Can you oil/grease a QR skewer cam
Quoted: 318 Post(s)
Liked 149 Times
I think I read emphatic no but I can't find it now.
I have one that I can't get to close all the way when it's tightened across the fork about right. The lever moves freely when the skewer's removed. But on the bike, the lever goes just past the tightest part of the cam then stops. I can push on the lever so it seems tight, but it doesn't go as far as it should, and when I open the lever it gives way with a sharp pop.
Maybe corrosion on the cam? Or maybe I did something to damage it.
This is the kind where the lever is peened on so you can't open it to look at the cam.
I swapped a different skewer onto the bike for now.
Quoted: 432 Post(s)
Liked 461 Times
To answer your question about the grease/oil, I've put a drop of oil inside QR cams before. I've not any problems with doing that but I suppose there could be some concern about the oil damaging any rubber materials in the QR.
As for your QR, it could be damaged and in need of replacement.
Likes For tFUnK:
Likes For dsbrantjr:
Likes For 2cam16:
Quoted: 4211 Post(s)
Liked 3,881 Times
As others said, yes. This is a standard (although minor) step on the tune ups I do. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I too put just a touch of something in there just to keep them from possibly getting corroded or worse. Jon Cannings said it was ok in a video eons ago, that's good enough for me.
