Super Record chain wrap
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I've got what I believe is a second generation Campy Super Record rear derailleur, and I'm trying to set it up with a triple crankset. According to the 1982 Campy catalog, the chain wrap capacity for this derailleur ought to be 28. I'm using a 49-42-32 crank and a 13-24 freewheel, so that should work, right? My trouble is, I haven't explored the edges of what Campy derailleurs of this vintage can do, so I'm not sure how short I can get away with cutting my chain. Here's how it looks now with the big-big combo (kindly disregard my phone's choice of what to put in focus):
With a modern derailleur geometry that's about as far as I'd want to stretch it out, but it seems like I can keep twisting the derailleur cage to the point where it would effectively allow the chain to go straight from cog to chainring without any deflection. Is it safe to run that way? It looks like I could probably take out two more links if I let it wind that far. Right now, the chain is too slack on the 32-15 combo and 32-13 is out of the question.
(FWIW, I am aware I could make this a non-issue with a long cage swap, but those are ugly and I'd like to keep this bike looking good.)
Thanks for any help!
My Bikes
My Bikes
Quoted: 380 Post(s)
Liked 541 Times
JMO of course but I'd say that you're wasting your time with a wide range triple and a short cage. No matter how you cut it you will gain no gears ultimately. Use two rings and get a 7-gear cluster/freewheel and be happier
Like I said - JMO
Like I said - JMO
In the lingo of the day, 28t max meant the biggest possible cog you might get away with on your freewheel, not total tooth capacity.
Honestly, that looks dangerous. A chain that short could fold the rear derailleur into your wheel. You'd be better off adding some chain, and losing another gear combo with the 32t. That's kind of a hack though.
I suggest you get one of those SOMA Spence Wolfe style extender cages if you want to run a triple. A super record RD simply is not designed for that. Typical gearing would have been 42/52 and a 13-21 in back. Maybe a 13-24 for those epic climbs or for those that preferred to climb in the saddle most of the time.
Likes For Salamandrine:
Bikes: Yes
Liked 3,868 Times
I thought about that. I have a 6-speed 13-30 freewheel which, if I could get this derailleur to work with the 30T cog, would provide almost the same range as the setup I'm trying to make work here, but it would obviously have much bigger jumps between cogs. Anyway, I like triples and I like to make weird combinations work. Wasting my time is one of my specialties.
My Bikes
My Bikes
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
Hey Andy.... Dean in Port Angeles here! I can't offer much help in the extremes to which a Campy SR RD can accommodate other than to tell you that I ran one with 52-41 chainrings and a 13-26 freewheel on my Cooper. Old legs and hills I like to ride were driving me to a 32 tooth cog in the rear. As I recall, I could not get the SR to clear the 32 even with the rear axle located at the rear of the dropouts of my Cooper. I don't recall anything about the chain wrap. I went down the path of the Soma long cage swap. It worked, but I totally agree with you that it did not look right. In the end, I chose to replace the SR RD with a Suntour Cyclone GT with a black hanger. In my view, it looks much like the Campy RD, handles the 32 with ease, and shifts great. The SR RD is boxed up....safekeeping for a future owner.
'Hope to see you again someday on the north end of the Olympic Peninsula!
Dean
Dean
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
Bikes: Yes
Liked 3,868 Times
That makes sense. I see now that the catalog actually lists it as "teeth capacity" so that would seem to fit what you're saying. VeloBase claims a 26T wrap capacity for the Super Record and Nuovo record and claims "confirmed" for the NR. I'd be happy to give up the small-small gear, and really even one more. I don't intend to use those combinations, but once I've been in the granny ring for any length of time my brain shuts down for a while, so I want to make it as close to OK as I can get.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
Dean
Dean
BTW, here's why I have to keep it all Campy:
Even the triple is blasphemous enough.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
Right! That's why I'm trying to use it with a 24.
My Bikes
My Bikes
Quoted: 380 Post(s)
Liked 541 Times
I'm thinkin' that you are in need of a proper beating with a stout cane
A triple is not blasphemous it is a desecration
Even posing such a thing speaks to a sub-humanity that is in itself offensive beyond telling
My God, Man!!! What Are You Thinking? ? ? ?
Likes For Steel Charlie:
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
Andy, I’ve used 34-28 on a Super Record RD, but agree with others that pushing bigger than a 28 wouldn’t make for a happy derailleur. If you want to cheat a little with a modern, but looks vintage compact double, and you’re feeling spendy, Boulder Bike has IRD 46-30 cranks for a pretty good price. It’s a really nice crank (put one on my/your Heron re-do).
Bikes: Yes
Liked 3,868 Times
I don't know how I stumbled into this insinuation that I'm trying to use something bigger than a 28. The big cog on the freewheel I'm trying to use is only 24. The 32 I mentioned is a front chainring. To be honest, I could probably just block off the big chainring and use this as a 42-32 double. I just want to make the full triple work.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
Me trying to make this work:
I think I've got it working, mostly. I'll post some pictures in the next couple of days.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 874 Post(s)
Liked 2,289 Times
On my Medici with a Super Record 2nd generation RD I am running a 52/42 front chain ring set up with a 5 speed freewheel that has a 28 tooth low. With the axle stops backed out so the axel is well back on the drop outs it clears the cogs well and shifts fine . I can run big to big if I want , but rarely do.
