Upgrade of my Shimano RS-81 wheels
Hi everybody, I have 2015 Cannondale SuperSix Evo Ultegra bike with rim brakes, Shimano RS-81 wheels and Vittoria Rubino Pro 700x25mm tires. Want to upgrade wheels but I am afraid of clearance since now the distance between rear tire and chainstays is around 3mm (may be around 3.5mm but no more) on each side. My wheels have 15mm internal width and 20.8mm external width. So which wheel set would you recommend and what is max internal/external width Ok for my bike?
Quoted: 1528 Post(s)
Liked 718 Times
Given your clearance is already minimal, I'd stick with the Shimanos.
Their narrow width is about the only thing that counts against them, and they're excellent in almost every other way except I guess the aesthetics of the hubs, the internals of which are peerless, IMO. The rims are pretty sweet too.
Although I suppose you'd just have room to run a 25 on a somewhat wider rim, by the sound of it... Not a whole lot of wiggle room though.
Here's a question - what do you weigh? If you're 70-75kg or less, you can probably go for broke minimising the clearance, particularly since a larger tyre on a wider rim is going to be less likely to go out of true, all else being equal.
Likes For Kimmo:
Liked 718 Times
How deep are the RS81s? I'm guessing they're the C25 version. You can get em deeper, you know. Up to 60mm, IIRC.
Again, if you're stuck with old-school width, these Shimano wheels with the carbon/ally rims are about as good as rim-braked clinchers get, IMO.
Something to consider is that aero rears aren't doing much aero in all that dirty air; something like 4/5 or more of the gain is from the front wheel. So you could just throw a Zipp or whatever on the front.
Likes For Kimmo:
Liked 718 Times
Kimmo Good to see you back here. I was beginning to think the Covid got you.
How about round your way? Things look pretty damn sketchy over there.
Quoted: 4717 Post(s)
Liked 1,882 Times
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
You are right. I forgot to mention my Shimano wheels are C24. I am aware about C40 and C60 wheels and think about Shimano Dura Ace C40 wheelset as a very good and expensive replacement of my current wheels. But what do you think about Campy Eurus or DT Swiss wheels? I saw some DT Swiss with external width 22mm which should work for my bike as well.
I just put a new 23mm Conti 5000 tire on and it measure 25.0 mm wide after sitting for a couple of hours. Conti may have made adjustments.
Likes For biker128pedal:
