I felt brave. So I took the drill to my Cannondale ST
Old 03-15-19, 08:52 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 261 Post(s)
Liked 372 Times in 177 Posts
Some if you may have seen my 1983 Cannondale ST with a problematic shifter boss. The boss was riveted to the frame, and they had become loose. Against the advice of others, I drilled the rivets out tonight.
The good news: the frame material is in good shape and should be able to accept new rivets.
So... what do I do now?
mkeller234 is offline
Old 03-15-19, 08:59 PM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 2422 Post(s)
Liked 4,395 Times in 2,092 Posts
Edited to note importance of epoxy as mentioned below.
Epoxy. Install new rivets. Reassemble. Ride.
-Kurt
cudak888 is offline
Old 03-15-19, 09:04 PM
Classtime
Classtime's Avatar
Quoted: 1949 Post(s)
Liked 2,010 Times in 1,109 Posts
My LBS, to be trusted, uses epoxy.
Classtime is offline
Old 03-15-19, 09:13 PM
cudak888
cudak888's Avatar
The panel bonding stuff that 3M sells would hold that shifter mount forever. I don't think it's available in anything but a huge two-part tube though.
-Kurt
cudak888 is offline
Old 03-15-19, 09:30 PM
repechage
Quoted: 3464 Post(s)
Liked 2,829 Times in 1,995 Posts
I’m inclined to go two part adhesive and rivets... not hardware store rivets but something from Aircraft spruce and specialty.
repechage is offline
Old 03-15-19, 09:41 PM
CliffordK
CliffordK's Avatar
Quoted: 18376 Post(s)
Liked 4,511 Times in 3,353 Posts
You could probably use the epoxy as above, but back it up with a simple pair of pop rivets. I don't know how well it would recess though. Perhaps you could shape the rivet a bit before putting it in.
CliffordK is offline
Old 03-16-19, 05:35 AM
horatio
Hump, what hump?
horatio's Avatar
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times in 145 Posts
Assuming the residue is adhesive, it looks like there wasn't enough used during assembly. A Monday morning build, perhaps?
Good on ya for manning up!
horatio is offline
Old 03-16-19, 08:44 AM
due ruote
due ruote's Avatar
Quoted: 904 Post(s)
Liked 527 Times in 320 Posts
Mcmaster Carr sells all kinds of rivets incl. stainless. I would try a dry run by riveting the boss to a piece of scrap and see how the head fits. Then proceed with epoxy and rivets.
https://www.mcmaster.com/rivets
due ruote is offline
Old 03-16-19, 09:31 AM
Salamandrine
Quoted: 2317 Post(s)
Liked 597 Times in 430 Posts
Someone has to say it. JB Weld. It's usually the best epoxy you can buy at the local hardware store. Good enough for this app. The adhesive is doing most of the work on this joint. Rivet is basically a clamp for gluing. Even so, belt and suspenders never hurts, and I like the idea of a stainless rivet.
Clean clean clean first. Remove all the old adhesive and abrade the surface until it is fresh and shiny. Glue immediately before it flashes over with oxide. You can't see it, but aluminum starts oxidizing as soon as it is exposed - in seconds.
Salamandrine is offline
Old 03-16-19, 09:42 AM
orcas island
Quoted: 175 Post(s)
Liked 238 Times in 109 Posts
Ditto on the JB Weld endorsement. I once slathered some on the cracked and leaking motor block of an F-150 that I needed to keep alive. It ran leak- free for another 100,000 miles fixed like that! Classy, I know...
orcas island is offline
Old 03-16-19, 10:52 AM
jetboy
jetboy's Avatar
Bikes: centurion cinelli equipe, look hinault 753, Zunow z-1, 83 stumpy sport
Quoted: 814 Post(s)
Liked 331 Times in 186 Posts
you could also tap and just put a screw in. easy peasy- the epoxy would act like lock tight and hold it all together even if the threading is only 2 turns in the thin wall. like above, its really just to hold the epoxy on to dry.
jetboy is offline
Old 03-16-19, 01:06 PM
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 7081 Post(s)
Liked 901 Times in 612 Posts
Kudos for diving in.
seedsbelize is offline
Old 03-16-19, 01:59 PM
stardognine
Partially Sane.
stardognine's Avatar
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times in 468 Posts
Wow, you have cojones of steel (or aluminum, if you prefer). 😲 It looks to have worked out fine though, congrats. 👍 I know my '85 has some fairly primitive looking areas, compared to later years, so I can imagine your first year frame is similar, or more so. 🤔
One of us should grab some pics of stuff, like the rear rack braze-ons, for example. Definitely not like later ones. 😉
stardognine is offline
Old 03-16-19, 02:28 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 261 Post(s)
Thanks for all the advice everyone. I think I will give the JB weld a shot. I’m nervous about the pop rivets because I have no experience with them. The screw idea is tempting for that reason. I may go to a local grainger and see if someone there with know how can help me.