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
One of the luxuries of having a ridiculous number of bikes is that I can have a few like this that are suboptimal in some respect. My goal here is to get the gearing low enough that this will be comfortable to ride on rolling hills. I'm a terrible climber (heavy and weak) so this wouldn't cut it in your neck of the woods, but it'll do for most of the hills in my local area.
You said it yourself...
If you have enough bikes, then why consign this one, an icon of steel cycling, to such a build. It's your right, of course, but just because you can...
Best regards, Eric
I seem to have lost what little mind I had left before this all started.
Bikes: Numerous
Liked 3,098 Times
When you say you used a 34-28, what were the other extremes? 50-34 + 14-28?
Likes For Spaghetti Legs:
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
I've used a Nuovo Record RD with a 13-28 and a 35/46.
I've also used a Zeus Superchronos, which is basically a Super Record clone, with a 13-30 and 35/48.
Both were tight, especially the Zeus setup, but I could use every gear.
Bikes: Yes
Liked 3,868 Times
The way I see it, if God had not wanted us to use triples, He would not have made 74 BCD Campagnolo chainrings.
It's not like I'm putting brifters on this or something. From 25 feet away, you probably wouldn't even notice, and that's the point of why I'm doing this the way I am.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
VeloBase also says the NR capacity is 26, which matches what you report there, but you got 30 tooth wrap out of the Superchronos. That surprises me.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
Submitted for peer review...
With my current chain length I get a little resistance here:
With the wheel further back it was enough resistance that I wasn't comfortable with it. With the wheel where I have it, I can feel the spot but it clears the cog teeth with some room to pivot still left in the derailleur. Since I don't intend to use this combination, I just need to avoid catastrophic failure. (And, I've got some experience with the results of a chain that's too short, so I do know how catastrophic the failure is and how quickly it happens.)
Once the chain is on the big-big combo, it looks like this:
Obverse:
Not pretty, but I have not exceeded the derailleur's natural range of motion.
Small-small is not so good:
As soon as I start turning the pedals, it takes up the slack in the upper part of the chain, lifting it off the chainring, but when the pedals aren't turning I get the above result. I'd need 28T wrap capacity to make that work, so I'd judge that the Super Record derailleur does not have 28T capacity.
On the 32-15 combination, the results are much better:
So, that's 26T wrap capacity (49-32 + 24-15).
Finally, the finished product:
I'd rank the offenses to tradition that I have inflicted on this bike like this:
1. Clipless pedals
2. Modern compact handlebars
3. Non-coil cable housing at the rear derailleur
4. Absurdly long valve stems
5. Tall stem
6. Triplized crankset
7. Modern clincher rims, polished silver not dark anodized
8. Brake cables too long
9. Not period correct bottle cage
10. Quick link in the chain
Others may, of course, order this list differently or spot things I've overlooked.
Obverse:
1. Clipless pedals
5. Tall stem
My Bikes
My Bikes
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Because I want to be able to ride it more! Would it not be more of a desecration to leave this bike hanging in my garage unused?
Cheers, Eric
Nice backdrop to a beautiful bike. It looks good in Campy.
Likes For Last ride 76:
Lurker
Well done!
You, being the sensible and experienced rider that you are, are never going to use small-small, so that scenario is academic.
You will also never use big-big, for the same reason.
But, should you temporarily lapse into insanity, you’ve configured things such that the lesser of two evils will happen:
Bike looks awesome!
- A bit of extra slack in small-small, which isn’t nearly as damaging as
- Too little chain in big-big, which will quickly break something that’s vital
Bike looks awesome!
1987 Nishiki Prestige (now 650B!)
1981 Trek 710
198? Nishiki Olympic 12 mixte (now 650B!)
2020 Surly Troll fat-tire build
1981 Trek 710
Quoted: 800 Post(s)
Liked 753 Times
edit: Ah, I just read more closely and saw your big and small rings are 49/32. That's less range than what I was attempting. Still. I'd just use a mid or long cage.
Bikes: Yes
Liked 3,868 Times
Well done!
Bike looks awesome!
Bike looks awesome!
I wouldn't bet that I will "never" use the bad combinations, but it will be rare. As you say, I'm basically trying to make sure that my response to accidentally using the bad combo is "Oh yeah..." rather than "Oh no!!!"
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
It's noisy on the big cog, but the rest of the cogs are fine. Also, the SR front derailleur shifts the triple amazingly well with this set of chainrings. I've found that a Nuovo Record front derailleur is absolutely terrible with a 52-42-24 crankset. It wouldn't shift from the small ring to the middle -- I had to shift from the small ring to the big ring and then back down to the middle. (I won't even dare show this crowd the bike that has that! Suffice to say I wanted to at least have a chance of climbing the hills at California Eroica.) I had heard that a 49T big ring is the secret to making the NR work with a triple. A bigger granny gear probably wouldn't hurt either. With the 49-42-32 rings, the Super Record shifts as well as if it were designed for this.
My Bikes
My Bikes
Likes For Andy_K:
