Panaracer Pasela TG Aramid Bead 27"x1 1/4" Less than 32 mm
Bikes: 1975 Schwinn Voyageur II (Made by Panasonic), 1988 Schwinn Voyaguer (touring)
Quoted: 11 Post(s)
I mounted a pair of 27x1 1/4" Aramid Bead (folding) Pasela TourGuards on Araya 27" x 1 1/4 rims approx 24 mm wide (outside to outside). The tires measured 28 mm when infalted to 80psig and 100psig. Here are 3 additional facts
Tires are marked 27x1 1/4 and 630 x 32 on sidewall
Box tires came in was maked same as sidewalls
Tires were bought at Nashbar on clearnace ($14 each) back in 2003 and only mounted in 2010.
Here is 2 observations
The actual tire width is approxiamately a 1 1/8" (28 mm) verssu a 1 1/4" (32 mm)
The rim appears wide enough and is stamped 27x1 1/4
Questions
1. Did Panaracer grossly undersize tires back in 2003.
2. Does Panaracer still undersize tires
3. It is possible they stamped a run of tires incorrectly, stamped as 32 mm but actually 28 mm.
The truth is out there somewhere
Questions
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Haven't we figured out a long time ago that stated tire widths are pretty unreliable?
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
I seem to remember a thread that hashed out the actual widths of Paselas once mounted. No idea what it's title was though. A quick search might find it. (but probably won't)
Dang I'm helpful sometimes.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
IIRC, it has been stated in BF that most tires are rated wider than actual and that Paselas are more accurate than most. I measured a set of 28mm (1-1/8") Paselas a year ago and they came out pretty much dead on.
Real cyclists use toe clips.
jimmuller
jimmuller
perpetually frazzled
Bikes: 1977 Bridgestone Kabuki Super Speed; 1979 Raleigh Professional; 1983 Raleigh Rapide mixte; 1974 Peugeot UO-8; 1993 Univega Activa Trail; 1972 Raleigh Sports; 1967 Phillips; 1981 Schwinn World Tourist; 1976 Schwinn LeTour mixte; 1964 Western Flyer
Quoted: 5 Post(s)
Liked 6 Times
Does it matter?
I have the wire-bead version of the Pasela TGs in 27 x 1-1/4 and they measure an honest 32mm fully inflated (~80-90lbs). They are on 1-1/4" wide rims.
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Does that number represent the width of the tire, or the height of the tire above the bead seat?
Quoted: 1854 Post(s)
Liked 663 Times
USA, if it's printed on the side of the tire it should be width.
Liked 5 Times
like most others, i've experienced tire size discrepancy.
If the tire is thinner than advertised, you've lucked out, b/c at least it'll clear your frame/fenders. Just try the next size up when those wear out.
Running 28mm tires never hurt anybody on a road-going bicycle. Just keep em inflated
-rob
-rob
Quoted: 17 Post(s)
Liked 41 Times
Any time they try to sell you something described in millimeters or centimeters, you can be sure it's a trick.
If they stick with sensible, honest inches, then you can trust them.
- Auchen
- Auchen
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Yes. I have a tire somewhere that has the size "622 x 28" molded into the side, and a silkscreened label that says "630 x 28" applied to the sidewall. Mistakes happen. As for the other possibilities you list, I wouldn't rule them out. As for the myriad possibilities you didn't list, I wouldn't rule them out either.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Yep, been discussed many times here.
https://www.bikeforums.net/showthread...ran-narrow-but...
+1 The good news at least they are narrower than advertised. Wider than advertised could be a problem, depending on clearances.
Liked 6 Times
SP
Bend, OR
Liked 6 Times
At least the old Paselas were only 10% under the nominal width. I had a pair of "700x32c" Continental Top Tourings that measured 26mm - narrower than my "700x25c" Michelin Axial Pros (which measured 27+). But then Conti's always been pretty "creative" with tire widths.
SP
Bend, OR
SP
Bend, OR
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Quoted: 7346 Post(s)
Liked 2,452 Times
Neither, actually. They're supposed to get this number by flattening the tire out, measuring linear distance between the beads, and dividing by 2.5. Then you're supposed to assume that this will be width.
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 19 Post(s)
Liked 5 Times
regardless, if you're gonna expect accuracy down to the mm you'd better take the rim width into consideration. The same tire will measure at different widths depending on the rim width.
--Don't Panic.
--Don't Panic.
Quoted: 11 Post(s)
Quoted: 11 Post(s)
Thanks for Input
Thank you to everyone who contributed. I concluded the tires were most likely stamped incorrectly and are really 27x1 1/8. However, they do ride very nice.
I was concerned since I am buying new Pasela's for another bike with 27" wheels and wanted to be sure Panaracer is not overstating the width at the current time.
Liked 6 Times
SP
Bend, OR
Quoted: 5 Post(s)
Liked 6 Times
Having 32c and 28c Paselas (and other tires - they're my two primary sizes) on a variety of bikes, I can tell you that, give all things equal, if 3-4mm of tire difference makes THAT much of a difference to your butt, you must have princess and the pea syndrome. Especially if we're talking 80-100psi. I mean, really? Now, 32-38, I can see that. 23-32? sure. But 28-32? I certainly can't tell much of a difference.
