Miyata 1000 Univega Specialissima compared
Bikes: 1984 Miyata 1000, 1984 Univega Specialissima (frame), 1993 Miyata 1000LT, 1987 Raleigh Ventura, 1935 Golden Sunbeam, Early '50s Columbia Bomber
Quoted: 19 Post(s)
I've seen quite a lot of debate and speculation about how similar the Miyata 1000 and the Univega Specialissima are. We all know Miyata built the frames for both bikes and they were intended for virtually the same purpose. The two bikes were built up with slightly different components (though not all that different) but when you get down to the heart of the bicycle, how do they compare? I recently got a 1984 Specialissima frameset in the same size as my '84 1000, so I decided to find out. First, the geometry. The geometry is exactly the same--same angles, same wheelbase, etc. I did find a few differences in the details. Here is a photo showing the lug windows and the fork crown on the Univega:
The lug windows on the Univega are diamond shaped and the crown has no markings.
In the next two photos, you can see the M-shaped lug windows and the branded fork crown on the Miyata:
The lugs and the fork crowns appear to be identical other than these obvious cosmetic differences.
(continued)
(continued)
Quoted: 19 Post(s)
Here is the most obvious difference I found. On the Univega, the seat stay braze-ons for the rack are drilled into the tubes. (I apologize for the blurry photo.)
The rack mounts on the Miyata are tabs, brazed to the tops of the seat stays.
The cable stops on the right chain stay are different as well. Here's the Univega:
And here's the Miyata:
(continued)
(continued)
Likes For WGD:
Quoted: 19 Post(s)
The chainstay bridge on the Univega has a threaded braze-on:
While on the Miyata, the bridge has a hole drilled through:
Finally, The seat stay tips on the Univega have flat faces:
The Miyata's seat stay tips have concave faces:
That's it. While it's possible the differences in fittings like the rack mounts, etc., are due to Univega providing their own specifications, I think it's at least as likely that these represent routine changes made during production. It would be interesting to hear from other owners of both makes, especially for '84s and '85s.
The serial number for the Miyata is M412XXX, while the Univega is M344XXX. I have no idea what the daily/monthly/annual production was, so I can't tell how much time elapsed between the two frames.
My conclusion is that (for 1984 at least) the frames are for all practical purposes identical. I would love to hear other opinions.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,694 Times
Great "apples to apples" comparison!
Especially because models and specs and components were changing so rapidly at this time.
Not that I think it *really* matters at this level- but I wonder if there were tubing thickness differences as well as the other minor appointments.
The Miyatas were specced with XT- that's the top of Shimano's range, and I believe the Univegas Superbe tech- and although it was the top of Suntour's range- it was not the best choice. But you see they were both applying top of the line technology to their top of the line touring bikes- the same... but different.
Commence to jigglin’ huh?!?!
Quoted: 19 Post(s)
My guess is they were using the same tubing but there's really no way to tell without test methods that are way more sophisticated than I can undertake.
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
(continued)
(continued)
Quoted: 19 Post(s)
The Univega has a few more nicks but the paint is still pretty good on both. Considering they're both 35 years old, they look great. I can't see any obvious difference in the quality of the paint jobs.
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
Nice job WGD. Interesting differences in the cosmetics. It seems likely to me that Miyata wanted to keep a difference to the two, as IMO, the Miyata is much nicer visually. So, I also wonder about any difference, if any, in the tubing between the two.
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Very cool rundown.
I like the univega's rack attachment setup more than the Miyata's tabs.
And the univega's chainstay bridge is better due to the threaded fender mount.
But the miyata's chainstay cable stop and spoon stay caps are nicer.
Nice comparison. I do like the Miyata lug cutouts better. Very cool. As you conclude though, they are essentially the same frame. The '83 models IIRC were even more similar WRT frame details, and the Miyata of that year was Suntour equipped.
Quoted: 19 Post(s)
Not yet. The Univega is just a frame at this point and will remain that way until probably next summer. I have a fairly major move coming up and I'm afraid the domestic authorities would freak out if another whole bike appeared. I plan to build it nearly identical to the Miyata, except I will probably use new rims. I have a pair of original Suntour 36/40, 110mm/126mm sealed bearing hubs though. I am thinking about different handlebars (maybe mustache) but I haven't really decided. But just about everything else (except for a Brooks B-17) will be original stock Miyata--deer-head derailleurs, etc.
