Mikashima Unique Custom Pedal Love
I fell in love with these pedals the first time I opened the box, back in 1980. They've stayed in the box ever since, though they've been through a whole bunch of household moves. The first Suntour Superbe pedals were, as far as I can tell, simply rebadged versions of these bad boys.
If they otherwise look familiar, eyeball some Campy Record/SL pedals. Imagine how the steel-cage versions would look in satiny aluminum, or how the black alloy cages would look in silver. And then imagine a much higher level of finish and attention to detail, like machining away the raised flash around the strap openings in the pedal body.
The only thing that takes away from the oozing of class, the only fly in the ointment to my eye, is the "MKS" and the very-Japanese stamping of the model number on the outside edge of the cage. Somehow the clean/crisp "MKS UNIQUE CUSTOM" engraving on the front/rear of the cage wasn't enough---Mikashima was very proud of this pedal, and very proud of its "UCR-02" model number. Makes me wonder what the UCR-01 might have been---track? Maybe I'd be OK with the "MKS" on the outside edge if it was on the forward part of the cage on both pedals, instead of on the front of one and on the rear of the other.
Although the Mikashima spindles aren't rifled like the Campys, I'm pretty sure all removable parts are interchangeable. So if you're needing spindles or cones or end caps for your Campy Record/SL, Mikashima could come to your rescue.
Handy tip for the cheapskates: whenever you manage to snag a set of Campy pedals with clean end caps, if you're going to be riding the Campys and aren't a bloody anorak, swap the clean Campy end caps for some MKS caps, like this:
https://www.benscycle.com/MKS-SYLVAN...8aArAfEALw_wcB
These are the newer Sylvan caps, which are shaped a little different than the Campy caps, but are the same thread. If you're not fussy, gently file away the raised MKS logo, put 'em on your Campy pedals, then scrape 'em up to your heart's content. Sell off the clean Campy end caps to the anoraks who will pay good $$$ for genuine Campy end caps. I used to get nearly free Campy pedals that way, buy a beat-up pair with clean caps for $35-$40, sell the caps for $35-$40, and the pedals only cost $10 for the MKS caps. But no matchy-matchy.
You used to be able to find Campy-clone domed MKS end caps, like the ones on these pedals, which was even better, because with those you couldn't tell the difference without getting your nose up close enough to see there was no Campy lettering on them.
Anyhow, a few pix follow, more here on flickr:
https://flic.kr/s/aHsmoxFY7o
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
Quoted: 3812 Post(s)
Liked 3,341 Times
Thanks very much for posting.
Great pictures.
Have a set of original Mikashima Unique road pedals which I like but have never used. They came to me second hand and are a missing one of the dustcovers. Dustcovers are of a design which seems to interchange with nothing else so have been unable to put them to use. Forty years of snoozing!
Great pictures.
Quoted: 4512 Post(s)
Liked 6,383 Times
Glad you brought these up, I have a similar pair of Unique Road's that have been needing to get cleaned up for service, cleanup happened today so overhaul will be next.
First good pedals I had were steel cage Unique Quill that came on a Mizutani Super Seraph in HS. Ended up being very glad it had these and the "Mighty" Sugino Mighty Competition crankset as I proceeded to let them get the factory grease washed out very quickly and before I knew it.
All survived just fine despite my ignorance and lived on for many years until they were stolen with the Raleigh SC they were on.
Huge fan ever since having benefited from their bulletproof nature.
Nice! I had these on my commuter way back then, I think I added some kind of alloy add-on toe flip on the rear cage plate to make it easier to flip the pedal around. I always liked that they took the extra step to rivet in the crank/toe-strap rub protectors, instead of just folding over a chunk o' steel.
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
lurking nightrider
Great pedals indeed. Beautifully anodized and smooth as buttah.
"If there hadn't been women we'd still be squatting in a cave eating raw meat, because we made civilization in order to impress our girl friends. And they tolerated it and let us go ahead and play with our toys." Orson Welles
Liked 6,383 Times
Especially current day, MKS are one of the best values in cycling, great looks, excellent quality, tough as nails, all at a very reasonable price.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
I'd like to see a wide shot or two of your photo staging.
Quoted: 4722 Post(s)
Liked 3,036 Times
I had a pair of these with the black anodized cages. They replaced the Campagnolo SL, whose cages I had worn out in two seasons. The MKS had more durable cages.
Quoted: 823 Post(s)
Liked 1,395 Times
I love MKS pedals - they're simple, durable, no-nonsense, reliable, smooth, and reasonably priced. What really amazed me was how responsive the company can be. Somewhere I have the email address still - several years ago I had two pairs of MKS Sylvan track pedals with bent left spindles due to poor cornering on my part. I found an email address and wrote to them to see how I could get replacement parts. They wrote back and asked me to mail them $9 cash and they would send me two left spindles. I did, and they did, and those pedals are still in use today.
I also have a pair of MKS Uniques that came with my pieced-together Allegro. I wonder if they take the same spindles - the previous owner managed to tweak the left one just enough to be noticeable ...
