Wahoo Bolt or Garmin 520
Quoted: 139 Post(s)
Liked 33 Times
Garmin and Wahoo offer similar features, similar price points, similar quality. Close call. It depends on what features matter to you. https://dcrainmaker.com has in depth reviews and feature comparisons and tables of what models offer what features. I think it comes down to what features matter most to you and which brand offers the best of the features you want.
Bikes: Tarmac, Merckx,TCX, Bridgestone
Quoted: 18 Post(s)
weiser
Bikes: liv langma advanced 1
Just got the Wahoo Bolt (first cycling computer ever) I’ll keep this thread posted on a noobs perspective (and will probably ask for some tips along the way)! Thanks for all the insight everyone! I’m enjoying this forum a ton.
After a number of calls to Garmin support, GS has told me that there is a problem with LiveTrack on the 520 connecting, or staying connected, with iPhones. They claim that a fix for the Garmin Connect app will be coming out soon. They suggested using Cyclemeter, or similar app, for tracking until their fix is ready.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
I think I'm about to return my Bolt.
I didn't realize this about cycling GPS, but they're not really meant for navigation. They're just positional trackers.
I thought they were like nav systems in cars. Input destination, follow the route.
Get lost? No problem.
Want to change destinations? No problem.
Need to turn around and go home? No problem.
But they're not like that at all. Those are all problems. You have to plan the route, upload, download, reload, etc. You have to bring your phone with you anyway. I think where battery life is a concern, I might be better off getting $250 worth of battery packs.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Quoted: 3221 Post(s)
Liked 2,048 Times
The issues with a bike computer trying to do what a car navigation unit will do is an issue of what route is appropriate for a bike ?. It's easy with a car, as ALL roads are likely to be good for a car (unless it's a railroad track or mt. gravel road covered in snow pack), you just need to pick whatever options the unit gives you. With a bike some additional intelligence is required for the unit to know what roads are appropriate, and that's a much harder thing to design, even Google sucks at it, so I wouldn't expect this of a bike unit.
But the units do excel at allowing you to pre-plan a route, then navigate you in areas that you are unfamiliar with and the process to do that is really easy, as is getting the route to the device.
But your call as to what functions are worth it to you.
Certainly all of that is now obvious in hindsight.
Maybe just a bit rueful because I imagined it to be more freeing than it actually is.
Of course, even that is moot. I don't have the time I imagined myself having for this hobby. I'm constrained to the same 20-40 mile loops out my front door. And that's fine--it just doesn't require GPS navigation.
Liked 406 Times
Or less?
Or nothing at all, since I can run Strava from my phone/watch (and if I want to see real time speed without burning through phone battery, I can figure out how to mount the magnet for my Avocet 30)...
I've only used the GPS once since I got my Bolt, and that was only to see how it worked. I did a 40 mile or so loop through the streets of Brooklyn and Queens, going into areas I don't usually go, but am still familiar enough with that I could navigate by sight. What I found is that for the shorter turn by turn I needed in the city it was just too confusing to use. All too often the turn would be indicated when I was already in the intersection, and it wasn't always clear which street to take. It would beep either too far away or too close, and I took one wrong turn even though I thought it was wrong when I got to it. Also, since I created the route myself, I already knew from the map where to go. I said in another thread that I have the map of NYC imprinted on my brain anyway.
That said, I still will use it when I get to unfamiliar areas to follow routes that I've downloaded. I'll be in Copenhagen and Oslo next week and I'll try it there. Which brings to mind another great use. I can take an entire bike monitoring system with me on travels that will fit in the palm of my hand. And I can grab my Assioma power meter pedals too. (and this just reminded me to charge the pedals right now)
Liked 2,048 Times
This is a common issue with GPS unit’s, car models included. The unit just cannot generate a location fast enough for the nav part to keep up with what’s happening real time. I’ve encountered this with car units and recall a bike touring post of some folks using a Garmin 1000 in Switzerland where the unit just couldn’t keep up in narrow streets with a maze of turns.
