What budget tools for wiring dynamo systems?
Quoted: 753 Post(s)
Liked 737 Times
I'd like to buy a ratcheting crimper and a wire stripper that will work with B+M and SON wires and connectors. I'm looking at a bunch of options on Amazon but it not clear which tools will work best for the application. I was hoping some one else had success finding an alternative to the high end German tools. Thanks, Woody
Jedi Master
Not sure what you consider budget, but I bought one of these son crimpers recently. Any open barrel crimper should work as long as it has the right sizes for whatever wires and connectors you are using. Cheapest one I found was around twenty bucks, so I figured I'd just get the german one since I was also ordering a bunch of other stuff from germany anyway.
Quoted: 2604 Post(s)
Liked 1,929 Times
I put my last system together with a pocket knife for stripping the wires, and a needle nose plier I already had to crimp the connectors. Hard to get any cheaper than using what you've got!
Quoted: 753 Post(s)
Liked 737 Times
Thanks guys. I'm looking for the happy medium here...
Jedi Master
The son crimper has two slots, 1.5-2.5mm for the insulation crimp and 0.5-1.0mm for the wire crimp, so look for one that has something like a 10-14 awg slot for the insulation crimp and a 16-24 awg slot for the wire crimp.
You can decide how cheap you want to go.
Quoted: 3459 Post(s)
Liked 1,465 Times
Pliers, usually use a long nose one, but the first pliers that my eyes land on is likely to be a good candidate.
Quoted: 103 Post(s)
Liked 28 Times
you can buy an English screen printed version of the SON tool at any ACE, HomeDepot, Lowes, Menards, etc. for around $10.00. I have a few of them laying around and I don't like them. I just finished installing a SANYO hub and B&W lights using this $12 item: https://www.lowes.com/pd/Woods-Multi-Tool/50331069
Jedi Master
Quoted: 753 Post(s)
Liked 737 Times
This is what I'm looking at, but there are a bunch of different models to choose from that look the same to me, even from the same manufacture.
https://www.amazon.com/gp/product/B0...PYCMRIKV&psc=1
I solder and use heat shrink tubing zip ties
a handy thing from Radio shack has 2 alligator clips and a magnifying lens on a base
to hold the 2 things for soldering with pencil ish soldering iron so flux and solder too..
now Schmidt has introduced its own coax plug connectors , I have yet to try..
Quoted: 455 Post(s)
Liked 112 Times
Ah Radio Shack. How I miss them!
Jedi Master
Jedi Master
My new son crimper, some coax wire and connecters arrived in the mail today so I re-wired a tail-light and installed a coax plug on the hub. The crimpers are solid. I'm happy with the purchase.
Randomhead
Liked 3,696 Times
Quoted: 753 Post(s)
Liked 737 Times
28-18 aqg is the size I ended up ordering. It will likely be a couple weeks before I get to wiring a bike. I will report back.
