Garmin Edge 520 Plus Woes
Quoted: 5 Post(s)
I received an Edge 520 Plus for Christmas, and thus, finally replaced my old Edge 500. Since day one I’ve had nothing but fits trying to get the 520+ to sync and auto upload properly. My devices are:
Edge 520 Plus
iPhone 7
Garmin HR strap (not the premium one)
Giant onboard Ride Sense for Speed and Cadence
I’ve been working with a Garmin tech via Email for almost 2 weeks now to try to resolve these issues. So far I’ve deleted and reinstalled Garmin Connect app on my phone, done numerous checks to verify settings, but still I’m having issues. Syncing with my iPhone seems to be hit and miss. The 520+ required 2 BT connections which was a bit confusing at first.
Also, my riding partner has the same Edge 520+ and when he saves his ride, it instantly uploads to Garmin Connect and Strava. He swears that he doesn’t have to open his Garmin Connect app either. I am struggling to understand how this happens since the Garmin tech tells me that I have to open the Garmin Connect app for this to happen. Even when I do, I still have to manually start the sync process, even though I have AutoSyc enabled.
I’m wondering if anyone else has experienced these issues, and has been able to resolve them? If so, please tell me how you did it.
Thanks,
Ray K
Edge 520 Plus
iPhone 7
Thanks,
Ray K
Quoted: 3242 Post(s)
Liked 2,086 Times
Have you updated the iPhone recently ?.
My Garmin 1000, which initially required multiple attempts at pairing to my iPhone for the BT BLE connection, but once setup, worked fine for 2 years, no longer automatically connects on the basic BT. I have to now do a manual connect and this is after the latest iOS update. I think Apple changes stuff to **** with people and Garmin sure ain’t the best company to keep up with this stuff.
Last edited by unterhausen; 03-13-19 at 11:05 AM. Reason: please don't evade the site censor
Quoted: 6196 Post(s)
Liked 4,810 Times
You didn't use the smart-phone app with your edge 500 did you? So why not continue to connect the 520 to your computer like you did the 500? Garmin's phone apps and even Garmin Express on my computers just cause me more grief than they solve. So I just manually retrieve rides from my devices. Saves me quite a bit of gnashing teeth with the quirks of Garmin's apps that seem to occur at the worst possible moments.
I've got a 520 and now the 520+ and they work like your friend's device -- when I save a ride on the Garmin unit, it automatically uploads it to Strava if my phone is nearby.
Someone else may have better troubleshooting tips, but this is a sequence I'd try:
1. unpair everything, have your phone forget the Garmin on bluetooth. Turn off your Garmin. Uninstall the Garmin Connect app. Leave everything off for now.
2. Update your phone's iOS, reinstall and update Garmin Connect.
3. Turn on the 520, pair it with your phone and let it update its software
4. Pair Garmin with your Strava
5. Try the 520 just with your phone, see if things are working
6. add the heart rate monitor, see if things work
7. Add the speed/cadence stuff, see if problems develop.
Lastly, the 2 bluetooth connections serve two different purposes. One is for all the cycling functions. The other is to send your texts and call alerts to your 520. I never have the second one, for calls and texts, on.
Hope that helps. When all else fails, there's always the manuals.
Liked 2,086 Times
As per the Garmin manuals, print out when possible, it makes for a decent backup toilet paper and that’s about it.
Quoted: 440 Post(s)
Liked 264 Times
I used to have to open the Garmin app before uploading then I bought a Garmin smart watch and the app is now always open. Could your riding partner have one also?
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Long story short, after 2 weeks of back and forth with Garmin, they issued an RMA for a replacement 520 Plus. Hopefully it will work correctly.
RayK
RayK
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Your phone has a setting that allows the Garmin app to run in the background. That will facilitate auto-uploads and further drain your phone battery.
Quoted: 5 Post(s)
Yup, I had that turned on as well. Location on Always, Background app refresh ON, Cellular Data ON. Made no difference.
I should be receiving my replacement 520+ this week. Hopefully this one will work correctly,
RayK
RayK
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Back when I was a Garmin user browsing their Edg1000 forums semi-regularly, there was at least 2-3 threads about broken iPhone/iOS behavior a week.
Liked 2,086 Times
It’s worked perfectly for the 3 years I’ve used the 1000.
Bikes: Enigma Echo Ti, Sabbath September Ti, Airnimal Joey
I have same problems with a Garmin 820+, used to download automatically but is now erratic. If I give it a couple of hours and then pair the device again with my iPhone, it seems to work. I had put it down to issues with the Garmin Connect service..................
Quoted: 5 Post(s)
*Update*
I received the new Garmin 520 Plus and had a chance to test it today on a ride.
The new 520+ was paired with my iPhone 7 per instructions, I had set the Garmin Connect app settings to use Cellular data, and Background app Refresh.