Possibly in a few years as processor speed gets better at this level.
Liked 406 Times
Bike GPS units are held back due to needing to maximize battery life....maximizing battery life means minimizing power draw which means using as low-a-power CPU as can do the job. I ranted on my Edge1000 because even after the battery-saving measures its battery life sucked and was never even half-of-rated-sticker life IRL. They can make today a wizzo-fast CPU and put it in an Edge--but you'll only get an hour of battery life.
It needs noted that most of the measures that have drastically improved smartphone battery life over the last decade didn't directly come from hardware like new amazing batteries....it came from software measures to minimize usage and throttle things down. Having more computationally powerful CPUs did help, to be fair, because a 2.5gHZ maximum-clock 8-core CPU phone can spend 99% of its time either in Deep Sleep on in 1-core mode clocked down to 1/10 of rated maximum. As opposed to older chips that needed to spend 100% of CPU time at 100% power to do anything.
Processor speed isn't the limiter. It really isn't. As far as narrow street navigation, it will always be a problem. You have minimal line-of-sight to the sky therefore estimated-probable-error is high due to lack of satellites....and in narrow medieval alley-way environs the error in position is larger than the distance between "streets"...making position routing/tracking problematic. It isn't a computing power limit problem, it is a geometry problem.
In almost any ride I do, I wind up deviating from a ride for a bit at some point, and it just gets plain annoying while the little bike computer goes nuts recalculating or warning me that I'm off the route. I much prefer having the route shown on the map and I can find my way to it and how to stay on it. Having a field that one can have on a screen that says "distance to next turn" (or equivalent) is more useful. Then when I get close to that point, I start watching the map.
So, for me, and I realize that YMMV, but I just don't find TbT to be all that useful in actual practice.
J.
The New Yorker took a business trip to the suburbs of Chicago a year or two ago and my colleagues insisted on turning on the GPS every time we got in the car. But even in unfamiliar Chicagoland I was able to navigate just fine without it, and once I looked at a map it was just easy to get around. The car GPS just drives me crazy. The area is flat, the streets run N/S or E/W and are all perpendicular, how hard could it be? To me it is only useful in a truly unfamiliar place, and on a bike taking a quick break to consult a map is no biggie. All that said, I still really like my Bolt.
Quoted: 2493 Post(s)
Liked 738 Times
So, quick question. For the 520; if I create a course on Garmin connect and load it on to the 520 will it show me where the turns are?
I also have the "Openstreetmaps" for my area installed on the device.
Liked 2,048 Times
I don't think routes created in Garmin Connect give you the turn by turn directions. If you create the route in "ridewithgps.com" it will. I create and store all my routes there and it's fairly easy to upload them to the 520. There's a tutorial right on the site. It plays well with Garmin Connect and Strava also, the ride data automatically populates both.
That said, I’ve never tried it on a 520, which generally does TBT OK, just doesn’t do it as well as a Wahoo.
Having used a Bolt as well as a Edge 810 and 1000, the RWGPS interface to the Bolt is very good. The Connect interface to a 1000 is as good. The maps on the 520 are not as refined as a Bolt, the maps and screen of the 1000 is better then a Wahoo. IMO.
Quoted: 1814 Post(s)
Liked 923 Times
I've had a Bolt for couple of months now.
Can't get the iphone app to not crash despite all manner of upgrade, reinstall,
& service contacts. Works for basic functions but can't upload routes, etc.
Still have the Garmin 500- was trying to get a moderate upgrade.
Quoted: 408 Post(s)
Liked 122 Times
I’ve had my Bolt for over a year running the app on an iPhone SE and never had a problem with the app. I don’t use the app very often to download routes but it’s never failed me when I have. The best way to download routes is via WiFi directly from the Bolt.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Koyote
77
07-22-20 11:32 AM
johngwheeler
Road Cycling
22
03-02-18 09:01 PM
