Squeaky Gates belt?
just another gosling
Quoted: 3872 Post(s)
Liked 1,920 Times
Squeaky Gates belt?
We've been having one of those tandem noise issues. Something to do with pedaling. Sounded like it might a a BB, but they're new FSAs and seem solid and free on the stand with belt and chain removed. Same sound whether sitting or standing. Usually appeared about an hour into a ride and never on the stand. I changed captain's pedals, no help, changed stoker's pedals, no help. I finally applied paraffin to the edge of the belt that contacts the rim of the timing ring. Seems to have fixed it. About 1000 miles on the belt, which does seem to press more tightly against the rim than it did when new. Belt tension does not seem to have changed with use.
Anyone experience this or similar?
Bikes: Paketa V2r, VECdM29er, a bunch of singles gathering dust.
I posted about this on another thread. Ours started doing this around 4-5000 miles, and I moved the eccentric to the left twice, then later flipping the belt and recentering the eccentric. So far so good.
Liked 1,920 Times
How much tension are you using? I backed off on the tension on mine after measuring the crank drag with drive chain removed, with and without the belt. When I push down on mine in the middle, it comes to kind of a stopping point where it stops stretching. That's about a 5/8" - 11/16" displacement. I don't notice any wear or stretch, nor has it slipped.
Quoted: 77 Post(s)
Liked 19 Times
Parafin on a Gates belt?
Heck, been lubricating regular chains dipped in liquified parafin for over 3 decades . . . no squeaks, no chain tattoos.
Bikes: 2011 Co-Motion Nor'Wester, 2007 Co-Mo Speedster copilot tandem
Paraffin as Zona suggested, would be a safer choice.
pan y agua
Quoted: 1428 Post(s)
Liked 697 Times
Soap and water.
Ours has made noise occassionaly. It seems to come and go. Its been quiet for a good while now (knock wood.) The Web cyclerly people say that dirt can make it a bit noisy. IIRC correctly they recommended mild soap and water.
Also, I don't think it's suppossed to "press against the rim" Co-Motion says it should run from Zero to .5mm from the outer wall of the sprocket. Zero would be against the wall, but again I'm not sure it should be "pressing" into it. So you might check the belt alignment.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
pan y agua
Liked 697 Times
Also, this from Gates:
My drive is squeaking or making noise, what’s the cause, and how do I fix it?
The belt can make noise when forced to run hard against the flanges on the sprockets. This can be due to sprocket misalignment, wheel misalignment, or run out in the drive caused by damaged components. Spraying water on the belt may quiet the drive for a few minutes, but the permanent solution is to correct the alignment or replace the damaged components. Another possible source of noise is a loose front sprocket. Using thread lock on the sprocket bolts alleviates this problem.
Liked 1,920 Times
"Press hard" is maybe too strong. Touches enough to make noise sometimes, for sure. Alignment seems OK. No visible wear on the belt. The paraffin fixed it, so I'll just apply some from time to time. Was curious to know if this was something unusual. Thanks, folks. If it becomes annoying again, I'll try flipping the belt.
pan y agua
Liked 697 Times
Is it touching on both rings or just one? If just one, I'd cosnider moving that crank half a mm out, or if both, moving both cranks half a mm out.
Liked 1,920 Times
It touches both rims exactly the same. And I just figured out the problem.
You may recall that this is a retrofit on a 2003 Speedster. CoMo says this may not work because the axes of the BBs may not be parallel. In our case they are not exactly parallel. Very close, but not exact. The two axes seem to converge in a horizontal plane on the belt side of the bike. So what's happening is that at the extreme ends of the beltline, the inside of the sprockets are carrying the belt teeth further outboard than they should be on both the captain's and the stoker's sprockets. This causes the belt to touch the flange at the top and bottom of both sprockets. It's not much and I didn't notice it until I used a very accurate straightedge just now. Both sprockets come out of plane with respect to the belt plane by maybe .005". The LBS that did the work didn't notice it either. Of course they used a straight edge to get the shims right for the two BBs. Use a straight edge fairly casually and they look perfectly aligned.
