Can you tape an already glued new tubular tire?
Quoted: 2323 Post(s)
Liked 4,981 Times
I've searched but can't seem to find an answer. I have a brand new tubular tire that's has a coat of glue applied to the base tape already. Is it OK to mount that with tubular tape vs glue or should I stick to glue on the rim? Getting ready to set up some new tubular rims using tape and hoping to only have to buy one tire if I can use this one.
Thanks!
Thanks!
Steel is real...and comfy.
Quoted: 1361 Post(s)
Liked 423 Times
At your discretion. I've done exactly that without issue. It sticks almost too much. Matter of fact the rim tape was aggressive enough that the base tape on a Vittoria tubular was coming off upon my later removal.
No manufacturer will give the green light for such - liability.
What kind of tire is it? In my experience, tubular tires come with something over the base tape -- whether it's latex, a form of glue, or whatever -- in anticipation that the installer will use whatever to mount the tire. If it's a new tire, and you've got a clean rim, you're good to use whatever you want.
If it's a new tire that someone else applied mastik to, you should still be ok, just scrape off any high spots or globs if there are any.
Quoted: 378 Post(s)
Liked 1,409 Times
I had my first flat, ever, on a tubular last weekend. Ever. Bad valve vulcanizing right at the inner tube part. Well-used Tufo Carbon Composite, so yeah, $80, but it came with some wheels, so any use was gravy.
Liked 4,981 Times
Well, finally got this done tonight. First time using tape. So freaking easy, hopefully I did a good job. seemed really easy and didn't take long at all. Just took my time laying the tape down, pressing it good to the rim. Then I put the tires on, pumped them up a couple of times while checking alignment, and then pulled out the facing tape. They are now sitting in the corner curing. I'll throw them on something this weekend for a test ride. Still not sure which bike is going to get them. Mounted then on some 40mm C.F. Reynolds wheels so I've got to decide which bike will benefit the most from them.
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
I'm not getting this . You put the tape on , then you put the tires on , then you pulled the facing tape off ? In the past I have just put on the tape , pull the face off , put the tire on and ride . Maybe I'm going to learn something here .
Liked 4,981 Times
Well, I'm no expert but that's how I did it. Let's you adjust the tire as best you can before it's stuck down. I just exposed a little tape on each end at the valve so I had something to pull once I was happy with how the tire sat.
Quoted: 1856 Post(s)
Liked 664 Times
I wouldn't use the Tufo again - too hard to remove a tire without causing other damage.
Liked 664 Times
I have, too, with a Vittoria, and they do seem to want to come apart a bit.
Quoted: 378 Post(s)
Liked 1,409 Times
I avoided sealants in tubulars, for years, but @ldmataya convinced me it was a good preventive measure. Now I put 2 oz in each new tubular.
Peace of mind issue, perhaps, and of course, subject to change if I flat and get all psycho twisted up on it.
Liked 664 Times
I do use a sealant now, but your LBS is right, it would not have helped that leak one iota, as it was a structural failure.
cycledogg
Road Cycling
24
04-23-22 07:26 PM
JohnES
Road Cycling
16
09-20-17 08:04 PM
