Flat Tire
My tyres / tubes are beat up and I often have constant slow leaks (pump it up once/month or so).
I don't often get flats (maybe 1/year or so) but the streets here are terrible.
Haven't had a flat for 6 months now (3000 km). I'm running 700x38 Schwalbe CX Comp at ~50-60 psi.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
I don't agree here. It's usually impact with glass and the tyres get sliced open. More than 12 pubs/mi2 results in a lot of glass on the street. So do broken car windows.
Perhaps my streets are terrible commentary isn't totally correct and it's a combination of terrible surfaces and glass/debris covering them. It's more slices down to the green belt than anything else.
Liked 4,218 Times
True “impact” flats result in snake bites caused by pinching the tube between the tire and the rim. They are indicative of low tire pressure and can result in far greater damage to a wheel then a simple “flat”. Tubeless people gush about how they don’t get snake bites but they say nothing of bending rims which is the real low tire pressure problem.
Stuart Black
Stuart Black
That’s not what most people would characterize as an “impact”. If you want to call rolling over glass an impact then getting flats from goatheads would be called an “impact” as well.
Your streets aren’t any worse than streets anywhere else. Broken glass and potholes are a way of life everywhere. On the other hand, you don’t have to deal with goat heads.
Quoted: 7348 Post(s)
Liked 2,469 Times
I'm so glad we don't have goatheads here. I don't think I've ever seen one in person (in goat?).
Having said all of that, I feel that the streets in the UK are much worse than anywhere else I've lived. It's essentially uncovered raw aggregate that the cars compress simply over time. After a new street is laid, two flat groove appear wherw people drive then the smoothness spreads out but never to where the cyclists ride. Essentially it results in the uppermost surface beibg solely composed of rough small stones that do a number on tyres. Never seen anything resembling asphalt / blacktop in the UK. Also, a good chunk of my current commute is on concrete or brick (bikelanes) both of which are miserable and by far the worst out of any commute I've had anywhere.
Thus, I humbly disagree with the previous poster that surfaces are all the same as it sounds like they haven't lived/ridden on many surfaces and are pulling from a very shallow well of experience.
It should also be said that I consider this thread is complete in my mind as others don't have a large enough knowledge base to contribute so I will no longer reply unless someone does some actual surface analysis.
Liked 4,218 Times
Even though I don't boast about it much on here, I commuted for 7 years in rural Texas and goatheads were very common. It was the major reason I ditched the roadbike with drops for a hardtail MTB. I suppose that I could have simply switched tyres/tubes on the road bike but enjoyed using the MTB around Austin and Brazos county when I wasn't commuting to the lab. It stuck with me when I moved to urban Europe where flat bars are very, very useful when one lives car free.
And I would doubt that the UK is the hell hole you describe. I’ve been there. The roads weren’t all chip seal. No road I was on was chip sealed at all.
I’ve also ridden in a lot of major cities...Washington, D.C., Los Angeles, St. Louis, Knoxville, Denver (of course), Edinburgh, Aberdeen, Antwerp, Amsterdam, Seattle, as well as others.
That’s my “well of experience”. I assure you that it wide and deep. I’ve seen lots and lots of paved roads, sealed roads, potholes, glass, thorns (other than goat heads), rocks, mud and more rocks. I know what roads look like in a whole lot of places and they all look pretty much the same. Some are good, some are great and some are worthy of being mountain bikes.
So, how does your “well of experience” compare?
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,218 Times
I’d send you some but that would be worse than sending pythons to Florida.
Stuart Black
Stuart Black
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Also, I'd just like to add that the street I grew up on, right here in good old New York, USA, was chip seal.
Portland Fred
Number and type of flats is a function of conditions, tires, riding style, and maintenance.
I used to get 2-3 dozen flats a year using flat resistant tires (significantly less when using Marathon Plus). Never got a snakebite, ever. The reason I got so many other flats is it was along a busy highway that was never swept that passed by a dump so there was a lot of small glass and metal debris.
Now I live in Portland where roads are pretty clean. I ride GP4000s and get one or two flats a year. I've gotten a snakebite or two -- because I was careless and didn't inflate properly
I ride only 23c tires.
