Di2 adjustment help
Quoted: 14 Post(s)
Di2 adjustment help
Hi, so I've just started messing around with adjusting my gears myself. Well, I switched wheelsets and this forced me to do it as its was not shifting correctly. However, no matter what I did., it could not get the granny gear to shift correctly without impacting other gears. What happens is, I shift into granny gear, and after a few revolutions, it jumps into next gear.
I gave up and switched to my original wheelset. I'm pretty sure it worked fine before I adjusted. But now, the same issue is with the wheelset. If I adjust so granny gear works, then the highest few gears are noisy and jump (big ring up front, smallest few in rear).
Is it possible I need to mess around with the limit screws? Or should I Just keep tweaking? Is there a recommended youtube or other instructinal on how to do this. I was exctied that I didn't need LBS for this..but maybe I do?
THANK YOU FOR YOUR HELP
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Setup your indexing per the Shimano DM materials
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The first place to start with any Shimano repair or adjustment is dealer manual for your hardware at the Shimano technical documentation website.
https://si.shimano.com.
Find your model, download the dealer manual (DM) and do exactly what it says.
The dealer manuals are very comprehensive and if you follow it carefully and nothing is broken then everything should work fine.
I have the DM downloaded to my phone so that I can look at it in the garage.
-Tim-
-Tim-
Quoted: 942 Post(s)
Liked 527 Times
It’s obviously something your doing wrong since it now has the same problem with the original wheels. I also recommend downloading the dealer manual referenced above. You probably need to start from scratch.
Quoted: 131 Post(s)
Liked 21 Times
Also check the B-screw adjustment and the top jockey wheel is not too close to the cassette.
The L and H limits screws have to be dialed in near perfect at both ends. Yes you'll need to adjust them correctly. Then if needed, you can do further tuning with the micro adjustment mode, by using the buttons at the shifters to incrementally move the RD to eliminate any chain chatter, but sometimes this step is not needed.
Read the manual properly, watch as many Di2 video's as you can
Quoted: 800 Post(s)
Liked 512 Times
I don't have any advice for you. I know, I know...
But, I have found this website to be a good wealth of information: https://di2center.com/
Hope it helps.
Hope it helps.
Di2 fanatic
Quoted: 53 Post(s)
Liked 65 Times
I'm adding new content or details to existing content all the time, but if there's anything you're missing let me know and I'll try to get some answers online ASAP*.
*ASAP means soon-but-not-too-soon-because-I-have-a-day-job-and-kid-too-so-time-is-limited ;-).
Yes. Standard installation on the hanger, hanger alignment is the same - unscrew the RD mounting bolt (5mm Allen), place alignment gauge in its place (Park DAG is the classical one), align, remove alignment gauge, re-install RD, making sure the RD sits correctly on the stop notch of the hanger. Failing to do the latter can affect shifting performance (equivalent of mis-adjsuted B-screw).
Di2 fanatic
Quoted: 53 Post(s)
Liked 65 Times
The shop manual procedure is the other way around - adjust the deraileur offset (done in 5th cog, going to adjust mode, fine-tuning offset), then (and only then) do you dial in the limits. They have to be actually further off than on a mechanical setup, to allow the motor to over-shift. The small cog adjustment, for example, is to hit the derailleur, and then give one turn extra space. If you tune directly to the required position (as you would on a mechanical), the motor won't be able to over-shift and may then drop you to the next gear.
I also made this mistake and wrote something like "first set up adjustment bolts and then do micro-adjustments".. but that's correct for the front-derailleur only. For rear derailleurs, first do adjustment/fine-tuning and then set the bolts
