it might just be a small software tweak required.
I had posted this on the DCRainmaker site and a member saw the files and came to the conclusion that the Garmin was recording data even when the speed was slow, say 1-1.5kmph, while the Wahoo files showed speed as 0 all the time and hence did not record data at all.
Simple solution would be to either:
1. Allow the software of the Wahoo to record at any speed, or
2. Put in a 'walking' mode which will allow data to be recorded at low speeds
When hiking, with 30-35% climbs, speeds will be low, but my Garmins, earlier the 500 and now the 520 have always worked well.
I know guys will jump on me saying that it is not designed for hiking, but like I said, my Garmins have always handled the hikes very well.
Beyond this, even when cycling, the Bolt shows gain/loss less than my Garmin does.
Quoted: 3240 Post(s)
Liked 2,086 Times
The folks at Wahoo, whom I assume you've contacted ?, would likely go "Oh, yes, OK, lets fix that !", where as Garmin would say "That feature will be in the next model. maybe".
Hermes1
3
03-28-18 05:43 PM
johngwheeler
Road Cycling
22
03-02-18 09:01 PM
