Red rear light; To blink or not to blink?
Walmart bike rider
In your opinion, which is better or easier to be seen?
Multiple blinky lights or just one?
Liked 2,979 Times
Pulse. I prefer a steady & a second that pulses.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Strobe Best
Fred "The Real Fred"
Likes For 10 Wheels:
Quoted: 3461 Post(s)
Liked 1,467 Times
Daytime, blink. Night time, constant on.
You can't get any depth perception on a blinking light, but a constant on light, you can get an idea on how far away it is. I want drivers behind me to be able to estimate where I am. If they are seeing a strobe light, they have no clue where I am.
Fog or heavy overcast, often use two blinkers to get their attention.
Above is pertinent to taillights only.
Likes For Tourist in MSN:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I put my rear on strobe. When I'm driving, I seem to notice a bike with a strobe sooner.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
I usually run one on each seat stay(one of those is the dyno taillight) and another on the helmet. Not blinking unless I'm on the highway ("Hey, I'm a bike").
IMO, blinking light(s) get relatively more attention than non-blinking light(s). Also, the color of rear lights is typically red, symbolizing stop or danger, and a flashing red light serves to alert or caution motorists approaching from behind.
I always have two rear lights in red in blinking mode attached to my bike basket. I have the same make of rear lights.
Likes For Eyes Roll:
Quoted: 4260 Post(s)
Liked 1,364 Times
Their headlights should be illuminating by the time that depth perception matters anyway.
You could also use two lights: one constant and one flashing.
Liked 1,364 Times
Flashing versus constant rear lights.
You want to register as a cyclist from a long distance away. Note that I didn’t say “seen”: that’s the first step. You also want the driver to know what you are. The further away this can happen, the longer the amount of time there is to have it happen.
Cycle lights tend to be small, which, obviously works against being noticed from a far distance.
The problem with steady lights is that they they can be hard to see or be interpreted as some sort of not-moving reflector.
Flashing objects are more noticeable from farther away (it’s why they are used on radio towers, etc, etc).
A small flashing light is more likely to be registered as a cyclist (because that’s generally what is using them on the roadway). This is a big advantage of flashing lights that naysayers don’t mention.
People frequently chime in with the “estimating trajectory” or “depth perception” stuff but they don’t realize either it’s not really an issue or it doesn’t matter. This bad because it encourages people from using the better flashing light.
The point of a light is to be noticed from a longer distance before where these could start mattering. By the time/distance they could matter, the car headlights are illuminating you.
The “trajectory” issue is more so for things that are crossing in front. With cyclists, the driver is coming up from behind (there’s no crossing). Anyway, to a large degree, drivers are seeing cyclists as not or barely moving.
There is nothing specific that suggests drivers have special perception issues with the flashing lights used by cyclist. There are indications where there could be issues, like for flying, but they might not be relevant. At the distances you want the rear lights to be working, small constant lights have similar problems with “trajectory” and “depth perception”.
If you believe there are these problems with flashing lights, you could use on constant and one flashing.
The purpose for rear lights is to be noticed for a long distance and time away as possible. The purpose is not for negotiation around you (the car headlights are for that purpose).
If you are riding in a group, flashing lights can irritate other riders, especially at night. (It’s not that uncommon for cyclists to have their rear light angle up, which makes them more annoying for following cyclists and makes the light less effective.)
Pulsing might be less irritating to other riders but, if it’s too slow, it might have an effect close to being constant.
That car rear lights are constant is no argument that constant would be better for cyclists. Car rear lights are much, much larger for one. Also, cars are also much more common (all of them flashing would be awful).
Keep in mind that nothing is perfect.
Likes For njkayaker:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
which do you notice more? I notice blue and red flashing lights more than steady on red lights. The other day on the interstate I could see a set of blue and red flashing lights far up the road and I noticed everybody's brake lights were coming on and they were merging over to the passing lane while slowing to the speed limit (this was in an 80mph zone where everybody drives 90mph) I kid you not it was a guy on a bike that had red and blue flashing lights on the back of his bike. freaking genius.
Palmer
Quoted: 1671 Post(s)
Liked 1,825 Times
Likes For tcs:
Liked 1,364 Times
These are a good idea too but they need headlights to work. So, they aren't sufficient. (Note that it's generally a legal requirement to have a rear light at night.)
They can be dim. Also, many people don't have pedals that will accommodate them.
These are the same idea as pedal reflectors but brighter (much brighter) and work for any pedal. You do have to remember to put them on. But they work in all directions (unlike pedal reflectors).
https://www.amazon.com/Jogalite-Cros...s%2C115&sr=8-2
There are two general types of reflective material (used like this). This works when wet. The other, which looks gray in marketing material doesn't work when wet.
Liked 1,364 Times
Likes For jadmt:
Front lights, blinking or steady can be VERY annoying. I would only use steady front lights at night, when needed. Never front blinking lights.
Likes For bikelif3:
I use a rear blue and red blinking light on a medium, non-seizure inducing setting. I like fooling cars into thinking I'm a cop ahead of them. Legal in my state from my reading of statutes. Have been passed by many cops with no problem.
It looks and sounds cool, but you don't want to get yourself into trouble for impersonating cops. You double check it with a cop or lawyer and make sure that you are absolutely certain as to what you are doing.
Quoted: 1591 Post(s)
Liked 1,020 Times
I blink during the day and go solid at night, But that's situational. In the city I'd flash at night but riding on country roads with a lot of trees the blinking light bounces of them in way that's distracting to drivers. But that's with a good bright light. With a lower lumen light I might still flash.
Likes For jon c.:
There's nothing wrong with fooling drivers to drive more safely than they would otherwise, especially when I'm on the road with them....
Likes For bikelif3:
Quoted: 455 Post(s)
Liked 112 Times
Here's an interesting bit of info.
When we were touring in Germany flashing rear lights were Verboten! We were stopped by the police and informed about this. In fact we are leaving for Europe tour #6 in a few weeks and I will say we have never seen flashing lights. One less bit of kit on our bikes as we have dyno hubs and front and rear lights on our bikes.
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 157 Post(s)
Liked 146 Times
In all the years I've been driving on I-ways I've NEVER seen an entrance ramp w/o a sign stating bicycles are prohibited, along with other varieties of low-speed transport.
Quoted: 904 Post(s)
Liked 1,899 Times
it is legal in Montana and I have put 1000's of miles on the I90. I travel to Minnesota a lot and always see bikes on the Interstate in wyoming and both SD and ND.
Likes For jadmt:
Quoted: 157 Post(s)
Liked 146 Times
Thanks for that. Last I was in SD was early '80's, yet to get up into ND or west to Montana. Will keep this in mind should I ever get back over that way.
Liked 1,364 Times
Bicycles are allowed on Route 10 west of Cabazon in California because it's the only way through the pass.
Bicycles are allowed on parts of the Garden State Parkway in NJ (but you need a permit).
Liked 1,364 Times
