What tool do I need for bike pedals?
Quoted: 35 Post(s)
My pedal sizes are 9/16 but confused what tool to get to remove them.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Registered User
Quoted: 188 Post(s)
Liked 276 Times
I've done the allen wrench thing, and soak them with some kind of lube over night. I've cracked a few knuckles trying the allen wrench thing.
Bought a pedal wrench, life is easy again!
Likes For TheDudeIsHere:
Quoted: 1438 Post(s)
Liked 1,092 Times
Edit: Allen 20574
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
More importantly turn them the correct direction. They are both different
Likes For dedhed:
Quoted: 2026 Post(s)
Liked 1,096 Times
As mentioned not all pedals have wrench flats, only a hex socket, 8 mm if you are lucky, 6 mm if your not. You need an extra long hex wrench or a hex bit in a 3/8" square drive ratchet to protect your knuckles
Likes For HillRider:
Quoted: 980 Post(s)
Liked 582 Times
There are some pedals that have wrench flats too narrow even for a dedicated pedal wrench. For example, MKS detachable pedals have couplers that mount on the cranks and the flats are too narrow for a Park pedal wrench. There's no hex fitting. Luckily, a 15mm cone wrench works perfectly.
Really Old Senior Member
Enock
Park Tool PW-1 or Park tool PW-3 will do 9/16 pedals. Here is a video showing them.
Likes For bikeme:
Quoted: 18371 Post(s)
Liked 4,507 Times
Quoted: 4559 Post(s)
Liked 2,802 Times
Forget the clockwise/counterclockwise, left/right stuff. Tighten toward the front of the bike. Loosen toward the rear.
Same spatial orientation trick I use for adjusting spoke nipples. Visualize the spoke nipple from looking down at the top of the wheel. Tighten and loosen as we would any ordinary threaded connection.
Likes For canklecat:
Likes For sweeks:
Bike Noob
Likes For I.B.Roots:
5/8 Crescent Wrench works perfect for me.
Lots of videos
https://www.youtube.com/watch?v=LYvHbN9rNZM
Lots of videos
A Crescent wrench (Brand name) is typically an adjustable open end wrench.
https://en.wikipedia.org/wiki/Adjustable_spanner
Quoted: 1062 Post(s)
Liked 665 Times
In addition to the many suggestions, if a pedal is being stubborn, I will support the end of the crank with wood blocks from the floor, so I can push down really good on the wrench. I've never had to fight a pedal more than once because I clean and grease the threads before re-installing.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
If a pedal has both wrench flats and an opening for an allen wrench, I will sometimes use both to get a little extra torque. I put the allen wrench and 15mm wrench on so they are approx. 180 degrees then set the bike so the rear wheel is held in place (on the ground) and set the crank so my loosening action will push the pedals forward. This way the chain holds the crankarm in place and you only need half the torque on each tool, which can save you from slipping and jamming your knuckles into the chainring.
You could also, if you have a stout wrench that fits on the wrench flats (good pedal wrench) set the bike on the ground and align the crank and wrench so pushing down on the wrench will loosen the pedal, then push down on the wrench with your foot.
Quoted: 1324 Post(s)
Liked 927 Times
Likes For Miele Man:
