Garmin 705/ computer interface problem
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
Go to download todays race, and the computer won't recognize the Garmin.
Worked this morning. Normally the Garmin shows up as Garmin/L and easy to open files in Cycling Peaks or upload to Trainright or other websites.
Tonight I get 2 devices , "Removable disc J" or "Removable discLl" Neither will open. Properties show 0 KB
I get messages I need to format drive L, which I don't want to do.
I've rebooted, unistalled the drives, downloaded drivers from Garmin.
WTF?
WTF?
You could get lost and die.
You could hit a tree and die.
what message do you get when you try to open it ? is it the format message?
did you do any updates between the time it worked and stopped to either the garmin or the PC
have you tried a system restore assuming you have windows
Bikes: Giant Defy 2
Sounds like the fie system has corrupted itself. Have you tried doing a soft reset yet and then plugging it back into the PC?
Bikes: Madone 6.9 w/ Record Carbon, Look KG461, De Rosa
How about the cable? Did you try a different cable or move to another USB port? Have you rebooted your PC?
Bikes: Giant Defy 2
I'd say with 90% certainty the first suggestion won't do anything, but the 2nd is worth a try, always possible that a USB port has up and died or the controlled has gone and borked itself
pan y agua
Liked 724 Times
Rebooted several times. Installed and uninstalled the Garmin. Did two system restores moving further back in time.
None of that changed anything.
Now today, the computer is recognizing the Garmin fine, and I can open every other file, but I still can't open yesterday's file. Did another ride today and that file is fine.
I could upload yesterday's file to Trainright (the CTS coaching site) which uses training peaks. But only 45 minutes of an over 2 hour ride shows.
On the garmin itself the data all appears to be there.
At this point I'm thinking something in yesterday's file is corrupted preventing other programs from reading it.
Bikes: Giant Defy 2
merlin: If you can PM or email me the file, I can take a look at it and see if the TCX structure is borked somewhere along the line.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Merlin, look in your history folder, is there a Laps file or folder?
pan y agua
Liked 724 Times
There is a laps file for the ride. I've got average power. speed and time for each lap of the crit in the Garmin,
You mean there is a Laps folder with files like Lapxx.dat? One of the lap files is likely corrupted and preventing the TCX file from being created. Try to copy all of the lap files to your hard drive and see if any complain. The one that complains is the problem and will need to be deleted. At that point the next time you plug it in it will construct the TCX. Also you may want to run the disk check tool on it to see if there is any file system corruption.
pan y agua
Liked 724 Times
^ I guess I didn't understand your question. In History on the Garmin, the file shows data by laps (I was using the auto lap feature)
But when I look at it on the computer, the folder "Laps" is empty.
I read back through the posts and realized I missed the part where you said you had a file but couldn't load it. You can read through the direction on my blog at https://www.photoscene.com/kimandstev...rmin-tcx-files to try to fix the file or send it to me (or the other guy, post #7)
bernmart
3
11-06-15 09:45 AM
AK404
6
01-17-14 04:37 AM
sstang13
6
12-27-12 05:02 PM