Likes For Goofball:
I prefer the hole drilled through the chain stay bridge as it allows a bolt and nut configuration. The threaded fender mount hole on the Univega is spiffy, however I have had the bolt back out of one several times. Had to thread lock it to keep in place. Just a preference that make little difference unless the bolt become rusted in the frame.
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 385 Post(s)
Liked 690 Times
RE: seat-stay braze-ons
I have the exact same burgundy specialissima from '84, as well as a steel gray specialissima from '83.
The one from '83 has tabs brazed on the seat-stays for racks, exactly the same as your miyata.
Generally, the univegas tended to be specced ever so slightly ahead of the curve from the miyatas, especially regarding componentry and frame features.
Did you note any differences in the number of bottle-cage mounts or the styles of threaded mid-fork mount? My '84 specialissima has a brazed-on standoff included in the threaded mid-fork mount.
Quoted: 796 Post(s)
Liked 522 Times
Very cool comparison @WGD, very cool that you have both and from the same year.
I have two touring bikes from 1987 : a Nishiki Cresta GT and a Trek 520 that I want to do a ride comparison on when I get the 520 refurbed but they are different manufacturers so I will be looking at ride and feel more than construction.
Bikes: Centurion Pro Tour ('81), Specialized Stumpjumper ('82), Raleigh Portage ('84), Specialized Expedition ('85), Specialized Allez SE ('85), Miyata Ridge Runner SE ('85.5), Fuso ('86), Novara X-R ('87), Peugeot Chorus ('88), Moots Mooto X YBB ('11)
Quoted: 13 Post(s)
Liked 23 Times
Two years ago I looked at a 1980 Miyata Gran Touring and it had diamond-shaped lug cutouts and a smooth fork crown (like your Univega). I have photos but am not able to post yet (newbie). Maybe the same lugs were used into the mid-80s? (BTW: tubing on a 1980 Miyata Gran Touring was Tange Champion)
Quoted: 19 Post(s)
As for the bottle cage braze-ons: same number and same positions. When I was eyeballing them, it looked like the mounts under the down tube were slightly lower on the Univega. But when I measured them, they were the same distance from the BB shell.
I did spot one more difference while I was looking at this stuff:
I initially thought the fork crowns were identical (except for the cast-in Miyata branding). They are actually quite different. As you can see, the Univega has a much longer tang on the inside, with nice looking circular cutouts. Slight advantage to the Univega on this point. Also, the fender mounting hole goes all the way through on the Univega. The Miyata has the hole only on the front.
^^^ That is a Viva Touring, not a Specialissima. It's a much cheaper bike. Not a bad bike, just a cheaper one.
Happy banana slug
Quoted: 1531 Post(s)
Liked 1,527 Times
In between the Viva Touring and the Specialissma was the Gran Tourismo. If you were to put the Univegas in comparison to the Miyatas, the 1000 was to the Specialisma, the Miyata 610 compares to the Gran Tourismo, and the Miyata 210 to the Viva Touring. Roughly. Actually, my late production '83 ('84 model year) Gran Tourismo has features that the same year Miyata 610 didn't have, like the mid-fork braze ons for the panniers, and the rear rack mount was hidden on the inside of the seat stay, not sticking out behind it.
as-bought '84 Univega Gran Tourismo
It has since been fitted-out my way -- with SunTour barcons, a better seatpost, a Fujita Belt brown leather saddle, VO Facette fenders, new cables, tires, bar wrap, brake pads, a 13-26 six-speed SunTour Winner Ultra freewheel, USB rechargeable LED lights, Blackburn rear rack...
I'm also thinking about using my hoarded set of vintage Phil Wood hubs to build a bomb-proof wheelset...
D'oh! Sorry, too many tabs. This Specialissima.
For sure that's a real Specialissima. '82 I think. Looks like a garage queen. Nice.
Happy banana slug
Liked 1,527 Times
A better option would be to keep eyes peeled for the previous year Univega Specialissima. Those had Gran Compe centerpulls instead of cantis through 1981. The Miyata 1000 had cantilevers from the start, more or less. 1979?
