Ultegra 9 spd. triple 39 ring ?
Quoted: 3242 Post(s)
Liked 2,086 Times
I've searched, didn't find anything
I've got an Ultegra 9 spd. system, with the Ultegra triple crank. Maybe the 6500 group, not sure.
The middle ring is done and needs replacing. Odd thing is all the reading I can find tell me this was a 30-42-52 crank, yet I've counted the teeth on the middle ring and it's a 39.
Thus I'd like to source a replacement, but need a ring with the ramps and pins to allow the system to work correctly.
Any thoughts on a source for that ring, appreciated.
39 tooth would be the small/inner ring for a Shimano 6500 double, or really any standard double. Is the current 39t ring actually ramped/pinned? The 39 off a double wouldn't be, it might have a couple cut teeth at best.
9spd Dura-ace had some odd gear combos on the triple, quick googling says it was 53/39/30. So you might be looking for a Dura-ace 9spd middle ring, not sure if anybody else made one.
Edit: Well there you go, that link has a 39t middle. Also this is the Dura-ace ring set, but It looks pretty beat up: https://www.ebay.com/itm/Shimano-Dur...e602:rk:4:pf:0
Liked 2,086 Times
Update:
Photo of the large ring, a 52 tooth in 130BCD and a photo of the crank L arm.
I see 6603, so will try to source that and Yes, it’s a ramped/pinned middle ring. I’ll likely replace the 52 as well, the small is a replacement 26
Ultegra 6600 would be 10spd I think, 9 and 10 should be interchangeable for cranks/rings so you're fine if everything else is 9spd.
Looks like 6600 was the same 53/39/30 setup, you could look for that middle ring as direct replacement. If you throw Shimano 39t triple in ebay you actually get some good results: https://www.ebay.com/sch/i.html?_fro...LH_TitleDesc=0
Liked 2,086 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Maybe try Bike Recyclery
HIGH END Used & Vintage Bike Shop! We stock Campagnolo XTR TA Suntour Parts NIB NOS
Those Shimano 3x9 drivetrains shift so great with the right rings, but unfortunately replacements are becoming almost impossible to find. I just bought one of these to put in my inventory for backup: https://www.rei.com/product/778838/s...130mm-39-teeth
I suggest that you do the same before they are gone. Good luck.
Recently I was in the same situation as you: a worn-out middle ring on a road triple. Although mine was on a Craigslist-purchased bike that was not nearly as in as bad shape as yours. Wow!
So a few seconds later I had a 9-speed Sora unit ordered on Chain Reaction for like $13. Works great. Steel, so adds a few grams, but the middle ring on triples always takes the brunt of drivetrain wear.
Liked 2,086 Times
Thx for that link
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
