Replacement B tension screw for Shimano Dura Ace rear derailleur circa 2005
Bikes: 05 Trek Madone 5.9, 07 Trek 7.7FX, 09Trek 6700, 09Trek 7.5FX, 15 Schwinn AC Performance Plus Carbon Blue (for torturing myself)
Does anyone know where I can get a replacement B tension screw for a 2005 Shimano Dura Ace rear derailleur?
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
Take the bike to a local ace hardware and then start trying the best screw to make it work. Eventually you will find one and it will be dirt cheap.
Quoted: 5763 Post(s)
Liked 2,537 Times
It's harder to find stainless steel metric screws, so you might have to settle for a black one. But once you know exactly what you need you can hunt for a stainless one on the net.
OR
Go to a bike shop where you have a relationship. They all have decent numbers of trashed derailleurs (some shops save them, some don't) where a replacement limit can be salvaged.
FB
Chain-L site
FB
Chain-L site
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Is there anything special about the ones used on ca. 2005 DA RDs? I have a couple extra Shimano B-tension screws that I'm not using.
I'm guessing that Shimano uses a standard B-tension screw for all of their RDs. I'm going to check out a couple of my kids old bikes that they've abandoned to see if I can find a screw that will work. Thanks for the idea and the offer. I'll let you know.
Quoted: 453 Post(s)
Liked 104 Times
It's an M4 x 12 screw according to the tech docs, so just buy one of these if you don't mind not getting an OEM part (Y-53M-21000)
aka Phil Jungels
Ace has a stainless section, and you can pick whatever length you want... even choice of head type.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,416 Times
Ooh, how cool would it be to be the only kid on the block to have a torx head B-screw?
Answer: not especially
Liked 2,563 Times
It would certainly make it harder for roaming hooligans to mess with your B-tension adjustments. Hate it when that happens.
