IS52 Crown race - which way is up?
Bikes: Fuji Track Classic, KHS Flite 100, All City Big Block, Foundry Valmont
Trying to get my headset together. Did I install this upside down? It doesn't look right when the fork is installed into the headtube.
Bikes: 2024 Specialized Tarmac SL8Pro, 2022 Specialized Epic Evo, 2021 Framed Alaskan Fatbike,2019 Trek Emonda SL6 Pro, 2018 Trek Stache 9.7, 2013 Specialized Roubaix SL4 Expert, 2009 Ritchey Breakaway Cross, 2016 Lynskey ProCross, 2008 Trek T1000 Tandem,
Quoted: 18 Post(s)
Liked 5 Times
You've got it on the right way but it should be pushed down more so that it's bottomed out on the fork. Then the fork will insert more into the head tube and take away that gap.
Any Ideas?
Quoted: 18 Post(s)
Liked 5 Times
- the gap I'm looking at is between the lower headtube and the blue seal on the crown race. I assume the seal is supposed to be further up into the headtube to actually seal something? That would require the lower bearing to move further up into the headtube. I assume the lower bearing seat is machined and cannot be pressed further into the frame.
Any Ideas?
Any Ideas?
Are you sure you have the bearing in the right way? The relief or chamfered edge should face the crown race. That's the only thing I can think of. Otherwise you have the wrong bearing thickness.
