Wahoo Bolt:
So far I love it. More info than I could possibly use, but really nice and better than using the phone.
Quoted: 20808 Post(s)
Liked 9,450 Times
Wahoo Bolt:
https://www.wahoofitness.com/media/w...S_pdAyJiUG.jpg
I ask because I have an Android tablet that I can use for setup, but no Android/iOS phone.
That Wahoo Bolt looks interesting. My Garmin Edge 500 is still doing everything I want it to, so I'm not in the market, but perhaps in another generation or two some compelling features will come out and get me thinking about an upgrade.
Quoted: 35 Post(s)
The example in the photo has it away from the edge and actually under the saddle.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
A bike fit,
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
this thread will not let me read past page 690..
however I got a new bearing in the pulley for my front shifter and a new chain. 4615 miles on a commuter chain not a bad run.
Liked 9,450 Times
That's because there aren't any pages beyond 690 - they're sometimes referred to as 'ghost pages,' and they seem to pop up when there have been a number of deleted posts within a thread (so they're more common with loooong threads).
Clueless Newbie
Bikes: The two-wheeled variety
Quoted: 61 Post(s)
I ordered two items online recently: a 120mm Zipp Service Course SL stem (+/- 17°); and a Columbus FEL 3k carbon fork, 1 1/8” – 1 ½”.
Sprintech bar-end mirrors. I am using only the left side. Darn ugly thing but I am tired of twisting my neck to look over my shoulder for cars.
Quoted: 35 Post(s)
Thats "MISTER Poopypants"
Bikes: Specialized Tarmac with Shimano RS81s and 105s
Quoted: 44 Post(s)
For my Litespeed T1
A Campagnolo Chorus groupset for my new bike
Quoted: 482 Post(s)
Liked 151 Times
Have only got a 20 mi ride in the wind and cold in since the fit, all seemed real good, but I need some longer rides. It was a Specialized fit for a Roubaix. Dropped the stack - removed 1.5 cm off spacer - raised the post slightly. Adjusted shoes and cleat positions, new insoles and shim, adjusted seat position and angle. Took over 2.5 hours. I do think it was worth it, especially with this bike which takes some effort to adjust the seat post and stack. I could loose up to 15 mm more with the short cover. Will see if need fine tuning after a couple hundred miles.
Bikes: Montague Swissbike X50
Quoted: 9 Post(s)
26" JBI Wheelmaster 36-spoke wheel --- it was the simplest way to get a quick release axle on my Montague Swissbike X50 so I could install a Montague Rackstand.
Not finding any reviews, so hoping it was a decent choice --- probably going to go to a local shop and try having a custom wheel made, and getting an IRD Classica 6-Speed Freewheel 13/32 --- I just commute currently, but hoping to do some bikepacking/touring at some point in time.
Bikes: Specialized Crux Expert Evo, Felt DA, Surly Crosscheck, Divvy
Quoted: 8 Post(s)
I bought a Smartmount race number holder a few years ago and recently broke the bracket that holds the number plate onto the seat post when racking the bike for a triathlon.
I wanted to buy a new bracket but could not find one on their web site. Sent them and email and they shipped me a new part gratis!
Good people there and if I remember correctly all products are made here in the USofA.
So I didn't actually buy this one recently but I did buy it.
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
What happened?
Liked 292 Times
Meanwhile, back at the Foreclosure Ranch, I happened to come up with these items so far...
Fenders, rims and tires on the last one only.
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
A tube of Shoe Goo to glue the sole back onto my 33 yo Detto cycling shoes.
Jon
Jon
Quoted: 3221 Post(s)
Liked 2,049 Times
Quick question for you (and any other owners): other than the initial set-up and some of the navigation features, how much does the Bolt rely on your phone? Once set up, can it operate as a typical GPS cycling computer without a phone 99% of the time?
1) If you always ride out of the house, then the Bolt can use a WiFi connection to upload a completed ride, if you need to do that. Setting it up for add'l WiFi connections requires the tablet, so that's about the only method for uploads if not using a BlueTooth connection to a phone/tablet. This is only important if you do remote start/stops, as the device will then save the ride internally until you choose to sync via WiFi.
2) It operates completely in stand-alone mode and does not use the phone for any navigation, ride tracking or for information about speed, distance, time, etc... it's a complete stand-alone computer.
3) If you navigate and use downloaded routes generated in RWGPS or Strava, you need to run the tablet app in BT mode to get routes/courses onto the device. I don't think you get get routes directly to the device via WiFi, nor can you use a cable/USB connection for routes as you can with a Garmin (and need to with a Garmin if using RWGPS routes).
Liked 2,049 Times
Bikes: FM098-V2, '16 Synapse
Quoted: 81 Post(s)
Liked 9,450 Times
It doesn't need a phone or tablet once initial setup is done. Some caveats:
