Niner RLT 9 RDO Build
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I have to decide on gearing soon and since there is no problem that can't be solved with a sufficiently large spreadsheet...
Values are gear-inches.
Shimano doesn't support 11-speed GS mid-cage derailleurs with anything above 32 teeth but plenty of guys are running SRAM 11-36 without problems. I may have to try this.
-Tim-
-Tim-
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Too lazy to add labels. Values are gear-inches.
[IM G]https://www.dropbox.com/s/2fjebi56vhp4wwc/gears.001.jpg?dl=1[/IMG]
[IM G]https://www.dropbox.com/s/ip8dc7vhphxqsrg/gears.002.jpg?dl=1[/IMG]
-Tim-
-Tim-
https://www.bikeforums.net/fifty-plus...road-bike.html
I ended up getting a 46/30 IRD Defiant (with 11-32 or maybe 11-36 back). Praxis has a 48/32 you can change out to 46/32...I think FSA now has listed a 46/30 as well.
- Soli Deo Gloria -
Liked 736 Times
Depending on what you want.... I thought the std Ultegra compact was too tall a gearing on both ends. I also thought the Shimano CX50 46/36 gearing was too tall on the bottom end, at least for any kind of bagged riding....Which brings me to this great resource over in the 50+ older sub on BF:
I've seen that thread. It is excellent.
Is the FSA 46/30 on the shelves yet?
The 24mm Shimano flavor bottom bracket is already on the bike though and I'm going with an Ultegra compact 50/34 for now.
Gearing may change once the bike gets into the real mountains and the Sugino 0X901D Compact+ looks super nice. I think it is a 24mm spindle, maybe, and it matches my frame colors. Sure is pretty...
-Tim-
- Soli Deo Gloria -
Liked 736 Times
03-21-17
Arundel Dave-O cages went on to check fit and just as quickly came off for safe keeping. These are the only carbon cages approved by Gravel Cyclist.
The M5 cage bolts supplied with the Niner frame looked to have smaller diameter heads than most of the bolts I've seen in the past and fitting the cages confirmed - they seemed to want to pull through the holes in the Dave-O cages. I didn't risk it and briefly toyed with the idea of buying Proti titanium bolts. It's lent and so I settled for four (silver) washers from my bolt bucket.
Every garage should have a bolt bucket.
-Tim-
-Tim-
small fussy note on your bottle cage bolts...the bolts that came on my stigmata were standard head allens like that, and i noticed they often stopped the bottle going cleanly back into the cage while i was riding (the bottom corner of the bottle hitting the allen head).
i replaced them with domed head bolts and the (small) problem is solved.
- Soli Deo Gloria -
Liked 736 Times
Thanks for the advice.
It is a concern and I'm hoping to find button head bolts like the Proti M5x16 but for less than $7.15 each.
The bike won't be rideable for a while and so there's lots of time to figure it out.
-Tim-
- Soli Deo Gloria -
Liked 736 Times
Right... er... Correct!
It's just holding the fork on for now. Actually that's a super nice Nitto stem but it doesn't fit the bar going on the bike. I flipped it up last night to make it look extra ridiculous.
I've word out in the local community for different length loaner stems so I can dial in fit before ordering the correct size. The final stem will be the Niner RDO part to match the rest of the bike.
-Tim-
-Tim-
- Soli Deo Gloria -
Liked 736 Times
I've got some silver button head bottle cage bolts but they're M4, not M5. They came with some cages I got from Wiggle.
If you're around the Silver Comet closer to the Powder Springs or Smyrna end on Thursday late afternoon/early evening, I'd be happy to meet up and give you a couple pairs.
What size stems are you looking to try?
That's very generous of you.
I stopped by Home Depot and Lowes tonight in that horrendous thunderstorm and the cage bolts are all set. It turns out that the factory bolts will not allow a bottle to slide in easily at all and so it has to be silver button head bolts.
The stem needs to be a 1 1/8" steerer, 31.8 bar clamp and preferably 6°. I've got a 110mm loaner lined up but would like to try any other sizes, 100 and 120 especially.
-Tim-
Bikes: 2015 Redline Conquest Elite; 2014 Fuji Tahoe 1.1 27.5er; 2006 Scott Speedster S30 (sold); 2001 Specialized S-Works CX; 1990 Trek 750 (sold); 1999 Bianchi Volpe; 1988 Bianchi Campione D'Italia.
Quoted: 131 Post(s)
Quoted: 18883 Post(s)
Liked 10,645 Times
I'm using the SRAM 11-36 on a 50/34. It's nice to have the gearing when you need it, but some of the jumps between cogs feel huge. I would have preferred an 11-32 but couldn't find one locally when my wheels arrived.
