Any IRO Rob Roy owners?
antisocialite
Originally Posted by 8bitevolution
And just a general question for all RR owners - when flipping the wheel back from fixed to SS, do you have a lot of issues getting the wheel to line up properly with the brakes or does it usually not require much adjustment?
Get the stick.
Bikes: 12 Y.O. Litespeed MTB, IRO Jamie Roy fixie, Custom Habanero Ti 'Cross, No name SS MTB, Old school lugged steel track bike (soon)
What kind of wheels do you have on yours? I'd like to get something stout enough that could go over curbs pretty well. I've stopped curb hopping for now because it was putting my wheels out of true and all sorts of nasty stuff.
Devil's advocate
Bikes: Surly Cross-Check, 1976 Schwinn Runabout, 1987 Schwinn Traveler
So for the price, can anyone think of any other SS/fixed bicycle that is a better "do all" than the RR?
Don't smoke, Mike.
Bikes: Devinci Tosca, IRO Rob Roy
Niiice, new RR pics ... those are in too short a supply on "teh interweb." Anyone else have photo that hasn't been posted before?
Devil's advocate
In my search for RR information, I found this guy's flickr set- https://www.flickr.com/photos/ehershe...7594204194160/
It shows it from out of the box to all together. A bit grainy but I liked seeing how the complete bikes were shipped.
dirtyphotons
JimmyMack
I found your bike on VeloSpace when I was searching Google..almost contacted you there! So it did pretty good in cross?
JimmyMack
The bike can race well. SS has a lot to do woth your fitness, and it can tax your running even more due to gear limitation. It felt solid all through the race, and I was glad to have it as a spare bike later on in the season. It feela bit heavy during a suitcase run or a sudden pitch in the road. It's very trust worthy during hard riding, and that can give you the confidence needed to hit a section really hard.
When riding fixed, the bike is geared 42x16. I have not had issues adjusting the brake pads using the thinline koolstops supplied with the Paul brakes. There is nearly and issue, but it is only close.
A friend of mine sent me the link below to a custom RR. Brothers of different mothers?
An Orange Rob Roy
SERENITY NOW!!!
Bikes: Haro Vector, IRO Rob Roy, Bianchi Veloce
Originally Posted by JimmyMack
HHCMF - Take pride in your ability to amaze lesser mortals! - MikeR
We demand rigidly defined areas of doubt and uncertainty!
i'd leave the sweet stuff
Bikes: BCA ten speed / 2007 bfssfg group buy IRO
jimmy mack, are your RR stripes painted on, or what?
Devil's advocate
The photos on IRO's site really don't do the RR justice.
Thanks to everyone who posted pictures and information on the RR. I think I'll probably have one of these on the way after the whole tax return thing is taken care of.
Plastic tape
I like the "clear" for a top tube protector on a track bike.
nice.
i have no idea why that's so visually pleasing to me. so hot.
if you have any good up close pictures of the stripes, i'd like to see them.
Weekend warrior
Bikes: 2005 Cannondale R700
Is the RR usable with 120mm wheels? I have 120's right now and am not too into the idea of getting a new wheelset if I went to a more relaxed geometry than my Mercier. And on the topic, is the Bianchi San Jose available as a frame only? I can't seem to the frame alone anywhere. It's 130mm spacing is definitely usable with the 120mm hubs, but I'm not too sure that the 132.5 spacing on the RR would work unless I compressed it down.
DNPAIMFB
Bikes: Titus El Guapo, Misfit diSSent, Cervelo Soloist Carbon, Wabi Lightning, et al.
I was really on the fence about getting one of these, but I'm being swayed. Especially that orange beastie! Oh my! For those that got the whole bike from IRO, how are the parts? I'm mostly concerned about the hubs and BB. Do they stand up to daily use through rain and snow?
SERENITY NOW!!!
Through rain, yes. No idea about snow since I haven't encountered any since I've had it. Just clean and lube the chain after riding in the rain a few times. The IRO hubs are good (Formulae) and the BB does the job although after driving the bike through 2 hrs of rainstorms this past weekend, I can hear some noises coming from that area when I'm cranking up a hill.
edit: I had a homeless guy tonight tell me he really likes my bike. That'd be the 2nd homeless guy to tell me that.
antisocialite
if your axle is long enough, you can just add spacers inside the outer locknut (the thing that presses against the inside of your dropout). some formula hubs have long enough axles for this, some don't.
or you can cold set (bend) the rear triangle to 120mm. this is what i did, and it's worked well. a bike shop should be able to do it for you cheaply.
My current rig utilizes the Nashbar flavored Dimension hubs. The rear dimension hubs come spaced at 120 with a bearing preload nut and a serrated nut to grab the inside of the frame. Two spacers were added between the two mentioned nuts and on each side of the hub. This brought the spacing up to ~130mm. The Dimension axel is not a long like Formula, and there are two unused threads within the track nut when the wheel is mounted in the frame. I've ridden off road many times using this setup, and the bike has been raced 2 times also. The confidence level is very high for this setup, and I have no fear of a nut coming loose.
The biggest loss is the inability to add a chain tensioner due to the lack of axle length. On the upside, my "wheel walking" has improved. Now there is no need for a chain tensioner.
I figure the hollow axle will fail in shear before any other problems arise.
Weekend warrior
Originally Posted by dirtyphotons
long answer yes with an if, short answer no with a but.
antisocialite
How did you bend the front fork? Or didn't you?
Weekend warrior
almost all modern front hubs are spaced 100mm (and the rob roy's fork is spaced 100mm as well). the only spacing issues you should encounter would be with the rear.
DNPAIMFB
Oh yeah, is it better to go with black or silver for the bars/stem/post/etc.? I'm thinking silver, but not if it's a cheap painted finish that's going to look like crap in a few days...
DNPAIMFB
silver is way faster
SERENITY NOW!!!
Originally Posted by pinkrobe
Well, that clinches it. The dwelling-challenged never comment on my current bike.
Devil's advocate
The more I look at jyossarian's bike, the more I like it.
Did you wrap the bullhorns in Brooks' leather handlebar tape?
The Veloce is damn nice, too.