Old 03-16-19, 02:32 PM
nomadmax
Quoted: 1104 Post(s)
Liked 1,825 Times in 878 Posts
I had a Cannondale in the 80s and it had a piece of all thread that went thru the frame that the shifter bosses threaded on to. Or, I'm senile.
EDIT
No, I'm not senile.
nomadmax is offline
Old 03-16-19, 02:33 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 261 Post(s)
Ha! I was afraid... then I worked a ton of hours and became delirious enough to not feel any worry. The swan song of warm weather is pushing me to finish this bike up.
You are correct about the early frame. They didn’t go to much effort to clean up the welds. Either way, I think it’s an object of beauty!
Old 03-16-19, 02:37 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 261 Post(s)
Old 03-16-19, 03:31 PM
cudak888
cudak888's Avatar
EDIT
No, I'm not senile.
As a matter of fact, I'm pretty sure I have a spare of this assembly for someone in need of it.
-Kurt
cudak888 is offline
Old 03-17-19, 02:35 AM
nomadmax
-Kurt
That's a heck of an offer
nomadmax is offline
Old 03-17-19, 04:21 AM
bark_eater
Quoted: 753 Post(s)
Liked 737 Times in 422 Posts
Just wanted to throw in 2 cents. The couple times I used epoxy on aluminum, I was useing West System. Their manual and website have allsorts of techniques and products for allsorts of projects. For aluminum I always used an acid etch as the surface prep. They sell this. They also have a new epoxy called G Flex which I have only used for glueing plastics but I believe would be the choice for this application. "West System" can be bought at "West Marine". I would check "Hamilton Marine" for mail order my self. I am sure that. Aircraft Spruce has more specific Epoxy systems for aluminum aircraft.
Cliff note version: Use an acid etch as part of surface prep for epoxy on aluminum.
bark_eater is offline
Old 03-17-19, 07:39 AM
repechage
The acid etch is to remove the oxide layer, aluminum actually has to be fabricated very soon after cleaning, it oxidizes readily.
Old 03-17-19, 09:51 AM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
Liked 256 Times in 165 Posts
Yes, JB Weld. I too have used it in many applications with great results. Don't get lazy and get the "JB Quick". Use the stuff that takes a few hours to set up. It adheres better.
I would also tap the holes and use flathead stainless bolts (available at most Ace Hardware stores) instead of rivets, unless you go through the trouble of getting some nice stainless flat head rivets from McMaster.
Either way, test fit the bolts/rivets before epoxy application, to ensure the heads are recessed enough to clear the shifter parts.
Hudson308 is offline
Old 03-17-19, 10:09 AM
Chr0m0ly
Chr0m0ly's Avatar
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times in 219 Posts
Terrifying huh?! Taking a power drill to a frame like this! Nicely done!! Looks like everyone's covered your options, so I'll just say good luck, and, you got this!
There's nothing like riding a bike around after you've had it's guts in your hands.
Chr0m0ly is offline
Old 03-17-19, 10:14 AM
mcpastor
Quoted: 15 Post(s)
Liked 4 Times in 3 Posts
Originally Posted by mkeller234
Wow, what a beautiful bike!!! I've owned some early Cannondales too. Love the look.
By the way, I see you're from Canton OH. So am I! Now in KC.
mcpastor is offline
Old 03-17-19, 11:16 AM
stardognine
Partially Sane.
Quoted: 972 Post(s)
EDIT
No, I'm not senile.
Aha, I mentioned seeing one of these assemblies some time back, but noone replied. Probably figured I missed my meds or something. 😁 I'm pretty sure it was in Seattle, and I just happened to go into a bike shop, where one was being fiddled with. 😉