Sunshine
Quoted: 10902 Post(s)
Liked 7,393 Times
Get 2 cages on a bike and thats .7-.9oz weight saved over multiple Ibera cages!
- Soli Deo Gloria -
Liked 736 Times
https://www.jensonusa.com/Niner-RLT-9...?cs=Silver/Red
The Stigmata is such a nice looking bike. Brake hose routing inside the fork is a really nice feature.
This build is helping me learn patience, and patience is more valuable than any bike.
King Cages are nice too.
I also ride fixed gear and sometimes just having gears at all is a treat.
-Tim-
Sunshine
Liked 7,393 Times
Liked 10,645 Times
- Soli Deo Gloria -
Liked 736 Times
03-24-17
Cassette was installed.
American Classic 29" MTB Race are essentially mountain bike wheels but accept Shimano and SRAM road cassettes natively. Those more knowledgeable than I report that versions with the letter "D" stamped on the freehub and newer will do so - just bolt on your favorite Shimano or SRAM road cassette and ride.
If the information given is correct then these wheels are good-to-go. Post here or send me a PM if you know anything about the numbers on this freehub.
The cassette is a SRAM PG-1170 which equates to a Force groupset. This one is the low geared 11/36 flavor.
The cassette did indeed slip right onto the freehub. No spacers were needed. The photo below shows how it looks before the 11 tooth sprocket and lockring were installed.
A dab of grease was used on the lockring threads and it was hand tightened using a standard cassette tool.
The lockring torque spec meant that a 3/8" drive torque wrench was needed. I had neither a 1 inch, 3/8" drive socket required for the lockring tool nor a 3/8" to 1/2" adapter for the socket I did have and so had to execute plan C, a socket designed for automotive sending units. It worked just as well.
Torque spec is etched into the lockring itself, 40Nm or about 29.5 ft lb.
I'm not used to cassettes this big. It looks comical IMO.
-Tim-
-Tim-
- Soli Deo Gloria -
Liked 736 Times
Maybe its paranoia but I've been worried about how the front derailleur will mount.
Ultegra Di2 front derailleurs only come in braze-on models (that I know of) but the frame has no braze-on mounts. That means a clamp has to be used and its positioning relative to the low bottle cage mounts on the seat tube is a concern.
How can something as simple as bottle cages cause so much trouble?
The cage mounts are low enough that the clamp clearly has to go between either bolt and that means the clamp has to be thin enough to fit between the frame and the cage. Those Shimano clamps are so thick that they sometimes rub the tires on bikes with tight geometry. This clearly won't work and they are ugly anyway. The clamp also can't be too wide or sit too low or high or it will hit the one of the bolts.
One has a right to believe that the manufacturer of a bike with a nearly $9k list price would have figured this out and so I set about looking for pictures of how the derailleur clamps to the frame on the Five Star build.
There it is in its glorious ugliness, a garish silver clamp which looks to me to be too thick to allow a nice cage to be bolted close to the frame. I could be wrong.
The good news is that the build pictured uses an Ultegra crank with a 46 big ring. There appears to be plenty of room to move the derailleur clamp up and down on the tube without hitting a cage bolt.
My road bike uses the Parlee carbon braze-on adapter pictured below.
This thing is uber weight weenie but doesn't flex that I can tell. It is also thin as a whisper and might even fit between the cage and the seat tube on the Niner. Just to be prepared however...
Two nylon washers were about 80 cents and who doesn't like looking through the fastener drawers at Lowes?
-Tim-
-Tim-
Liked 406 Times
[IMG]https://gzmyu4ma9b-flywheel.netdna-ssl.com/wp-content/uploads/2017/01/2017-Niner-RLT-RDO-carbon-gravel-road-race-bike08.jpg[/I MG]
[IMG]https://www.dropbox.com/s/26080dq9qe1m6i5/parlee.braze.on.adapter.001.sm.jpg?dl=1[/IM G]
[IMG]https://www.dropbox.com/s/dy34p6h91e4g9o6/cage.bolts.001.sm.jpg?dl=1[/IM G]
-Tim-
-Tim-
Usually you only see low-slung water bottle bosses on dedicated/serious CX bikes, in order to give more shouldering room through the front-triangle for your arm. Take for example the Foundry Flyover, I was looking at this bike for a while, and spotted the same issue. Now I checked and your RDO is not listed as a CX bike but as a gravel bike.
Maybe they were thinking of allowing more clearance for bike-packing bags, which they love to show pictures of on their website....as bikepacking bags and standard water bottle bosses get into fights on medium and small frames.