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 984 Post(s)
Liked 634 Times
They certainly look nice, but I do not understand the name. A Campy copy, yet "unique"?
Great tip -- I'm looking right now at a set of Campy track pedals from one of my bikes that is missing a cap, and don't want to pay eBay $$$$ for a replacement.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 3,036 Times
...The only thing that takes away from the oozing of class, the only fly in the ointment to my eye, is the "MKS" and the very-Japanese stamping of the model number on the outside edge of the cage. Somehow the clean/crisp "MKS UNIQUE CUSTOM" engraving on the front/rear of the cage wasn't enough---Mikashima was very proud of this pedal, and very proud of its "UCR-02" model number. Makes me wonder what the UCR-01 might have been---track? Maybe I'd be OK with the "MKS" on the outside edge if it was on the forward part of the cage on both pedals, instead of on the front of one and on the rear of the other...
Unique was the series designation for MKS' top grade pedals and it it dates back to at least the pre-boom era of the mid-1960s. Originally, there was just the Unique series, then it was divided into Unique Custom and Unique Royal, with the former having a forged shell and the latter having a cast shell. The original Unique series and the two subsequent Unique Custom and Unique Royal series, had both road and track models.
Liked 3,341 Times
Interesting to note that the subject set is metric. Perchance this may be why they have not been put to use...
They're 9/16" x 20tpi, the standard for quality pedals/cranks. Or am I missing something?
I never used them because they looked so lovely I didn't have the heart to get them all greasy and scuffed. I don't hold onto many NOS/vintage bits just for appreciation, I'm definitely of the "these things were made to be used" school. But these guys somehow...these and a couple/few Suntour Microlite freewheels. I used to build the Microlite bodies with the largest 2 cogs steel, thinking I'd get to use them longer due to lower cog wear. Not thinking that smaller cogs wear out much quicker, and the weight penalty for using steel i/o alloy on the smaller cogs was less than on the bigger cogs. Shoulda built 'em with steel 13-15-17t cogs, and alloy for the 2-3 biggest...
Fuggedaboutit!
Fuggedaboutit!
Liked 3,341 Times
the spindles are marked with a letter M indicating that they are metric thread
so the thread is 14.0mm X 1.25
note the examples posted by others; their spindles lack the M marking
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
I no longer have these but they're take offs that came with a 2nd gen black DA group so they likely pre-date these Customs. The 'dirt' is seepage of the original grease.
Can't tell if that's an M or if it is, perhaps it's simply Mikashima? Doesn't look the same.
Likes For clubman:
Bikes: Some Schwinns, Raleighs, Centurions, Crescent, Bianchi
Quoted: 248 Post(s)
Liked 289 Times
Phyllo-buster
Liked 2,054 Times
Oh yeah, glad you like them. I can't ride clips and straps anymore so it's best somebody puts them to work. I suffer from chronic sellers remorse but I'm trying hard to get over it so I can sell the rest of the pile.
Don't know what the "M" stands for, but the threads are not metric. 9/16"x20, just like what's marked on the box. I just threaded them into a brand-new set of non-metric crankarms to be sure.
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
Liked 3,341 Times
Thank you for the update.
Good to read all is well sorted.
Evidently one of those cases where an M marking did not stand for metric.
My apologies for the false alarm.
Liked 6,383 Times
Bump!
Standby for more MKS love.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
They are a close copy of Campagnolo's Record pedals. The only closer copy is the KKT Pro-Ace.
I have a set of MKS Unique track pedals, con denti. They don't have a model designation:
Likes For JohnDThompson:
Liked 6,383 Times
Great pictures.
Great pictures.
The ones with the slot are the version for these, the older ones of these only have a slot with no serrations.
I have a set with no caps and was cleaning them, going to see if I can fab an adapter of some sort for temporary/show.
Can we see yours?
Quoted: 796 Post(s)
Liked 522 Times
Lovely MKS bling. I agree MKS stuff is great I have two pairs of MKS 'sneaker" pedals (RMX). I don't have to mess with clips and straps and I am way too slow for clipless, the Sneakers are perfect and bullet proof -not as beautiful more industrial looking but so very functional
Liked 3,341 Times
Those take the larger diameter caps from the older design.
Can we see yours?
Can we see yours?
Ah gotz me no peecha takin' thingus.
Far az ah been able to figger they be not show'd at either vb or speedplay.
Also checked google images and ebay just nowe without enny hitz.
Thar be a pair on ebay with the slotted dustcaps but it is later than my set. The one here does not have the uniform teeth all the way 'round the edge of the cap.
Cap is indeed large diameter w/male threads. Threads appear to be quite fine although ha' no chequed 'em w/gauge.
Believe me set to hail fra ~MCMLXX.
Liked 3,036 Times
My pedals came with a "UNIQUETOOL". Look close and you'll see how the teeth are in sets of three, with a double spaced gap between each set of teeth. Pics courtesy of my son.
