This Defies Laws of Physics. Can Anyone Explain Chainring Bolt Dilemma?
Bikes: Cannondale Carbon Synapse Road, Cannondale T2000 Touring, Vintage Mongoose IBOC Pro MTB, Vintage Peugeot 12spd racer, Old rusty Schwinn Manta Ray I neglected as a child, Diamondback Haanjo EXP Carbon & Metro, Specialized Roubaix Pro, RaleighSC Tandem
Quoted: 225 Post(s)
Liked 39 Times
I removed the original chainring and guard (2 piece with 4 bolts, each with a thick washer inside the inner guard, and a thin one inside the outer guard) from a 1x9 bike I have, to replace the chain ring with a "narrow/wide" chainring.
Since I didn't own a chainring nut wrench (I ordered on on Amazon, but it got delayed), I went to the LBS and asked to use their tool while I was in the store.
The mechanic there happily did the job for me, and discovered there was space after he tightened the fasteners.
Indeed, the three piece thing was loose and somewhat "jingly," like a tambourine. We both figured the new ring was thinner and I needed new size chainring bolts.
I came home and discovered the old ring was 1/2 the thickness of the new ring. Yes, the new ring was TWICE as thick.
This defies laws of physics. Can anyone explain what is up with that?
Thanks in advance!
Thanks in advance!
Quoted: 225 Post(s)
Liked 39 Times
Expired Member
Quoted: 3648 Post(s)
Liked 5,382 Times
Washers?
Quoted: 225 Post(s)
Liked 39 Times
Quoted: 225 Post(s)
Liked 39 Times
Quoted: 225 Post(s)
Liked 39 Times
I'm thinking of mounting without guard, but I will need new bolts and then the chainline will also be off..
Is there some sort of washer width equation for this?
The thickness of outer guard plus washer is 4mm. So theoretically, I could get 4mm washers and just stick then in there, directly between spider arm and ring...? BTW, the thickness of the new ring is also 4mm.
So, to mount w/o ring without guard, do I need to order new chainring bolts for "4mm" thickness chainring?
Quoted: 225 Post(s)
Liked 39 Times
Could it be that the outer chainring bolt goes through the old chainring holes thus making the old chainring act as an extra washer while in the new chainring, it rests on the edges.
This would explain the play.
Use some vernier calipers or a ruler to measure the diameter of the holes in the chainring.
See if the bolt (outer bolt) goes through the holes in both chainrings.
Kret
Kret
The only difference is the new ring it about twice as thick as the old one...
Really Old Senior Member
Single speed chain ring replacing 9 speed chain ring?
EXACTLY TWICE?
If not, how about some "real" measurements.
What "laws of physics" are being defied?
It's your credibility.
EXACTLY TWICE?
Quoted: 225 Post(s)
Liked 39 Times
1) Replacing front ring on my 1 x 9. There is a chain guard.
2) Old ring is 2.5mm thickness (and, when mounted it is tight with no play), I can ride the bike. New ring is 4mm thickness and when mounted is loose & jingles like a tambourine when struck with hand. The bike, I assume is not ride-able with this loose & jingly setup.
I'm not a physicist, but this does not appear to make sense from a physical standpoint.
I'd like to see pics of both rings on both sides of the mounting holes.
Something has to be different.
Countersunk hole that the chain bolt "sits in" differently from one ring to the other?
Chain bolts backwards or not fully tight. Maybe bolts "popped in" to countersink holes after some usage?
I would expect usage in current state could result in elongating holes over time, depending on how hard & often you use it.
I think defying the law of math makes more sense.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Thanks in advance!
Thanks in advance!
What's a "three piece thing"?
Never mind, I would offer no guesses based on that description.
[+1 on the law of arithmetic.]
Quoted: 225 Post(s)
Liked 39 Times
2) The "three piece thing" consists of: Piece #1-Outer chainring guard, Piece#2- Chainring, and Piece #3 - Inner chainring guard.
Quoted: 225 Post(s)
Liked 39 Times
Indeed, if things defy laws of physics, then they must also defy laws of math.
Hoping this all makes sense...
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
Either:
a) you lost a spacer of some sort.
b) you are assembling it wrong.
Have you tried re-assembling with the old ring?
Likes For Kapusta:
Advanced Slacker
Liked 2,534 Times
Are all of the chain ring spacers the same OUTER diameter? You say that some are thicker than others, but I am unclear whether you mean the length of the spacer or the outer diameter.
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times
Where are you measuring the chainring thickness. I believe many modern chainrings typically are different thickness where they contact the cranskset spider than at the tooth. As to defying physics, I doubt it unless you are pedaling close to the speed of light, in which case relativity might come into play (and affect your measurements in some way I am unaware of).
Where is the chain line right? Mounted on the inside or the outside , of the crank arm ,
or do you have to solve that first?
and in my experience it's been fine to mix chainring bolts and sleeve nuts, of different lengths,
a shorter nut on a longer bolt. so the bolt passes through the nut ..
single nut double length bolt is on my single ring - trouser guard ring set..
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Sometimes the socket side of the chainring bolt does not seat perfectly in the crank. If the front bolts are long enough to connect, you will have play. Whether it is this or a different piece causing the play, something in the sandwich is not seating the way it was before. This would also explain the change in the chain line.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Looks like the bike shop mechanic pulled the ol' switcheroo on you and substituted cheaper, thinner washers. Happens all the time if you don't keep a sharp eye on them.
Quoted: 225 Post(s)
Liked 39 Times
Thanks, all! I'm expecting some short/single gear CR bolts, in addition to the special tool.
I'm gonna try and install the ring w/o the guard. Will report back...
Quoted: 225 Post(s)
Liked 39 Times
Ok, the new single ring is mounted directly with no guard.
Ok. I mounted the single ring directly onto the spider with 4mm (inside width) ring bolts and all is fine. Re- indexed and all gears shift fine, but get some noise on the two biggest cogs.
I'm assuming I'd alleviate this problem by adding 3mm washers in between the spider and chainring to makeup for the spatial disparity inward, that the guard and thin washer allowed...
I thought of adjusting the low limit screw, but I think physically moving the front ring inward would be the best decision...
Please me know your thoughts.