- Soli Deo Gloria -
Liked 736 Times
Its nice to have options and there is always this...
-Tim-
Bikes: 2003 Raleigh M40, 2015 Raleigh RX 2.0, 2017 Kinesis Tripster A/T
Quoted: 26 Post(s)
Liked 6 Times
This a great gravel bike build to draw inspiration on my own build. I too am selecting niner fork (rigid 29er qr fork). I am now rethinking of doing 11-32 rear cassette instead of 11-36 to work with 46/34 front. My build will also use ultegra di2 shifting with trp hylex rs brakes.
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 3078 Post(s)
Liked 1,631 Times
Mighty tasty bike, TimothyH! Tasty water (Topo Chico) too! Thanks for the thread!!
@TimothyH
Any paint issues during install?
There is a guy on youtube who has gone through 3 frames so far...
sorry can't post the link due to low post count
a quick search for "rlt 9 rdo" should turn up (GlobalTravelCouple)
- Soli Deo Gloria -
Liked 736 Times
I've seen the video with the paint issue. My frame has nothing like that.
The only real defects are visible in the photo below - a small bump and what I initially thought was bubbling around the mounting hole. The bubbling is really just a rough paint edge and the camera caught light reflecting. I have the bike sitting next to me right now and the photo looks look far worse than it actually is.
Everything else is as pictured in post number 3.
-Tim-
-Tim-
- Soli Deo Gloria -
Liked 736 Times
03-28-17
Messed Around with Disk Brake Calipers. There are lots of pictures and this might spill into a second post.
I say "Messed around" because some of what I did tonight will likely be undone at some point and it really was just an exercise in familiarity with the product. Having done countless brake jobs, a few big brake kits and even helped on a custom fabrication job in the automotive world I'm quite familiar with disk brake technology in general. The principals are the same but the parts sure are smaller! This is the first time I've worked on bicycle disk brakes.
The following documents were used:
There were several small bags with a myriad of small parts and so the first thing I did was arrange a well lit work area and several small ziplock bags so that the parts didn't get mixed up or lost. The front caliper is pictured below as it appears out of the box with a mounting plate attached to the bottom.
The note "UP for 140mm" printed on the mounting plate refers to 140mm rotors. This bike will be using 160mm rotors and the plate is reversible to accommodate the larger disks.
A small safety retaining pin keeps the caliper from falling off should the mounting plate bolts come loose. The pin was pulled using small needle-nose pliers - ziplock bags come in handy here. The two 4mm bolts were removed from the bottom of the plate, it was flipped 180° and reinstalled using a dab of blue threadlocker. Torque spec is 6-8 Nm. The pin was then reinstalled. Note that the plate now says "UP for 160mm" on the outside.
The rear caliper comes with no such mounting plate. The Niner frame is designed to accept the caliper without a mounting plate when using 140mm rotors. A Shimano SM-MA-R160 D/D adapter is used to space the caliper an additional 10mm away from the axle to accommodate the larger rotors. There are literally dozens of different adapters and "Answerer of Questions" Chris Wolff @ Niner quickly came up with the exact part number needed.
Additional part numbers for the adapter are in the exploded view linked at the top of this post. The installation instructions are also linked. The process was almost identical to the mounting plate for the front caliper. Again, Torgue spec for the two 4mm hex bolts is 6-8 Nm. The two alloy washers pictured are not used here and were safely tucked into one of the aformentioned ziplock bags.
Here it is with the adapter installed. Notice that I forgot to install the tiny little safety retainer pin into the small hole at bottom right. Doh!
Continued next post...
Shimano Road Hydraulic Disk Brake Dealer's Manual
https://si.shimano.com/pdfs/dm/DM-BR0004-05-ENG.pdf
Another Shimano Road Hydraulic Disk Brake Dealer's Manual
https://si.shimano.com/pdfs/dm/DM-BR0008-08-ENG.pdf
Rear Disk Brake Mount Adapter for 160mm Rotors Service Instruction
https://si.shimano.com/pdfs/si/SI-8NU0A-001-00-ENG.pdf
BR-RS805 Brake Caliper and SM-BH59 Brake Hose Exploded View with Part Numbers
https://si.shimano.com/pdfs/ev/EV-BR-RS805-3852A.pdf
Calipers are BR-RS805 flat mount which were purchased as part of a Shimano bundle along with ST-R785RL Di2 Levers, brake hoses, pads and fluid. Everything came neatly packaged in a single Shimano box. https://si.shimano.com/pdfs/dm/DM-BR0004-05-ENG.pdf
