Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
Lifting rear wheel in sprint
Old 06-21-10, 04:47 PM
bdcheung
Carpe Diem
bdcheung's Avatar
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
My rear wheel lifts off the ground during sprints. What am I doing wrong?
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
bdcheung is offline
Old 06-21-10, 04:48 PM
botto
botto's Avatar
Quoted: 15 Post(s)
Liked 27 Times in 12 Posts
too much weight forward.
botto is offline
Old 06-21-10, 04:49 PM
bdcheung
Carpe Diem
bdcheung's Avatar
Huh. My chest is usually above my steerer tube with my neck/chin above where the stem clamps the handlebar. I feel like any further back and my saddle hits my legs when I sprint--am I doing it wrong?
bdcheung is offline
Old 06-21-10, 06:39 PM
MajorMantra
MajorMantra's Avatar
I find the back more prone to lifting when I'm in a too-high gear - it kills smoothness. Spinning slightly faster and shifting weight back helps.
MajorMantra is offline
Old 06-21-10, 06:48 PM
mkadam68
mkadam68's Avatar
Bikes: 2012 MotorHouse road bike. No. You can't get one.
Liked 9 Times in 6 Posts
I was taught that the nose of your saddle should lightly touch your hamstrings as you sprint. Of course, I think this advice came from BF, so it must be correct.
mkadam68 is offline
Old 06-21-10, 06:49 PM
ted ward
Rice Baker
ted ward's Avatar
poor pedaling technique: pulling up at top of stroke
ted ward is offline
Old 06-21-10, 07:02 PM
grolby
grolby's Avatar
Quoted: 288 Post(s)
Liked 86 Times in 60 Posts
More likely a variation on this, which is still pushing DOWN at the bottom of the stroke, which causes you to rise up which unweights the rear wheel which causes skipping. Pulling up too hard in the middle of a sprint is all but impossible; the downstroke is so many times more forceful that it's more likely to be causing a problem. In any case, pedal stroke is a real possibility.
grolby is offline
Old 06-21-10, 07:46 PM
merlinextraligh
pan y agua
merlinextraligh's Avatar
Quoted: 1447 Post(s)
Liked 724 Times in 371 Posts
+1. Waterrockets wrote a pretty good explanation of this in another rear wheel skipping thread. Worth looking up if the search engine worked.
You could get lost and die.
You could hit a tree and die.
merlinextraligh is offline
Old 06-21-10, 07:54 PM
ridethecliche
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times in 160 Posts
You need to do form sprints and add more high cadence sprints to your training. You're overgearing and under spinning.
ridethecliche is offline
Old 06-21-10, 08:00 PM
waterrockets
Making a kilometer blurry
waterrockets's Avatar
Bikes: rkwaki's porn collection
Quoted: 37 Post(s)
Liked 91 Times in 38 Posts
Yep, most of it is pedaling down through the bottom of the stroke. When you reach the bottom, any down force from your leg results in your hips going up, which gets your center of mass going up. This results in the tire coming off the ground as your cleats and pedals pull the bike up with you.
You can have your weight really far forward if your stroke is correct. Here's a side view of Renshaw and Cavendish taking 1-2 on the Champs Elysees (clip from this video). Cavendish's helmet is almost even with his front wheel:
waterrockets is offline
Old 06-21-10, 09:29 PM
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
Throwing the bike excessively from side to side can also cause skipping.
shovelhd is offline
Old 06-21-10, 09:46 PM
waterrockets
Quoted: 37 Post(s)
Though, when properly controlled, this is a valuable component to a sprint. If I sprint with a well-timed swing, I find I get another 100W on the top end. True though, it can mess up your form and send you skipping along.
Old 06-21-10, 11:17 PM
ridethecliche
Batüwü Creakcreak
Quoted: 229 Post(s)
Hence form sprints in the little ring at 130+ rpm.
Old 06-22-10, 06:05 AM
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
+1. The swing has to come naturally, from the bar push/pull. I was referring to the guys who are trying to emulate Cavendish.
shovelhd is offline
Old 06-22-10, 06:39 AM
bdcheung
Carpe Diem
bdcheung's Avatar
The skipping doesn't happen when I do my form sprints--and those I normally wind up past 145rpm.
If I look at Sunday's sprint, my cadence starts at 93 and gets up to 138.
bdcheung is offline
Old 06-22-10, 06:46 AM
gsteinb
out walking the earth
gsteinb's Avatar
Quoted: 912 Post(s)
Liked 752 Times in 342 Posts
sounds to me like jerky form. I'm pretty far forward here
gsteinb is offline
Old 06-22-10, 06:48 AM
bdcheung
Carpe Diem
bdcheung's Avatar
i wish i had video.
the sprint was also up a 4% grade - which I'm guessing changes a lot and I should have included in my OP.
bdcheung is offline
Old 06-22-10, 06:50 AM
MDcatV
Quoted: 31 Post(s)
WR good explanation. i've found as have others i've spoken to, that rear wheel skip is exascerbated by deep section rims. i assume this a rim stiffness issue.
my natural sprinting position is very much like mark cavendish's (and for you dip****s out there, please note that i'm in no way comparing myself to mark cavendish, only that we're about same size and look similar in sprint position), so i've got my head out over the front of my bike kind of far and low. i notice that when i jump really hard i have a tendency to invoke rear wheel skip, particularly when i've got the deep section rims on and even moreso when sprinting up a hill. if i immediately focus on smooth, the skip goes away. i practice this so that i can largely avoid it when i actually need to sprint.
MDcatV is offline
Old 06-22-10, 07:05 AM
waterrockets
Quoted: 37 Post(s)
Which ring?
i wish i had video.
Yeah, it means you were likely at a lower cadence, which means higher pedal force, so a larger jump when your pedal hits bottom and you haven't let up yet. My guess is that during the race, you lost form a bit and don't have the same stroke you do during form sprints.
Old 06-22-10, 07:22 AM
botto
botto's Avatar
Quoted: 15 Post(s)
how come everybody has a photographer with a decent camera/light/lens but me?
botto is offline
Old 06-22-10, 07:41 AM
kensuf
My idea of fun
kensuf's Avatar
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Quoted: 41 Post(s)
Liked 59 Times in 36 Posts
some of those pictures you posted to fb were pretty good.
kensuf is offline
Old 06-22-10, 07:43 AM
botto
botto's Avatar
Quoted: 15 Post(s)
shhhh.
botto is offline
Old 06-22-10, 09:45 AM
grolby
grolby's Avatar
Quoted: 288 Post(s)
Yes, exactly - I was thinking about WR's posts on this issue in the past.
grolby is offline
Old 06-22-10, 09:56 AM
bdcheung
Carpe Diem
bdcheung's Avatar
more form sprints it is!
bdcheung is offline
Old 06-22-10, 10:15 AM
Dunce
Guest
Posts: n/a
Quoted: Post(s)
I had this problem last year a lot, still do some this year.
I found for me it was this....
*EDIT*
Or perhaps it was at the bottom. Point is I smoothed out the stroke (mostly by increasing cadence) and it's rarely an issue now.