Basically I don't care, now that I know what the problem is and that paraffin is an OK palliative. Last group ride we were on, another bike dropped their chain at an inopportune moment. Belt is good. And I haven't gotten grease on any body parts or clothing recently.
Going OT, I tried wax on my chains years ago, but never really liked it. Too much time fussing and my chains didn't last as well as I would have liked. Maybe I didn't do it right. Latest chain potion is Finish Line Pro Road Ceramically Reinforced gump. I'm getting great chain life on the bike with this stuff.
Likes to Ride Far
We've been away for a while (touring the French Alps on the tandem) so just saw this thread now.
Last year, we had quite a bit of worrying noise coming from the Gates belt drive after re-assembling the bike after flying with it. I discovered that I had installed the belt in the opposite orientation to what it had been before - flipping it around completely stopped the noise.
The belt now occasionally starts making a noise after riding on wet roads / in the rain. After the water has dried, it makes some noise for a while, but if we keep riding it seems to clean itself off and then is back to being silent again quite soon. I've occasionally tried cleaning the belt with soap, water, and a sponge or brush in these situations, but I was never very successful, and continuing to ride it seems to be the best way to clean it - the open design of the belt-ring seems to work very well.
Tips on squeaky Gates belt
Hi all. I've had a similar experience with my Gates-based Cube Hyde.
Because I tried to rule out everything, I ended up replacing my old squeaky pedals (bought some Shimano Saints) and then replaced my Bottom Bracket, which cost me a lot of money and time (the old one was hard to remove).
Ultimately, it turned out the front Carbon Drive sprocket was pretty worn, and some teeth were wafer-thin. This was the source of squeaking. The moment I replaced the sprocket all the squeaking went away.
For CenterTrack there are two options: CDX and CDX:EXP - the latter sprocket is more expensive and made of more durable aluminium alloy.
- There is a chance the belt's teeth are contaminated - try brushing the belt using e.g. an old toothbrush to make sure exclude all dirt and sand as culprits. You use water + soap to do it.
- A temporary fix for squeaky belt is rubbing soap or candle (i.e. wax) into it. Do NOT use any lubricants like grases or WD-40s as it could damage the belt.
- I also noticed that the belt stopped squeaking in rain.
Bikes: Paketa V2R tandem, Granite Tandem Design TI travel tandem, Lynskey R265, Specialized Diverge, and of course a unicycle
Quoted: 11 Post(s)
How many miles were on your Cube Hyde when you replaced the sprocket?
Thanks
Thanks
Cap'n Mike
Bikes: Co-Motion Carrera
Backup Gates Belt?
I am planning a 6 day trip from Washington DC to Pittsburg on the C&O Towpath and the Alleghany Gap with our Carrera Co-Pilot Tandem.
I want to be able to recover from most mechanical breakdowns and carrry extra brake & shift cables, brake pads, an extra tire and chain pins.
So, should I carry a backup Gates Belt?
I can't imagine how I would recover, if the belt broke. Do Gates belts ever fail?
thanks
thanks
Liked 1,920 Times
thanks
thanks
Results matter
Results matter
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Quoted: 146 Post(s)
Liked 92 Times
We’ve probably ridden over 30K miles on the original Gates version and it still keeps going!
Ferengii
Bikes: Co-Motion tandem; Bilenky tandem; Trek Domane SL6
Quoted: 7 Post(s)
Liked 17 Times
We’ve also got 30,000 miles on our original belts and haven’t had any issues. None-the-less, we bought a spare set of belts when we bought the bike 7 years ago because a broken belt would definitely stop us on our bike tours (multiple tours in US & Europe each year). A spare set isn’t much weight and doesn’t take up much space, but we are out the cost. We regularly tandem tour with close friends who have the same bike set-up, so the belts are back-up for both tandems.
When we roll into towns/villages and walk or park the bikes, we get a lot of people stooping down to examine the belts, including one guy who was checking out the timing belt by pressing down hard on it with his foot. That made me glad we had spares.
I suppose it’s a decision based on risk/cost!
YMMV
YMMV
