Replacing Gyromaster hub cartridge bearings
Certifiable
Got a Gyromaster front hub and the 629NK bearings are badly rusted. Need replacements. The axle is fixed to the hub, probably held in place by internal c-clips.
Before I start calling around, can a competent LBS press out the old c-clipped cartridges without damaging the hub?
Where can I buy new cartridges? Called the nearest bearing distributor and the guy I talked to wouldn't try to locate 'em.
Do the replacements have to be 629NK? Would 629ZZ or 629RS bearings work just as well?
Certifiable
Hey Jim. Nothing unusual is visible from the outside.
I flooded the hub with WD-40 a few weeks ago and its still dribbling out. The axle spins freely and there's just enough in and out play to suggest its being anchored internally.
Here's where I learned about the "NK" c-clips: https://www.bikeforums.net/showthread...ridge-bearings
Guess its possible the axle is being held in by corrosion, but I'm thinking the clips are a more likely cause. I could pry out the rubber seals and possibly see if the clips are in there. However, I'd like to be certain I can get new cartridges before damaging the seals.
Haven't been able to locate new 629NK bearings anywhere.
The axle has a shoulder, it won't come out without removing the bearings. To remove the bearing hit the end of the axle with a brass or some kind of soft mallet, you don't want to jack up the threads. With a little luck the bearing will come out in one piece. If the bearing blows apart, knock the rest of it out with a screwdriver and hammer.
Certifiable
Thanks Brian.
Now that I know there's potential destruction involved, its important that I have replacement bearings lined up ahead of time. Do you know if 629Z, ZZ, RS, or 2RS bearings can be substituted for the original 629NR cartridges?
You might find this thread interesting:
Also, trying to pull up the link provided for National Precision was bad, but doing a brief search found this:
https://www.nationalprecision.com/bal...tra_small.html
From what I recall, the trailing letters define the seal types and configuration.
Certifiable
Thanks for the info guys. Looks like the c-clips are more closely related to the seals than the axle.
My reading so far leads me to believe Gyromaster hub cartridges have seals on one side only. Is this correct? 629-2RS double-sealed bearings are much more common; wouldn't they also get the job done?
Just in case anybody will go to this (useful) thread for information: I just pulled apart Sunshine Gyromaster front hub from 1980 Fuji S12-S LTD and found 629 bearings, front rubber seal marked '629 LB', rear metal seal marked '629 Z'. Obviously, they are sealed on both sides. No idea what those letters mean, they do not seem to correspond to modern conventions.
Axle is held in place by some friction and some (optional) rust. No C-clips. Mine took some quick soaking on WD-40 and gentle blows from rubber mallet. Rubber seal from the bearings was quickly and easily removed by one of the 'picks' from set I bought in car parts store long time ago; that pick has 2 angled straight bends in it, and works perfect for application.
I wish I had a bearing puller called Enduro V-Puller (https://www.enduroforkseals.com/id61.html), because one of the bearings is firmly stuck in the hub and I have to simply clean it in place (Other bearing came out with the axle). Will get that puller one day, for next cleaning/replacement.
Well, now that I am trying to take apart rear hub, I have a question.
What do you do if hub, bearings and axle are all rusted together so well that not-so-gentle blows with rubber hammer take absolutely no effect?
I am soaking it in PB Blaster now, hoping that it will loosen it some. If worst comes to worst, I will clean and relube it 'in situ', but I would prefer more complete overhaul...
Aha... thanks... I have pretty much exact pictured setup available in my garage...
But I bet that means that I better have replacement bearings at hand...
And... is't it going to anneal (soften) the axle? After all, I am planning for that thing to be ridden, not hung on a wall...
Make sure that the wheel is on something solid when you hit it with the mallet, like a vice opened just wide enouigh to let the bearing slip out, dont be afraid to hit it hard
Quoted: 17 Post(s)
Liked 39 Times
- Auchen
- Auchen
Big thanks for ideas, guys! I think I will let it soak in PB Blaster a bit, then place it over something solid, and whack it really good. If that will not work, I will just grease bearings as is, and will repeat it with the torch later, when I have replacement bearings at hand.
BTW - front bearings after a treatment of fresh grease feel very smooth...
Quoted: 89 Post(s)
Liked 63 Times
When dealing with Roller Bearings of this type it is better to have the old one to mic because the center hole can be Standard or Metric, the letters behind the numbers refer to the type of seals that are used, ZZ = metal shielded, RS = Rubber Shielded. If it's possible I like to use double rubber shielded bearings for wheels when I can, don't use the ZZ metal shielded in wheel hubs as they don't work good fighting off moisture.
Definitely go with 2RS seals if possible, and 1RS as backup (with the seal side facing out) if you can't find 2RS in your bearing size. 2RS is what most modern cartridge bearing hubs spec. However, it won't affect the mechanics of the hub, strictly the moisture resistance.
I believe that usually they go in with just finger pressure if hubs are clean and lubricated, certainly was in my case. Now, to get them out is a different issue, I would be more interested in some kind of elegant puller to save all the hammering, soaking and torching... Maybe when overhaul happens frequently (once a year?) it would be easy thing to do with finger pressure as well, but it my case bearings were there for 31 years...
Update: soaking in PB Blaster was not very productive, but moving whole setup (2 wooden blocks and clamp) to the concrete floor allowed bearing/axle to come out on the first blow. Brilliant idea about solid base, thanks!
Bad news is that when I tried to knock out other bearing out of the hub(unsuccessfully), it got indexed, and did not come out. For now I lubricated it and called it a day (it works, but is a bit rough), but will need to come back to it later with new bearings in hand, and either puller or a torch to get that stuck cartridge out.
Just for information, rear bearings were of '6200 LB' type.
Huge thanks for help and ideas!
Bikes: many
Quoted: 18 Post(s)
Liked 16 Times
I just did this with a 1990 Fisher Procaliber. It works.
https://www.br00klyn.org/images/parts...4-1991-pg1.JPG
https://www.br00klyn.org/images/parts...4-1991-pg2.JPG
TallRider
Bicycle Mechanics
7
02-16-17 11:23 PM
JonathanGennick
Bicycle Mechanics
3
05-18-10 11:58 AM