Portland Fred
This stupid thread jinxed me. For the first time in years, I didn't carry a flat kit.
Of course I got a flat and will actually have to fix it at a shop. Ugh.
This spring, I've had two flats on two different bikes, about two weeks apart. Each bike was sitting in the garage when the tire went flat. In both cases, there was a single tiny hole on the rim side of the tube. The rim tape was intact in both wheels, and I could find no debris or anything that could have caused the flats.
One was weird enough. But two identical, unexplainable flats? How the heck does that happen?
Bikes: 2010 Origin8 CX700, 2003 Cannondale Backroads Cross Country, 1997 Trek mtn steel frame converted commuter/tourer, 1983 Univega Sportour, 2010 Surly LHT, Others...
Quoted: 48 Post(s)
Liked 15 Times
Quoted: 1002 Post(s)
Liked 237 Times
I got brand new tires.
Put one on, pumped up the tube and plffllfflflftlftlftftfffffffffffffffffffffffffffffff............................ tire went flat
Oh well....I had a brand new spare tube. Figured I'd patch the flat one and make it my spare and put the brand new tube on.
Put the tire on...pumped it up...plfflltsffftttfffftfffffffffffffffffffffff..............................brand new tube flat.
I'm not even sure what happened. I can't find any protrusions or sharp edges in the wheel. Best I can figure is I pinched the tube with the tire lever when fighting to get the tire on (tire did NOT want to go out). And I did it twice. Which means this thread is to blame.
Now I have to burn the new tire while doing a tribal dance in sacrifice to the cycling gods to rid the wheel of the bad juju.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Came home with a deep 4mm long hole in my tire the other day. Might not have noticed it, except that the sealant was still weeping out of it until it formed a scab. Its nice that we have the technology where flats have become a very rare thing if we choose...
I get 2-3 dozen flats a year using flat resistant Kenda Kwest 100psi tires. They are cheap to buy and I find they last me a around 8 to 10k mikes.
I find 1.5” in width works best for the ruff chip seal roads here in the NW.
Liked 2,469 Times
2-3 dozen flats a year? That's two or three flats a month. That's horrible.
Quoted: 18376 Post(s)
Liked 4,511 Times
@tim24k mentioned 8K to 10K per tire, which is a LOT... A few thousand miles riding on threads?
But, it all depends on flat types, and miles ridden.
One would naturally expect a person riding 10,000 miles a year to have more flats than someone riding 1,000 miles.
It is hard to say, but I'd estimate that I get one flat tire every 500 to 1000 miles. Sometimes I'll go for a while without flats, then get a couple in quick succession.
Portland Fred
Yes, quite a few.
Debris, wet, and dark all boost the number of flats since hitting more stuff, having stuff hidden by water/darkness, and having it lubed definitely leads to more flats. Likewise, regularly inspecting tires and removing shards and bits of wire before they work themselves all the way in makes a big difference.
Tire type also definitely matters, but the only way to get no flats is to ride only clean roads -- all tires can get flats.
Quoted: 293 Post(s)
Liked 218 Times
It all depends on the year and how long I am willing to keep riding on slowly deteriorating tires. I have had either 5 or 6 so far this year if I recall correctly and they have all been on my commuter that wears Panaracer Gravelkings 32mm. The rear tire is quite worn and it caught up to me tonight. I was heading into work at 930PM when I suddenly felt that now too common bouncy feeling emanating from the rear wheel. Another in and out flat. I quickly patched the tube and was on my way again in 15 minutes but this flat fix at night has convinced me it is time to replace the rear tire at least. I did make it to work on time though.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I wrote over in the poll thread:
"I'd estimate one flat every 700 miles or so on those bikes. That would be four or five per year. Still, it's no big deal."
All of those are on more narrow 25mm road tires. I don't ride my MTB frequently enough to flat. My road commuter has Marathon Plus 35/37mm tires. Those don't flat. Ever. Period.
Bikes: Marin Muirwoods 29er
Liked 5 Times
No punctures for the 5 months I've had Marathon Plus (700x38) tyres on, then one yesterday (front), and another today (back) !!!
So 2 in 2,200 miles...or 2 in 46 miles (depending on your POV).
Maybe I should go back to my Schwalbe Citizen's.
