Spokes
Bikes: 1938 Raleigh Record Ace (2), 1938 Schwinn Paramount, 1961 Torpado, 1964? Frejus, 1980 Raleigh 753 Team Pro, Moulton, other stuff...
Quoted: 26 Post(s)
Liked 11 Times
Spokes
I need some spokes - currently have Alpina, ss, double-butted, but too short. I need 18 - 20 300mm. Who is a good source? Thank you!
Quoted: 1088 Post(s)
Liked 1,205 Times
+1 on danscomp. I just got some spokes for my first wheel build, and they were super helpful and organized. Fast shipping.
I bought these: https://www.danscomp.com/products/43...ted_Spoke.html
is just a real cool dude
Quoted: 31 Post(s)
Liked 32 Times
There's two guys on ebay that I use and cut spokes to whatever size you need and you don't need to buy full boxes. Last two wheel builds I did I used them. Plus they're cheap and fast. I think one guy is called Yojimbosgarage and the other is Bicycledreams.
Quoted: 26 Post(s)
Liked 11 Times
Thank you. Interesting that the treaded ends are all 2.0 mm, no 1.8.
Quoted: 7348 Post(s)
Liked 2,470 Times
Quoted: 1372 Post(s)
Liked 1,751 Times
I just bought a set of spokes from a local bicycle shop. The made all the measurements of hub and rim, cut and rolled the spokes. They added a wee bit for the washers I am using on my old tubular rims. The spokes, butted stainless steel and nipples, fit perfectly. They are about a dollar each, but I got my two sets for this old Glider...
Quoted: 16 Post(s)
Dooood heck yea, thanks so much for the tip. I was in need of a set of odd length spokes and the Yojimbo seller had exactly what i needed for no additional cost and reasonable shipping.
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
Quoted: 26 Post(s)
Liked 11 Times
Current are Alpina, SS, DB, 295mm, 1.8/1.5/1.8. They and the nipples do meet, but not by much. There's 2mm of thread showing on the left side. They seem fine on the drive side.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
I think Bicycledreams is danscomp?
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
From a strictly stress-strain point of view, thinner spokes will tend to undergo lower amplitude stress cycles as the wheel rotates, goes over bumps, and the axle loads (bike plus rider plus payload) vary from ride to ride. This will yield a longer fatigue life for the rims (in the eyelet area) and the hub flanges, as well as the spokes.
Furthermore, as the wheel incurs small, semi-permanent distortions through use (i.e. prior to a re-truing/retensioning event), thinner spokes will tend to experience less tension unevenness. This will also contribute to a longer fatigue life for the spokes, rims and axles.
In practice, I don't know how measurable these advantages are.
Calamari Marionette Ph.D
Another one for Dan's Comp.
Quoted: 26 Post(s)
Liked 11 Times
OK, gotta get on this. These are for Geraldine's 'dress-up' wheels.
