Weather proof/Corrosion proof connectors
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I normally just place connectors near the headlight, tail light, and dynamo. I can normally keep the wires tied up to the bracket that the item mounts to. If you don't need to make a disconnection at these vertical runs of wire, maybe you can move the connectors near the lights?
indeed... it's all a matter of trading off the priorities and making compromises between them.
I haven't thought much about field repairs. I solder the wire in my connector pins and use heatshrink to provide strain relief (i.e. keep them from flexing near the area where the solder has wicked up the wire strands). This, along with good support of the wires, has provided very reliable wiring.
I should say that I've worked with electronics and wiring for most of my professional life, and have seen a lot of failures at connectors. Some were my fault, I have to admit. That was where I learned about the damage from overcrimping a wire in a connector pin or terminal lug.
Properly done, wires and connectors can be very reliable.
Same with crimping AND having the right tool for the exact thing you are crimping together. Not having the right equipment and skill is ripe for eventual failure there too. In either situation, I wouldn't solder or pre tin a crimp. I have soldered or crimped as required critical equipment professionally. In the regular world where most people are using run of the mill multipurpose crimp kits and an all in one squeeze crimper, gas tight is not an option.
Quoted: 1827 Post(s)
Liked 3,367 Times
Never tin the wire prior to crimping in the contact. This guarantees you will not get a gas tight crimp. And get poor electrical contact as well. If you feel you need to solder the wire to "seal" them do it after crimping, not before. Or just use blocked wire and not worry about it.
One factor was that the electronic device had a volume of air in it. As things heated up and cooled down, it acted as an air pump, pulling in air or water via the wire strands. The device had a "pigtail" of wire that connected it to the outside world. In retrospect, we should have used a bulkhead connector to avoid that sort of problem.... although there are potential problems with that too.
Ahhh... part of the fun of design is finding out all of the ways to get yourself in trouble!
Steve in Peoria
Quoted: 241 Post(s)
Liked 232 Times
Bike electrics is quite a niche area. Economically, it does not make much sense to optimize connectors specifically for such a market. In practice we have to repurpose connectors optimized for something else. That leads to maybe more struggle than elsewhere. To ensure strain relief on a bike, I now start putting a piece of a shift cable into the heatshrink sleeve.
I just noticed the reference to blocked wire. It's probably overkill for bikes, but I have used it on construction equipment... some of the connectors end up under water for prolonged periods, despite the gear not being expressly designed for that. I've seen damage where water did wick up the strands of a length of water, cause corrosion of the circuit board, leading to the failure of the board.
Steve in Peoria
Steve in Peoria
Quoted: 667 Post(s)
Liked 529 Times
Why not use the waterproof connectors I referenced in post 21? don't know if they are rated for submersion but the automotive industry has been using metri pak connectors for decades now. The definitely eliminate the need for separate boxes for protection while the positive retention connectors eliminate the need for external velcro tie downs.
Pigtail connectors and the heat gun solder connectors seem like an excellent DIY solution for people with no soldering skills.
Quoted: 840 Post(s)
Liked 336 Times
Quoted: 980 Post(s)
Liked 580 Times
Silicone Greases
Liked 3,367 Times
Nice to see someone has fought the same issues. Sometimes I feel like I'm the only one who's seen them. A couple of engineers at my company recently retire. Them, myself, and 1 other engineer were the corporate subject matter experts on connector issues. I'm now trying to train up a few others but I doubt I'll get it done before I depart the company in December. I feel sorry for the engineer that will be left. I had a engineer who couldn't believe that water would actually wick thru a wire. I told him he either needed to vent his electronics housing or use blocked wire to stop the water ingress issue he was seeing. He didn't listen and a customer experienced some spectacular failures due to water ingress into the electronics. We are now in the middle of a recall to replace 12,000 units with units that have a GoreTex vent.
I hope someone is updating the guidelines that I've written, but I don't expect it. There hasn't been much respect for technical knowledge for quite a while. People seem to think you can just hire a new, cheap engineer and they somehow know everything. Well, even if management never really appreciated some of the wise engineers that helped train me, I know that I appreciate them!
Steve in Peoria
Quoted: 226 Post(s)
Liked 45 Times
Well. It's been a year. Soldering wires together then heat shrink worked. I ride my bike daily in all kinds of weather (but not in a coastal area). This is the first time I haven't had to fiddle with my connections for a year.
I wanted a removable connection from the dynamo to the lights and the Sinewave phone charger but figured that if I really needed to remove wires I could just snip them and start again.
I've tried various connectors over the years and covered them with grease but they always seemed to have some issue. Probably over sensitive to the low voltage involved in a dynamo hub.
All the responses were very enlightening (being an engineer myself working with control systems) .
I feel like a semi-idiot for fooling around with aluminum connectors before.
Likes For boomhauer:
Quoted: 1188 Post(s)
Liked 1,154 Times
Been using these for a few years now, cheap and work well. https://www.ebay.com/itm/171866680184
Quoted: 840 Post(s)
Liked 336 Times
Depending on a bike I have used the Schmidt coaxial connector or variants of 2.8mm spade connectors. Off the cuff : One should not use the dynamo voltage as an excuse for poor workmanship.
Bikes: Litespeed, O'Brien, Specialized, Fuji
Quoted: 18 Post(s)
Liked 15 Times
Stuffing a connector with Nyogel 760G seems to be what car makers do to their connectors, so makes sense to me. I just use the stuff on flashlight threads. Nyogel is incredibly expensive if you try to buy it by name, but you can get the exact same Nye product rebranded as Ford/Motorcraft XG-12 electrical grease for about $15 for a 3oz tube. It's a synthetic PAO grease, not silicone.
The previously linked article about dielectric greases:
https://support.newgatesimms.com/cho...tor-lubricant/
sounds like Nye-speak, but also interesting is their advice to NOT use silicone electrical grease:
https://support.newgatesimms.com/not...al-connectors/
