Campagnolo Dropout Screw Tap
Need to chase new paint from dropout screw threads. Anybody know the tap size? Will post in C&V also. Thanks.
kanawa-
Sutherlands says they are M3 x .5.
Quoted: 1438 Post(s)
Liked 1,092 Times
Get yourself some M3 x 30 or so mm socket head stainless cap screws and a couple of matching nuts, they will hold better than the original thumb nuts and springs.
SE Wis
Quoted: 2738 Post(s)
Liked 3,379 Times
SE Wis
Liked 3,379 Times
I use the acorn nuts as the "knob" like on the originals with a little loctite and cranked down. I run a tap down the holes so they turn by hand.
Friendship is Magic
Bikes: old ones
Quoted: 26374 Post(s)
Liked 10,346 Times
...it is not at all difficult to break off a small diameter tap like this in the hole you are cleaning.
Use plenty of oil on the tap, and back it out every couple of turns to let the chips of paint and detritus clear.
They are hardened to maintain the cutting edges, so brittle. Because they are hardened, they are difficult to drill out if you break one in the dropout.
