Tubeless or not?
#227
Quoted: 20810 Post(s)
Liked 9,456 Times
Mounted up the 28mm Pro1 Addix TLE.
They went on to the rims very easily, though it took a little work to seat the beads with my ****ty air blast canister. Significantly more narrow than the 28mm Hutchinsons - probably 4mm narrower - and actually measure about 26mm wide on my rims (Reynolds Assault SLG, 17mm ID). I guess that makes sense since Schwalbe said that the nominal size would be true-to-size on a 19mm ID rim. Strangely, they're only about 1mm shorter in height than the outgoing Hutchinsons.
Oh, one other thing - DT Swiss rim tape rocks, y'all.
I'd seen great reviews online, so I picked some up. It goes on so, SO much better than Stan's and the like. The DT Swiss stuff has just a little bit of stretch, and when you're pulling it on, it'll conform nicely to the rim, instead of wanting to crinkle and be stubborn like the non-elastic stuff.
Hopefully I'll get in at least a couple hours on the new tires on Wed.
Likes For WhyFi:
#228
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Likes For sfrider:
#229
Liked 9,456 Times
It's the only TL rim tape I've used, but 21mm DT tape went on without fuss on my P1800's. It seems DT rims generally need two layers of tape for GP5000TL tires or they can be a little leaky. The rear P1800 bubbled a little sealant through the rim joint opposite the valve, so I shot DT support an email, and they promptly responded that some tires with a wider inner diameter can benefit from an additional layer. The wheelset came with only one layer.
#230
Liked 9,456 Times
Just a quick update on the Pro1 Addix TLEs - they're pretty damn nice. I was concerned that I'd be giving up some comfort vs the larger 28mm Hutch Fusion 5s, but that's not the case, even at 5psi higher. But they're not squishy. Likewise, they've got great grip... but seem to roll really, really well. Time will tell on the durability and longevity, of course, but if those are at least okay, these are stellar tires.
Likes For WhyFi:
#231
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
WhyFi Did you find a decent source for your tires? I’ll be in the market soon.
Keep the chain tight!
#232
Liked 9,456 Times
Edit: $38 right now - https://www.merlincycles.com/en-us/s...0c-187206.html
Likes For WhyFi:
#233
Quoted: 4717 Post(s)
Liked 1,882 Times
I think that I got them from Merlin. They were ~$35 each at the time, IIRC.
#234
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
#235
Liked 9,456 Times
I'm not sure. I just know that the older ones were prone to cuts and wore relatively quickly. These are supposedly better in both regards, but I don't know how, specifically. I've never had a sidewall cut (I'm jinxing myself right thar) so I've never paid particular attention to that aspect, either.
Likes For WhyFi:
#236
Super Modest
Liked 4,620 Times
#237
I have Reynolds R4 Carbon wheels and GP5000 tubeless wheels. I got about 1200 miles on tubeless when my rear had a sidewall blowout. I got a new tire and even Thor couldn't have enough strength to get that baby on. I tried every trick in the book including...the soap trick, hot water trick, laid them on hot cement...nada. I took it to the bike shop and it took them 4 hours and a lot of swearing. I am not debating whether tubeless is worth it when I know the only chance I have is to fill the hole with a filler. Does anyone have any tubeless tires that are possible to mount?
#238
Liked 1,882 Times
#239
Liked 9,456 Times
The Schwalbe Pro 1 Addix TLE that I just got were very easy to mount - they ride really, really nicely, though I haven't had them long enough to comment on durability or wear. Merlin has these at $38 each right now.
The Hutchinson Fusion 5 Performance 11Storm were also very easy to mount. Good, but didn't feel quite as nice as the new Pro 1. Decent wear, though in about 4000 miles, they've taken two 1/4" cuts in the middle of the tread that were too large to close with just sealant - not sure if that's just bad luck or if the casing is to blame. If flint/glass isn't a problem in your area, it's probably a non-issue.
Schwalbe G-One Speed, 30mm - awesome tire if they fit.
Likes For WhyFi:
#240
Bikes: Canyon Endurace, Merckx liege 75, Cinelli Vigorelli
Quoted: 167 Post(s)
Liked 114 Times
Another vote for Hutchinson Fusion 5 All Season. It was easy as pie to mount them on Shimano wheels.
#241
Quoted: 850 Post(s)
Liked 344 Times
If everyone went tubeless today, would shops be able to just eat this kinda labor cost? It’s absolutely absurd that this is a problem in 2020. TL has been around for 2 decades in the cycling industry.