Once I finished my ride, I saved it on the 520+ and observed that the ride uploaded to Garmin Connect (and Strava) without having the Garmin Connect app on my iPhone open.
This is contrary to what the Garmin tech told me. He said that I had to open the Garmin Connect app in order for the uploads to occur. I also confirmed this with several of my riding mates, and they do NOT have to open the Garmin Connect app for the upload to work.
So the good news is that the new 520+ works correctly. The bad news is that Garmin Support Tech didn't know how their products are supposed to work.
I'm going on another ride tomorrow and will be curious to see if this continues to work as expected.
RayK
RayK
Quoted: 4260 Post(s)
Liked 1,363 Times
Garmin Connect Mobile has some sort of "background" process. That might not always be running. So, you might need to run GCM, once in a while, to get things to work. So, the techs are kind-of correct.
Liked 2,086 Times
*Update*
RayK
RayK
Now if I can only get the 1000 to automatically connect to iOS everytime the unit boot.
Bikes: 650b traditional rando, 700c SS rando, 700c fast rando..... plus a mountain, folder, and retired urban track in the basement
Quoted: 37 Post(s)
Bumping this thread.
I got an Edge 520+ to replace my trusty Edge 500 for this upcoming randonneuring season and the road to Paris-Brest-Paris. I'm also experiencing a lot of woe in getting the 520+ to behave like my old 500.
What I used to do with the 500:
Any assistance would be greatly appreciated!
- Create routes in RWGPS. Generally i'd do it by controle or maybe every 100k.... never would make long routes. Also helped the unit load routes faster.
- The mapping page was excellent. A breadcrumb trail with the next cue and distance to turn. All I needed!
- Stop and save files every 200k or so. I'd generally experience freezing and corruption with 300km+ rides, so I got into the habit of resetting every 200 and then stitching files together later.
- Charge on the go with a Gomadic charger.
- It takes FOREVER to load routes, even if they're short. DC Rainmaker pointed this out in his review of the pre-production 520+, and it doesn't seem to have gotten fixed. Would turning off all mapping help with this issue? A breadcrumb is totally fine with me.
- Using .tcx from RWGPS, sometimes I get a full cue sheet as one of the main pages, and sometimes I do not. It will just have "Start" and "Finish" cues. I have to dig into the menus to find the cue sheet, which is not helpful.
- Related to the above bullet, on the mapping page, during navigation it will show me the route highlighted, but sometimes will give me no cue or distance to turn.
- Does the 520+ suffer the same issues with long files? Saved routes / recording data with too many waypoints?
- Can I charge on the go with any regular USB stick and cable, or do I need a specific pinned one like Gomadic?
Santa Claus brought me a 520+ this year and I had a lot of trouble initially. As of late, I just open the Garmin connect on my phone, power up the 520 and take off. Zero issues the past 20 rides.
Quoted: 37 Post(s)
I initially wanted to get a Wahoo, but after reading a lot of the reviews, it seems like it needs to be tethered with your phone. Even if not needs, then maybe it's just simply designed to heavily lean on your phone. One of the things I love(d) about Garmin is that they can be totally stand-alone units. I don't want navigation to fail because I went out of cellular range or something silly like that.
Quoted: 942 Post(s)
Liked 527 Times
Quoted: 212 Post(s)
Liked 83 Times
I have an Edge 820. The first day things were a little tricky. The Connect app on my phone kept telling me that the device needed an update before I could add anything to it, and to check the Connect website. The Edge 820 would tell me to check the Connect app to turn on Wifi. There seemed to be no provision in the app itself to upgrade the GPS's firmware. ...those sorts of oddities.
But then something cool happened: I plugged in my phone to charge, and plugged in the Edge 820 to charge. While they were charging the phone app sent an update over to the GPS. The GPS, once fully charged, displayed a message that to complete the upgrade I needed to unplug the device. I followed that instruction, and the device updated. After that both the phone and the GPS needed to have the bluetooth paring removed, and then they needed to re-pair. At that point they were both using the latest versions of the software, and were fully compatible.
Now everything works as expected; as it should. ...maybe even better than expected. I discovered just yesterday that even if I create a route using the connect.garmin.com website, I can then tell my phone to send it over to the GPS. I don't have to install software on my computer. Any ride info that gets recorded automatically syncs with my phone's Connect app, and then up to my Garmin Connect account. Strava also just works. The on-device routing works well enough, too.
Quoted: 37 Post(s)
No you don't need your phone or a cell signal to rely on navigation. That is misinformation by people who have never used one (or to be more precise, don't understand how it works). The phone app is there to make setup easy and to link all your data to other apps like Strava, RideWithGPS, etc... This is done one time, after that it's all automatic. The phone app has zero to do with using the Bolt or with navigation.
In any case, the original questions still stand. I'd like to develop a streamlined system to get this thing functioning like my old 500.
Liked 2,086 Times
