Convert Brooks B17 into Flyer?
Old 07-15-19, 01:12 PM
golftdi
Bikes: Surly Midnight Special, Jamis Coda Elite
Quoted: 28 Post(s)
Liked 13 Times in 12 Posts
Hello.
Does anyone know if it possible to convert B17 into a Flyer, by installing the Flyer Backplate & Bolt Assembly and the Flyer Bracket and Coil Assembly (available at the Brooks website)? I have tried googling this question with no success.
I ask because the B17 is available in more colors than is the Flyer.
Thanks!
Edit: I just asked Brooks this question.
golftdi is offline
Old 07-15-19, 02:44 PM
no motor?
Unlisted member
no motor?'s Avatar
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times in 297 Posts
RHM should be able to answer that. He put my B17 back together after the tensioner failed, and did a great job of it too!
no motor? is offline
Old 07-15-19, 02:54 PM
golftdi
Quoted: 28 Post(s)
Thanks -- I don't post very much here so I don't know who RHM is but presumably he will see this thread?
golftdi is offline
Old 07-15-19, 03:47 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
Signal boost to @rhm.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-15-19, 04:59 PM
no motor?
Unlisted member
no motor?'s Avatar
Thanks, I missed that. I sent him a PM too.
Old 07-15-19, 05:36 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
Thanks, guys, for the heads up! I was away from the forum while riding my bike around Lake Ontario... again. Doh!
Anyway:
I'm pretty sure I could take a B17, remove all six rivets at the rear, and attach it to a Flyer frame. That assumes I could get the whole Flyer frame. I'm not sure the parts you list comprise the whole frame, I'll check that later.
I am not sure the rivet holes would line up correctly. If not, I'd punch new holes and plug the old ones with the plugs that came out of the new ones. Then I'd replace the six rivets.
You don't have to remove the nose piece.
All that's not terribly difficult. Can you do it? Probably, but it would help if you have the right tools. Rivets are easier to install with the right tools.
Okay, that said, what you really want is a Flyer in a better color, right? I suggest you Google "Angelus Leather Paint." It seems excellent stuff. If you go that route, get a jar of the color you want as well as the pre- paint conditioner, which is a solvent to remove anything that would prevent the paint from sticking. All this should cost about $7 at a craft store.
rhm is offline
Old 07-15-19, 05:53 PM
golftdi
Quoted: 28 Post(s)
Anyway:
First, thank you for the folks who reached out to rhm.
And second, thank you very much rhm for your detailed post and for your very practical good advice.
If I end up painting the Flyer, I will post a pic.
Best to all!
golftdi is offline
Old 07-16-19, 08:49 AM
golftdi
Quoted: 28 Post(s)
Here's what Brooks' customer service told me:
"It is possible to make this conversion, in theory, but it is not that straight forward
You need all of these parts:-
BYB 299 Flyer Bracket & Coil Assy
BYB 274 Backplate Assy
BYB 298 Flyer Side Rod
BMP 183 x 2 Nut
BYB 702 x 6 Rivet"
Clearly not worth the effort, but I'm glad I asked and thanks again for the posts.
Rob
golftdi is offline
oddjob2
Classic & Vintage
0
12-26-16 03:15 PM
fender1
Classic & Vintage
0
06-16-16 08:23 AM
Wolf Dust
Classic & Vintage
10
05-07-15 12:59 AM
WestcoastPete
Commuting
19
10-16-11 10:48 AM
OLDYELLR
Classic & Vintage
0
08-09-10 06:32 PM
