Ripped off Presta Tip with Hand Pump - bad technique/pump/tire?
Quoted: 761 Post(s)
Hi
Wasn't on a tour, but amazingly I ripped off the tip (i.e. the bolt/nut) completely off with my hand pump. Nearly screwed up my pump and was wondering if this has happened to anyone else and its due to:
a) A cheap tube
b) A poor pump
c) My poor technique
c) Needs some discussion. How do people actually pump a tire with a small handpump without bending the presta tube pin.
a) A cheap tube
b) A poor pump
Quoted: 2236 Post(s)
Liked 1,314 Times
Instead of trying to yank it off; put your thumb between the rim and pump near the stem and, while steadying the pump with the other hand, slowly pry it off the stem. That makes the pump come off straight instead of sideways like a bottle top opener. Or, grip the pump like using a cork screw to open a bottle of wine and pull off. In either case, straight off instead of levering the pump.
Without seeing the tube or pump but knowing how these things happen I vote C: poor technique.
Quoted: 18417 Post(s)
Liked 4,532 Times
When pumping, make sure you hold the head of the pump stable, and if possible also the rim to minimize stress on the valve when pumping.
In some cases, the tube will still hold air without that screw top, and can continue to be used, at least until it goes flat.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Leave off the jam nut. This allows the stem to flex a little as the pump is used.
The jam nut really isn't needed in most cases and in some cases when over tightened can pull the tube through the valve hole in the rim and cause a flat.
-Tim-
-Tim-
Quoted: 3480 Post(s)
Liked 1,477 Times
Some time back I wrote up a comparison between the Road Morph G and the Lezyne Micro Floor Drive pump. I think these are the two most popular pumps for touring. It is unlikely that you would have that problem with one of those pumps.
https://www.bikeforums.net/touring/1...ive-pumps.html
The website programmers have changed software a few times since I posted that, thus the photos are messed up a bit.
To answer your question, I have not had the problem you had but decades ago I had a tube separate from the valve stem while I was pumping up a tire.
Bad Technique. P/V?
BITD, with the old frame-fit pumps stem was at 12:00, held up by the pump,
in the air.
then you hit the pump straight down, knocking it off so removal, force was vertical..
in the air.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I squirt a little blast of silicone spray into my pump heads and my shop air chucks. I find that this allows for a smoother on and off. I also do the same for my tire pressure gauges.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
I'm confused about when you actually did this. Was it while pumping, or while removing the pump?
If it was while pumping, get a pump with a tube. As Tourist mentioned, I really like my Topeak Road Morph (and associated variants). The only bikes that I have a pump without a tube for are the road bike that just doesn;t get ridden that much, and the fat bike because one doesn't really fit.
Nifty trick, I need to give this a go.
2-Wheeled Fool
Liked 677 Times
Thanks, Jeff. In an effort to keep an uncluttered shop, I only use the spray silicone dielectric grease. Its good for electrical connections as well as a minor lube job. One word of advice: Keep it away from anything that you may paint in the future. Paint of any kind does not play well with silicone.
Mad bike riding scientist
Quoted: 6241 Post(s)
Liked 4,250 Times
Hi
a) A cheap tube
b) A poor pump
a) A cheap tube
b) A poor pump
The introduction of the Topeak Morph pumps made frame fit and mini-pumps obsolete and demonstrated how useless they are. All that energy that used to go into ripping the valve stem off is now put into the ground which makes damage to the stems less problematic and makes pumping up a tire with a pump you can carry on your bike much easier. Get one and don't look back.
Stuart Black
Stuart Black
That pretty much sums up my take on the newer pumps like the morph series.
after having used the other type for decades, a road morph G made for so much easier and safer pumping.
Quoted: 935 Post(s)
Liked 1,328 Times
C*pt*i* Obvious
Been there done that.
Every pump I use now has a hose.
With mini pumps, it can be quite fatiguing to get up to full pressure, then lose focus and make the mistake of damaging the valve stem.