#242
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
A tubeless anecdote - I have really enjoyed the ride on my Spesh RapidAirs, which is one reason i have stuck with tubeless so far. The other day, as i was pumping the tire for a ride, i noticed a sidewall cut and the usual sealant spray. I put a newspaper under the tire, turned the wheel so it was hole-at-6 and then left it overnight. Seems to have sealed up ok - was holding 80psi the next day.
Not bad, i gotta say.
Likes For guadzilla:
#243
I've been tubeless on the road for the past couple of years. It's just better in every way. In only the past year or so, the main thing I've noticed is that the setup has become much, much easier and much more reliable. A couple of weeks ago, I mounted some new GP5000TLs on my road wheels with my bare hands and a floor pump in about twenty minutes total during lunch. This is on Giant SLR 1 Disc wheels. They've been holding air since then. I had a similar experience recently with both some Maxxis Ardents on my trail bike (Mavic XA Elites) and some Jumbo Jims on my fatbike (the notorious Mulefut 80s). Basically foolproof installs. The industry finally seems to have figured out how to make this easier with better bead profiles and better tolerances, at least with certain setups.
#244
I took my wheel back to the lbs and they said I needed a new valve and new tape. I had them tape it and on my first ride, my valve was leaking. I had 100 psi when I left and by the time I got home, I had 40 psi. I'm trying to decide whether to go back to the lbs and have them fix it or just scrap tubeless and go back to tubes.
#245
Liked 9,456 Times
#246
Pizzaiolo Americano
This is like confirmation bias on steroids. As a non-user, and by its very nature, you'll only notice tubeless when it doesn't work for someone else - it's like taking a survey but only accepting the negative results.
I can guarantee you that 90% of the guys that I ride with don't know that I run tubeless and have been for longer than the three years that I've been riding with them. I've never had a flat while with them, but I know that I've taken punctures in their presence. Despite that, if I should take a Goldilocks puncture and go flat the next time I'm out with them, whenever that is, it'll automatically be an indictment against tubeless in their minds, because it'll be their only data point (as the successes went unnoticed).
The other thing with road tubeless, in particular, is that it's still relatively new, not all sealants seem to be appropriate for road pressure and user experience/skillset is... varied, to put it gently. Is a certain rim/tire combination really impossibly tight, or is it just that the person installing them was not yet practiced enough to do all of the little things to ease the process? Does sealant in general not work above a certain pressure or was the person using stuff better suited for MTBs?
This is why I think that it's important to talk about rates of punctures, before and after the move to tubeless, and the specifics of actual user experiences, rather than to lean on observations of failure or, even worse, parrot third-hand "experience" from those online or friends-of-friends.
Revisiting this topic because I am having my first issue with tubeless set up ever...I am mainly a MTBer and have never had an issue with setting up a tubeless combo. I got a new set of the Bontrager Aeolus Pro 3V for my new Domane last week. When I went to set them up with a new set of Continental Terra Speeds (I know...gravel tires...but I ride this bike on multi surfaces...), they would not hold air...I did the soapy water thing and found a few small punctures in the sidewalls of my tires. The thing is, there was 90ml of Stans sealant in the tire...It would not seal these little punctures. The sealant came out of a brand new, sealed bottle. I use Stans on my MTBs and have never had an issue...It's strange. I ordered some Orange Seal Endurance and will try that tomorrow....
#247
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
#248
Non omnino gravis
Sidewalls are just more permeable. I've had some tires weep sealant from the sidewalls for several days before finally sealing, sometimes requiring multiple rides. IME, any tire that requires sealant needs a ride or two to seal completely. This is why folks can mount a tire, set the bike down, and the next morning the tire is flat. Whenever I mount a set of new tires, I ride the bike around the block immediately afterward. Nine times out of ten that's enough. But things like skinwalls tend to leak a lot at first.
#249
Liked 9,456 Times
OooOoooh! I kinda want these - bar end tubeless plug tools from Effetto Mariposa -
They'd be more quick/convenient to access than getting stuff out of the tool roll. If you can store them with a bacon strip loaded that would be really sweet.
#250
Super Modest
Liked 4,620 Times
WhyFi I just mounted two Pro1 Addis TLE tires (25c) a few minutes ago. No soap or lube, just mounted them with my heroic grip and hit them 150 PSI. I’ll pull the valves and put sealant in tomorrow. They are currently “resting” at 100 psi.
I used your Merlin link, ordered them Monday night and they came today. Shipping was a little high but the total price was still decent.
Likes For Trsnrtr:
