is this cassette wear normal for a new bike?
My bike is 2 weeks old and has about 75 miles on it. Last night I took a look at the cassette and noticed some of the teeth are showing wear. Is this normal?
Here's a link to the full size picture so you can zoom in on it: https://www.dropbox.com/s/3fijpe1bgu...sette.jpg?dl=0
Quoted: 2026 Post(s)
Liked 1,096 Times
No, it's not normal as cassettes can last many thousands of miles. However, what you are seeing isn't wear, it intentional. Modern cassette cogs have shaped and contoured teeth that aid shifting speed and reliability and that's what you have. As an aside, that thing is awfully dirty for only 75 miles. A bit of housekeeping would help assure a long service life.
Quoted: 5793 Post(s)
Liked 2,594 Times
It's not wear. It's the normal tooth profiling that you see on modern index cassettes. see here
FB
Chain-L site
FB
Chain-L site
Bikes: Trek Domane 5.2, Ridley Xfire, Giant Propel, KHS AeroComp
Quoted: 1648 Post(s)
yep, way too dirty for only 75 miles, what the hell are you riding thru?
Randomhead
Liked 3,701 Times
I recently sold a crank, and I was shocked at how much profiling there was on the teeth. Crank had ~250 miles on it and some teeth looked really bad until I realized that they were barely worn and just shaped like that to promote shifting. I think the profiled teeth get most of the wear because they get a lot of contact while shifting the chain.
Bikes: 89 Schwinn 754, 90 Trek 1100, 93 Trek 2300, 94 Trek 1400 (under construction), 94 Trek 930, 97 Trek 1400
Quoted: 29 Post(s)
The cassette looks fine as others have already stated.
The condition of the chain is a mess.
Looks like too much lube, OR the chain was not cleaned before you got the bike, OR it was lubricated and the excess lube on the outside of the chain was not wiped off.
Crud is attracted to excess lube, and the crud is what causes accellerated chain wear. You need to clean the clean, lubricate it, and make sure that you wipe the lube off the outside of the chain (it doesn't do any good on the outside of the plates).
Constant tinkerer
I suspect this is what happened to the OP. One ride with a new chain covered in that sticky factory lube and it can look like that.
What's funny is I took that picture after running a rag over the chain. The chain has whatever the factory or LBS put on it. I'll give it a good cleaning this weekend.
Quoted: 29 Post(s)
The original oil used by the chain manufacturer's is pretty thick, and hard to remove. While it's a toxic hazard, nothing cuts the lube on a new chain like gas. Using protective gloves, get a cloth rag and wet it in gas, then wrap it around the chain and hold while turning the cranks to rotate the chain. Make sure you lube the chain (dropping lube on the pins/rollers only). Cover the tire, and use a brush to clean the cassette or freewheel (or better yet, remove the freewheel or cassette from the bike before cleaning).