Liked 4,250 Times
Au contraire, mon frère! I can never understand why folks are so in love with all these mini-pumps (and I include the Morph and Lezyne's in that category). I still use an old fashioned Silca frame-fit with Campagnolo metal head. It weighs 5.5 oz, in comparison to the heavier Topeak Morph G ( 7.57 oz), Lezyne HP (6.61 oz ), or Lezyne HV (7.44 oz).
I would agree that most mini-pumps are as useless, in my opinion, as frame fit pumps. But the Topeak Morph and Lezyne are very different because they mimic a floor pump.
Not only that, but it will pump up a tire to very high pressure much faster than any of those pumps. I have on many occasions stepped in to pump up the tire of a hapless cyclist fumbling unsuccessfully with their mini-pump or CO2 cartridges. If used correctly (i.e. valve stem at 12 o'clock, thumb wrapped over tire and index finger wrapped around the back of the head there's no way you will risk damaging the valve.
I know how to use a frame pump "correctly". I just never found it to be all that efficient. Tearing valve stem off was a very common occurrence because while you may be able to pump the tire up to 160 psi, anything over about 80 was a struggle. I disagree that the way you describe holding the valve stem is going to negate valve damage. That last bit of pressure will usually cause the rider to move both the pump and the wheel during pumping.
Finally, I've never used a pump or any other object than maybe a rock to fend off dogs. Never had the need to.
Stuart Black
Stuart Black
Liked 4,250 Times
Maybe but you'd have to carry the pump and hose around. You also can't push that kind of arrangement into the ground as well as with the Topeak Morphs and Lezyne MicroFloor pumps. Yes, they cost a little more but they last for long enough to make it worth it.
Personally, I prefer the Topeak to the Lezyne. It's a bit more streamline and the pump handle on the Morphs is more comfortable.
Stuart Black
Stuart Black
don't try this at home.
Quoted: 986 Post(s)
Liked 521 Times
My Mini Morph is small and light weight. I really like the design, with one end of the pump on the ground, like a floor pump. It's shorter barrel means I need more strokes to fill a tire. That's a reasonable tradeoff for me. (But I mostly use CO2 now, the pump comes along on all-day solo rides.)
I counted at least 200 strokes to get my 25mm tires up to about 70-80 psi, more than enough to finish the ride. I was pushing down with all my upper body weight for the last 50 strokes. No pressure gauge is needed, just pump until it's getting difficult. That's a lot of strokes -- pumps with longer barrels are way faster.
The Mini Morph needed about the same number of strokes on a 38 mm tire to get it to reasonable pressure, maybe 30 psi.
Liked 1,477 Times
Au contraire, mon frère! I can never understand why folks are so in love with all these mini-pumps (and I include the Morph and Lezyne's in that category). I still use an old fashioned Silca frame-fit with Campagnolo metal head. It weighs 5.5 oz, in comparison to the heavier Topeak Morph G ( 7.57 oz), Lezyne HP (6.61 oz ), or Lezyne HV (7.44 oz). Not only that, but it will pump up a tire to very high pressure much faster than any of those pumps. I have on many occasions stepped in to pump up the tire of a hapless cyclist fumbling unsuccessfully with their mini-pump or CO2 cartridges. If used correctly (i.e. valve stem at 12 o'clock, thumb wrapped over tire and index finger wrapped around the back of the head there's no way you will risk damaging the valve. A simple downward tap releases it. For an even more durable (but heavier) pump with an one-way valve look at the Zefal HPX. Both of these pumps are also very effective at fending off belligerent canines. Try that with your mini-pump!
I carry a Zefal HPX on a couple bikes, but only because I already owned those pumps and I have more bikes than I have mini floor style pumps. I would not be buying a new Zefal HPX now when the other pumps are in my opinion so much better.
But if you have the arms of a wrestler, the old Silca pump probably works great.
I got nothing to add to which has already been very well said, except +100 on the Road Morph. The little hose makes all the difference.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
+1. Lezyne microdrive. Screw on chuck at the end of a hose. Idiot proof.
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Quoted: 935 Post(s)
Liked 1,328 Times
I'm curious as to why you think the Morph is superior to a Silca or Zefal. It's definitely not faster.
I suppose it's because it's rather like a short floor pump, so you push down, against the ground..
